OH
will running backwards harm a saito .72 4 stroke? mine did it for thefirst time the other day and now I am concerned it may have hurt something? It seems to run Ok, is it a problem or should Ijust fly it?
Chris
Chris
no damage![Big Grin](images/smilies/biggrin.gif)
ive had mine start backwards when trying to flip start it.....so now i just flip it backwards....
my 100 is going on hangar 9's new P-51 if it ever shows up......lol
My Feedback: (23)
ORIGINAL: Zoobear
Help!!!! Is the Saito 5 cylinder sirius a better Engine than the Saito 5 cylinder 325R series and what is the big differance Thanks Ron
The SAITO 3.25 is .25 cu. in. larger in displacement and the newest version has two glow plugs per cylinder.
Both are fine engines and I have one of each but I like the Saito radial better.
My Feedback: (14)
I owned a NIB Saito 3.25 R5 (bought new from Horizon) for a while, but eventually sold it because it used glow fuel. I just couldn't see having to clean up the model all of the time because of glow fuel. Gasoline/oil would have been enough to cause me to keep it and use it. I should have bought one of the RCS small 5 cylinder gas engines years ago when they were about $2750 a piece.
Ed Cregger
Ed Cregger
Has anyone seen a real users manual for the R170R3? All I've heard of are the crudely worded xerox copied ones like that with my engine. I'm just wondering if it exists.....well, and to get a copy too.
Does anyone need to join the club? I've had a lot of down time due to illness, so I haven't been able to keep up every day. Just reply here and I'll get on it.
ORIGINAL: jdkxtreme
I have not been able to find out what HP the saito 82 puts out..Any help?
http://saito-engines.info/specifications.html
The Horsepower ratings given out by manufacturers are meaningless and useless. They are usually at some unobtainable rpm with a prop that will not fly a plane. Manufacturers also exaggerate the ratings
If you are comparing engines browse through the rpm forum
If so, keep the info out of the forums. Any asking, offering, or actual selling in the forums is not allowed. You use PMs for it.
My Feedback: (23)
ORIGINAL: blw
OH
ORIGINAL: DougV
Hi Guys,
Would a Saito 125 be able to hover a Seagull (heavy airframe) Extra 260, 90-120 size frame?
Doug.
Hi Guys,
Doug.
http://www.horizonhobby.com/Products...ProdID=SEA5025
It probably could hover the plane if the weight was kept under 10 lbs. However, it wouldn't be crazy power. If you want that, I'd go bigger than a 125 on it.
Here is a link to some RCU ratings where people flew this plane with a Saito 125. One loved the 125, and one hated it on this plane. Go figure!
http://www.rcuniverse.com/product_gu...fm?kit_id=5520
According to the ratings, it looks like these planes tend to tip stall! Of course all Extras do, to some extent.
Hello again , i have another i forgot to ask an the saito 125 is it a comon problem for the intake tube oring to be blown out and fule to come out while it is running inverted , or is there a cure for it.
My Feedback: (10)
Hey ya guys,
Has no one spun a 3 blader on a Saito 180 before?? If I'm spinning a Master Airscrew Classic 18x6 2 blader really well.... would a 16x8 3 blade do just as well???
Cheers, Paul
Cheers, Paul
ORIGINAL: beaver180
Hey ya guys,
Cheers, Paul
Hey ya guys,
Cheers, Paul
TN
I had a nose over and broke the motor mount and the HSN valve bent. I need to replace it. How to I get the threaded part out of the carb?
My Feedback: (23)
ORIGINAL: w8ye
The 16 X 8 three blader should be the one to use?
ORIGINAL: beaver180
Hey ya guys,
Cheers, Paul
Hey ya guys,
Cheers, Paul
Location: West Moorings By the Sea, TRINIDAD AND TOBAGO
Well guys I have just won a saito 180 with a cracked/broken manifold on E bay. Price was good if it ends up working. It will be shipped to Miami then down to Trinidad. Do you think I should order the entire carburetor and Manifold or just the manifold with a carburetor kit and then see how bad it is when it arrives. Miami is two weeks away for any parts I need and so its a bit of a delay when ever we need anything down here.
Kevin
Kevin
