new smaller (composite) Sebart Avanti XS
Old 09-06-2019, 04:27 PM
  #126
damagedgoodes
I’ve had 3 flights so far on mine and it’s such an easy flying jet with its light wing loading, it’s nice to have a lie stress model. I agree it would make an excellent trainer/first jet. I moved my fuel tank and turbine back a little however I’ll look at shifting the turbine back even further to get the tank on the CG as I don’t like the shift during flight. Rabbit VT90 KS in mine and it’s a great match. Over Christmas I’ll strip and glass and paint the wings/hori stab.
Old 09-16-2019, 11:07 AM
  #127
FlorianDo
Just a little feedback from my end after 7 flights:
Easier to land than my foam Avanti!
As this is my first yet, and I am not a very frequent flyer, I can confirm this is a perfect first jet for anybody that can put an ARF together.. with a few little tweaks and improvements (mainly servo mounts, which are a disaster in my opinion, and the glueing on the fuselage needs a little extra glue here and there..)
On maiden, i forgot my timer, ended up flying for 10 minutes, with 12 minutes turbine run time on a M100.. Thanks Carlos at CMjets for that little extra tank capacity :-).. Hopper was half full, tank completely empty :-D
Electron gear is perfect. For those that find the electron gear too soft in the main springs, (which I found) just ask electron for stiffer springs. They have three sizes available and i found the 1.8mm (medium) springs perfect, which are now mounted as standard in the Electron combo.
Looking forward to flying again next weekend!
Old 11-09-2019, 08:34 AM
  #128
RockiesGuy
RockiesGuy's Avatar
A little late with catching upon the thread, but I finally decided to get me one! I posted a -wanted- ad, but if anyone knows a modellbau willing to ship to the USA directly I'll be glad to know it...
My wanted ad is for a used one, here in the USA, any condition, but if stripped the better !
Old 11-09-2019, 08:49 AM
  #129
swk550
My Feedback: (76)
swk550's Avatar
I received my Avanti XS from Lindinger. It arrived to my house in Houston at approx three weeks. Shipping cost was low at approx $85. If you sign up you get periodic emails with specials. I was able to get a 10% discount while the red one was still in stock. This was the third shipment I received from Lindinger. I am very pleased with their service.
Old 11-09-2019, 08:40 PM
  #130
RockiesGuy
RockiesGuy's Avatar
swk550; I have had only nice experiences with modellbaus Lindinger and Schweighoffer...quick shipping, reasonable costs... I was trying Lindinger today and, although in stock, their system told they do not ship to my address...but I sent an email inquiring anyway...I had about 4 large boxes shipped from them (both) before...so I know is shippable....I found two possible used ones,,,but one I think is a scam...and one legit...also Sebart USA replied to my question...not bad, but still would like to save a bit of cash on a used one...I can fix anything wrong on any plane...(lucky me
Old 11-09-2019, 08:54 PM
  #131
Steve Collins
My Feedback: (8)
I got both my Avanti XS and my Mini Avanti from Lindinger.
Old 03-27-2020, 12:39 PM
  #132
gringotuerto
I've been slowly putting mine together recently. Beautiful kit!
Regarding the pushrods on ailerons and flaps - I don't see how this fits well. The hardware provided with the kit has long bolts and ball links on both the control surface end and the servo end. That entire ball link assembly has to remain clear of the servo slot (i.e, at full deflection, it cannot dip inside the wing, because the ball link assembly is much bigger than the width of the servo slot). So then you need a really long control arm on the servo. It doesn't help that the servo is sunk a few mm deep inside the wing, instead of being flush against the inner surface, which adds even more required length to the servo arm. And with such a long servo control arm, the travel would be way too much for the intended throws. It seems the only way to use the HW provided with the kit is the program low travel on the servo, which is always undesirable. I am thinking of using the provided ball links on the control surface side, but using something like a normal clevis on the servo side. Did anybody else run into this problem, or have a better solution?
