Feibao Velox Arrives!
#127
RE: Feibao Velox Arrives!
ORIGINAL: Roger Suckling
John,
How does the wing section compare to the Phoenix? Could you possibly measure the thickness of the Velox?
Best Regards
Roger
John,
Best Regards
Roger
No idea how it compares to the Phoenix but the root chord incl flap is 490mm and the max thickness is 46mm at approx 150mm back from the L/E. Thickness at the false T/E (at the Flap L/E) is 20mm. No idea about section type.
Rgds,
Dick
#128
Thanks Dick,
The Phoenix at the same point ie 150mm from the LE is a bit thicker at 70mm. I was just trying to get a rough idea of the low speed characteristics.
Best Regards
Roger
Best Regards
Roger
#130
ORIGINAL: JustABigKid
John, could you post a couple of pictures of your engine and radio instalation? Where did you put the ECU and pump?
Hope it helps,
Cheers,
Dick
England
#131
Roger
Off to the WJM tomorrow! The Velox will fly very slowly, just as slow as the Phoenix, on the first flight I undershot the runway through flying too slow! I mounted my pump vetically on the former I made to hold the main tank in place with the hopper tank just in front of the main tank. Dick, I like your installation, very tidy!
John
John
#133
Nice clean instalation!
regards,
#135
CJ, that's a nice installation. I'd caution you on one thing though - the position of the fuel filter. You can unknowingly get air bubbles in it that can cause an engine out, and you will have difficulty shaking them out if you can't orient the filter upward. In flight you certainly will though.
Ask me how I know! [8D]
#136
ORIGINAL: Ron S
Has anybody else reading this had problems with horizontally mounted filters? Also, if you use Festo filters, just how have you managed to get them completely free of air??!!.
Cheers,
Dick
England
#137
This is a non-issue for the 6mm clear Festo filter. Yes, you can have (and see) an air bubble in it. No, it is not an issue. I have flown for years with these horizontal in the old Isobars with never an issue. I even tried, many times, purging the filter of fuel (so its all air), then running the turbine and specifically trying to get the filter air to dislodge and cause an issue. Could never get it to happen.
Don't know about the JetCat filter though. Since it's not clear, you can not know about an air bubble.
#138
ORIGINAL: Woketman
Thanks Mark, yes, I tried all sorts to get rid of the 'Festo' bubble with no luck (as have many other jet fliers I know). One to live with, I think...but has anybody had probs with the Jetcat filter and air bubbles (other than Ron, that is)?
Cheers,
Dick
England
#139
I have also used the JetCat filter for years and have never had an issue. But since it is not see-through, I really don't know if there's a big air bubble in there or not. But since I never had an issue with the Festo, I have not worried about it and also have never had an issue. But it might be prudent to mount it vertically, output up. I doubt it matters though.
#140
Velox flew OK today (full gen at http://jmajets.co.uk/forum/viewtopic.php?p=420#420) and here's a picture that Paul Lewis took for me...
Cheers,
Dick
Cheers,
Dick
#141
Dick
My fleet of jets have the filter fitted in every possible angle (depends where they fit in a loop of tube) never had a problem. Most people have problems with JetCat filters because they don't re tighten them a couple of days after assembling them. The O ring compresses in the first couple of days. I build my filters and place then in a clean bag when I start any jet build and re tighten before installation.
Dave W
Dave W
#142
ORIGINAL: Dave Wilshere
Dick
Dave W
Dick
Dave W
Dave,
I had a slight leak on one pipe to filter joint that I found on initial start-up but it was 'me-induced' (nerver tightened the union fully)...I've never had a JetCat filter leak. As a precaution against possible trapped air, I tipped the model on its side (filter then orientated vertically) and gave it a good shake...no problems with fuel flow...and it experienced all attitudes when I flew it and, again, no probs (tempting providence here!).
Cheers,
Dick
England
#143
My Feedback: (13)
What # Robart retracts work for the Velox? The #630's? Or any other brand retracts?
Thanks.
Also, if I JUST buy the frame only version, do I have to cut out the wheel wells and also the front wheel well for the retracts? (just like on the phoenix)
Thanks.
#144
IN
I just received my velox and I purchased my gear from Todd at Dreamworks. I'll be flying mainly off grass so I chose the pro-link gear. I'll post some pictures as I progress in the build process...
#146
NE
I'm flying one with a P80. It flies great but I dont think you could get 6-7 minutes unless you're real easy on the throttle. I start the timer when I throttle up for takeoff and I'm back on the ground in 5 minutes usually with enough for 1 go around. I'm trying to find a way to get some extra fuel on board.
#147
ORIGINAL: justinh
#148
My Feedback: (287)
MA
I flew mine with a P-80. Great combo...Unfortunately I tangled with a runway light. I was 12 inches off the ground...it was 16...oh well... I added an additional 24 ounces by moving the main tank over to the left and adding a 24 ounce sullivan tank. It gave me a good 9 minutes at wot with a couple minutes reserve. Stock tank most likely anly good for 5-6 mins tops....BTW I also used Robart 630 with struts from my Kangaroo. It all fit perfectly.....Great plane and combo...I already miis her...
#149
Thanks for the info guys. I am thinking about making this my first real jet. I flew the spinning whistle planes back in the 90's , and have been flying aerobatics primarily for the past 12 years or so. The price of this plane makes it very attractive, and it looks to be a fairly forgiving plane for the turbine newbies.
Question: I have seen the kit alone for as little as $720 (sincityjets), but every site I have been to also mentions saving "hundreds" with super combo deals, but they don't mention the price. Anyone have any idea what the price is for the plane/retract combo (the one with the retracts, wheels, brakes, air tank, valves, etc.)??? I don't want to email them until I am ready to order, and I know I won't be ready to order for a few months after I finish moving. But I would like to get a ballpark price so I know how much money to hide from the wife
#150
ORIGINAL: bodywerks
... and it looks to be a fairly forgiving plane for the turbine newbies.
Think +/- $900 additional to the base price for the add on combo's and you'd still need a real brake valve unless you use or like the on/off valve they give you. If you get the door option, you'll probably also need some sort of gear/door sequencer.
