BVM Plug and Play F16
Old 10-24-2014, 06:12 AM
  #126
smchale
My Feedback: (67)
smchale's Avatar
Looks great Kris! Keep flying it and ignore the experts!
Old 10-24-2014, 09:32 AM
  #127
tulz161
Originally Posted by gunradd
Here is a pic all fueled ready to fly showing the new stance with new main springs and a weaker nose spring with the correct F16 ride height. Some have said I would have problems rotating. Well with the gear on the F16 being so close to the CG I knew they didn't know what they are talking about. So the 10 gallons of fuel I burnt yesterday in the F16 says I was right flies great and no problem rotating.
Love that second pic! How is the 140 with the external stores? Ever find yourself wishing for more?
Old 10-24-2014, 04:06 PM
  #128
gunradd
My Feedback: (9)
gunradd's Avatar
Thnx Tulz
I have a k180 in it now and that's perfect with the stores on. Also you end up pulling the throttle back more with the bigger motor and saving some fuel.
Old 11-09-2014, 04:11 PM
  #129
cigartoyz
cigartoyz's Avatar
Originally Posted by tulz161
And what do they charge for all that (but not the silly spark turbine)?
You were able to get the JL F16 for $4700
Old 11-10-2014, 07:09 AM
  #130
dubd
dubd's Avatar
Kris or Sean, do you think a 210 has too much residual thrust for this F-16?
Old 11-10-2014, 08:12 AM
  #131
gunradd
My Feedback: (9)
gunradd's Avatar
It will be fine with the 210 but you will need to watch the top end speed. I think it would be enough flat and level to cause structural failure.
IMO anything that will take a 180 should just use a 210 for better fuel economy and an engine that will fit many different airframes in the future.Also another benefit is how much cooler the 210 runs witch will help the pipe last longer. But care on the top end speed needs to be considered with the 210.
Old 11-10-2014, 10:50 AM
  #132
dubd
dubd's Avatar
What's the maximum safe speed for this F-16?
Old 11-10-2014, 11:15 AM
  #133
gunradd
My Feedback: (9)
gunradd's Avatar
BVM has a VNE listed in the manual but I don't off hand remember what it is. I would not go over 170mph with it. Its not a fast plane. Its big and light. watched Rob Lynch 2 weeks ago with his clean thunderbirds plane with a 160 inside it and it was moving pretty fast and he put the plane through any and every maneuver you can do with it so it can take what ever you throw at it but I would keep the top speed down.
Old 11-10-2014, 11:42 AM
  #134
mr_matt
My Feedback: (10)
mr_matt's Avatar
1/2 the nose strut is $240? Did BV remake the gear?
Old 11-10-2014, 07:19 PM
  #135
smchale
My Feedback: (67)
smchale's Avatar
Dantley,
the published VNE is 175mph.
kris is correct about the top speed, I'd be cautious. I agree with his comments re the K210, I suspect we'll see more and more of them, even just turned down because of the fuel efficiency and cooler temps.
i assume your question about residual thrust was aimed at idle thrust? The idle thrust on the K210 is 1.4lbs (6.2N). The f-16 with the gear down does have a good amount of drag and if you add the drop tanks I see no issues with the k210 at idle or near idle.
Old 11-10-2014, 10:26 PM
  #136
dubd
dubd's Avatar
Thanks Kris and Sean. 175 MPH is pretty damn fast with a plane of this size. Glad to hear the K210 with work with some caveats.
Old 08-23-2015, 07:32 AM
  #137
ddennison
My Feedback: (15)
Hi guys,
I am on my second season with my F16. I wonder if you all have mushy feelings when you take off? I have a 140Rx in mine and it flies fine but flying right after TO has required more "up" than I usually need to hold. almost full at times just to keep it on a gentle few degree climb. Once it gets going it flies great.
My stab trim is a little below the mark on the template/skin (leading edge). My CG is on to one finger breadth aft (hat full, gear down). I am wondering if I am still a bit nose heavy or if the 140 just takes a little time.
Any thoughts would be great.
Dave
Old 08-23-2015, 08:08 AM
  #138
cyphur01
cyphur01's Avatar
Nose heavy. I am running 1/2" in front of the mark. 200 flights. Locks into a good attitude on landing. I have a p140rx in mine as well. Only time mine feels sluggish is with the smoke tanks full.
Old 08-23-2015, 10:47 AM
  #139
Kelly Rohrbach
Hey guys, I will be flying my f-16 with a Pegasus HP, wonder what you guys are doing in terms of fuel tanks/smoke tanks combination. I'm thinking of one of the two smoke tanks to fuel being the peggy has a bigger appetite. Planning on flying it loaded for bear most of the time.
Old 08-23-2015, 01:35 PM
  #140
ddennison
My Feedback: (15)
Do you mean 1/2" behind the mark?
Old 08-23-2015, 01:44 PM
  #141
Kelly Rohrbach
Me thinks that's what he meant.��
Old 08-23-2015, 01:54 PM
  #142
gunradd
My Feedback: (9)
gunradd's Avatar
Highly recommend using all 4 tanks for fuel. That gives you about 6 mins with at least 1 min of reserve
Old 08-23-2015, 02:01 PM
  #143
Kelly Rohrbach
Kind of thought so, especially with the hard points full. Thank you
Old 08-23-2015, 02:04 PM
  #144
Kelly Rohrbach
I watched your flight and it looked great, nailed the landing. Did you have to put in lots of up trim after take off.?
Old 08-23-2015, 02:25 PM
  #145
cyphur01
cyphur01's Avatar
yes I am sorry. 1/2" behind the mark. I kept creeping mine back and found the aft limit about 1" behind the mark. You will know when you are close. It will begin to get very "pitch happy" on approach ( not unmanageable) when you have gone too far.
Old 08-23-2015, 02:41 PM
  #146
jetpilot
My Feedback: (48)
jetpilot's Avatar
IM curious why this is on the Jetlegend website now:
The new JetLegend F16 1/6 PNP version available now!
No installation needed! superb performance!
only 5,999USD
Old 08-23-2015, 03:04 PM
  #147
Kelly Rohrbach
Is that balance flat and level or slightly nose down, thanks in advance!
Old 08-23-2015, 03:05 PM
  #148
kevinthoele
Scott
If you live outside the US That's the deal. Kind of stinks for us inside the good O US. Maybe you have businesses outside US and could ship there?
Old 08-23-2015, 03:15 PM
  #149
jetpilot
My Feedback: (48)
jetpilot's Avatar
Why is it priced in USD if its not for US? wouldn't Euros or pounds be more appropriate or are they just trying to piss off all the BVM customers?
Scott
Old 08-23-2015, 03:19 PM
  #150
jetpilot
My Feedback: (48)
jetpilot's Avatar
I will say these look very nice in person and the landing gear appear capable of lots of abuse as I witnessed about 50 of the hardest landings ive ever seen on about 10 different models this last weekend.
Lights are very visible!
Scott
RCFlyerDan (10-23-2021)