Old 03-27-2020, 07:21 PM
  #133
Steve Collins
My Feedback: (8)
Mine only had ball links at the control surface end, the other end of the pushrod is a 90 degree bend that was fastened to the servo arm with a snap on keeper.
gringotuerto (05-10-2020)
Old 03-28-2020, 05:43 AM
  #134
Steve Collins
My Feedback: (8)
I also have been very pleased with Lindinger from Austria. I have ordered 2 jets from them so far. I found their shipping to be incredibly reasonable. Just remember, when looking at prices on their website, the prices include VAT tax which, for U.S. customers, is removed at checkout.
Old 05-10-2020, 07:15 AM
  #135
gringotuerto
I got mine from Neil at SebartUSA (sebartusa.com).
Anyway, I am just putting the finishing touches on this, and notice that the recommended CG in the manual is 23cm, which is a shade over 9inches. When I measure that out on the model (from leading edge where it joins to the fuse), it seems to me this is slightly behind where the main strut hits the fuse. It is approximately aligned with the aft edge of the main strut. With trailing link, the actual wheel axle is some distance aft of the strut, and so might be a tiny bit aft of the CG, which is what matters. But this seems to be cutting it very close. Did you guys balance somewhere between the main strut and the wheel axle?
Also I thought I would post my solution to the wing attachment. Like many others, I was not happy with the wood screw provided in the kit, because it seems the hole would wear out with many uses. I found these very small threaded inserts on Amazon:
(I tried to post the URL, but I get an error message saying I am not allowed to post a URL. OK, so let me just paste the Amazon item description:
"uxcell M3 x 4mm x 4.3mm Brass Knurled Threaded Round Insert Embedded Nuts 100PCS")
With the wings attached, I drilled m3 holes (pushing an m3 bolt into the first hole to ensure that the second one was aligned). When I was convinced I could shove an m3 bolt into both holes with the wing tube in place, I took it all apart. Then I took the wing tube over to my drill press, and put an m3 bit in the chuck, and put it through the hole in the wing tube, to position the tube. I clamped the wing tube in that position, so now the drill chuck was perfectly aligned with the m3 hole. Then I removed the m3 bit and inserted an m4 bit, and drilled about halfway into the wing tube. In this way I get a hole that is m3 for half the tube, and m4 for the other half, the two sections exactly aligned. Then I hardened the holes with CA. Then I took and m3 bolt with a washer, and used it to draw the insert into the m4 hole until it got stuck (i.e., until it encountered the m3 portion of the hole and couldn't sink any farther). So this way, I have an m3 hole with a metal insert, which I think should last a lot longer. And the insert should be pretty solidly in there - in other words, I can't over-tighten and pull out the insert when I'm attaching the wings. One note -- make sure you put the m4 counter-hole on the same side of the tube on both ends! Otherwise you will be sad. Also, make sure the wing tube is perfectly centered when you start drilling - there is not much extra length on each end. The m3 hole is very close to the end of the tube, on both ends.
Old 06-12-2020, 05:31 PM
  #136
A7Bldr
My Feedback: (40)
Did you fly your Avanti yet? I too am wondering about that CG location....it seems too far aft.
Jim
Old 06-12-2020, 11:54 PM
  #137
FlorianDo
CG per the book works well. With empty tank/full hopper it barely stands on its nose wheel. Per my recollection nothing more than one centimetre front of main gear. Flies on rails.
Old 06-14-2020, 01:06 PM
  #138
gringotuerto
I haven't flown yet, but might next weekend. I'm going to balance it a little forward of the manual, because I always do for first flights. Also my field is a little bumpy, and I don't want it to be flopping nose high at the slightest bump on takeoff. But I'll do an inverted CG check in the air, and assuming I get the plane back, make adjustments from there.
Old 06-20-2020, 06:05 AM
  #139
gringotuerto
Default Today Bert and Ernie might die a fiery death
If weather allows, I think they will fly today.
Old 06-27-2020, 05:31 PM
  #140
gringotuerto
Got rained out last week, but I finally flew today. All went well, it flies very easily. It does land faster than the Freewing foam Avanti of course!
Old 12-01-2020, 06:56 PM
  #141
Flying Fiz
I've been doing a long slow build of this jet over the last few months, I had a new Jets Munt 70MXBL to go in it but have now got the new Xicoy 95 on the way. I'm due to receive it the second week of December, and as its the same weight and size as the 70 it should be a great combo with this jet.
I have to say the build instructions are lacking in a few places, such as how the horizontal stabs are fixed in place, after looking at the various components and feeling inside the fuse to check that there was a blind nut taped in place I realized how it all went together. I just hope it all stays in place as once the exhaust tube is in place it may not be too easy to access. Speaking of which I'd prefer it if there was a hatch under the plane to assist with installation/access to turbine and tube. But overall a really beautiful plane and excellent finish.
gringotuerto (12-01-2020)
Old 12-02-2020, 12:54 PM
  #142
Flying Fiz
[QUOTE=gringotuerto;12614259]Got rained out last week, but I finally flew today. All went well, it flies very easily. It does land faster than the Freewing foam Avanti of course!
[/QUOTE Hey Gringotuerto Was your CG as per the manual? If it lands fast that is usually a sign of being a tad nose heavy, which is fine, but surprising given how far back the recommended CG is. Thanks in advance for your answer, BTW how did Bert & Ernie enjoy the ride?
Old 12-02-2020, 02:22 PM
  #143
gringotuerto
I was a little confused by the manual CG because it seems way too far back. It is essentially even with the struts, although because they are trailing link gear, it is still ahead of the wheel axel. Mine was near the manual CG, but probably just a touch forward of it - perhaps 7mm, which is very little on a plane of this size. Still, the thing rotates backwards around the mains a little too easily for my liking. Anyway, with this CG, it flew well, but landed with a visible up-elevator trim, probably about 2-3mm. So I take it to mean that it is still a bit nose heavy. Super stable and nice, though. I have only flown this beast 3 times now, and all flights were good. But I didn't yet invert it to check the CG in the air. Bert and Ernie didn't puke, but they look perpetually surprised.
Old 12-03-2020, 12:56 AM
  #144
Flying Fiz
Glad they didn't make a mess of the cockpit, and looking surprised has got to be a good thing. Thanks for the detailed response .
Old 01-29-2021, 10:37 PM
  #145
Springbok Flyer
Springbok Flyer's Avatar
Where did you guys buy the XS in Australia?
JanR
Old 02-15-2021, 07:43 AM
  #146
jvaliensi
Hi,
I love the Avanti and was thinking to get this model. I've talked to a fellow jet flyer that had two of the early ones. Both of his suffered catastrophic spar/wing failures. And I know he is a good flyer.
Has Sebart fixed this? Or has anyone else had these issues?
Old 02-16-2021, 06:59 AM
  #147
gringotuerto
Originally Posted by jvaliensi
Hi,
I haven't had any trouble, but I fly pretty gently. I hadn't heard of this being a problem in reading and watching videos about this plane, but there is limited material available because it isn't a super common plane. Anyway, most of the time a "good flyer" is much harder on an airframe than an intermediate pilot.
Old 02-16-2021, 10:12 AM
  #148
wfield0455
My Feedback: (7)
wfield0455's Avatar
Hi,
This is the first I've heard of this problem. The Avanti, at least the 2M Avanti S was supposedly designed to FAI style / precision aerobatics. If your friend is really into speed that may be the problem.
This is from the 2M Avanti S manual but since they are similar in design it may apply to the Avanti XS as well...
From the manual; "This plane is a compromise between aerobatics jet and 3D jet, it is NOT a pylon racer or speed jet and it is built with a very light structure and for this reason we hardly recommend:
→ Do NOT fly your airplane at to high speeds, because this may cause structural failures or flutter due to the extremely large control surfaces. The plane has been tested until 250 km/h, flying the plane over this speed is not recommendable"
Old 02-16-2021, 10:32 AM
  #149
Neil Guildford
Mines been good for 15hrs with a VT 80. I often do slow box loops.
Old 02-16-2021, 10:52 AM
  #150
jvaliensi
I wish my models would last 15min - 15hrs is amazing.
Neil Guildford (02-16-2021)
