My Feedback: (221)
RE: Welcome to Club SAITO !
ORIGINAL: Old Fart
I agree with sigman,do you have any more audio?? it's inspired me to build my twin.
http://www.youtube.com/watch?v=-eemviDIr-M
Gary
My Feedback: (221)
ORIGINAL: RC Specialties
Ram,
I sure would like to hear your P-38 with a couple of TurboHeaders. Drop me an email and let's talk.
Jim
Ram,
Jim
Hi All,
I flew my Spitfire MkII powered with a Saito 115. It's very good engine !!! Take a look on this video:
http://www.youtube.com/watch?v=LeyzSASSyog
Good flies,
Thiago
Good flies,
Thiago
My Feedback: (29)
I was in the hobby pretty hard up until 3 years ago, found out we were going to have our first child. I am now looking to get back into it. I have owned 2 .40gk, a .65, 3 1.00, and a 1.5. All were fantastic, except for the .65[&o]. One of the 1.00 was in a great planes little toni, and man did that sound awesome at full tilt in the air making a 100mph pass
AR
Hey all,
I always wanted to own a Saito when I first entered the hobby, but with kids and all that comes with that, I just couldn't seem to pull the trigger and buy one. Kids are grown now and it's time. All I know about them is what I've read here and in the "broken english" manuals. I believe there's more info to be had here. What I know for sure is that I like being around "Saito people". Got room for another Saito Club member??_
Now this is not as good sounding as the P-38 with the twin 100's. But its not to bad. http://www.youtube.com/watch?v=99JUwz97kp8
Its sort of a dull flight, but it was the first time it flew. Thats when I found out how quiet it is. Love the BIG Saitos!
Hello Saito-ites,
Not only have I never owned a Saito, I have never even owned a 4-stroke motor! (I have 2-strokes and gassers.) So that is why I am clueless about how to solve my problem.
I have designed the 1910 Glenn Curtiss Hudson flier for a full scale replica project underway at the Glenn Curtiss Museum in Hammondsport, NY. They don't have an engine problem. They are using an original OX5 to power the replica. (The museum intends to re-enact the Hudson Flier's flight from Albany to New York on the 100th anniversary next May.)
I am building a 1/4 scale R/C version and am having a tough time finding the right engine. Even for a 1/4 scale plane with an eight foot wingspan (and two wings), the plane is very light. The CAD program is telling me the weight is 5-1/2 pounds. That is without the covering, motor, or rigging. Leaving out the motor, the plane should still weigh less than 8 pounds. I think that a 60 would be fine expect that this plane has a lot of drag. For this reason I would feel more comfortable with a 90. I could always use a lighter pitched prop.
I am concerned about vibration. I originally thought about using an RCV90 but it has a significant torque pulse that could be a problem. A multi-cylinder engine would be the best. That leaves few choices. The Laser V-twins are too big. Saito is the only manufacturer that I know of that makes a 60 or a 90 twin.
So that's why I'm here.
A friend lent me a 90T and I have been modeling it. The needle valves are not in yet but as you can see in the picture, the side mounted carb rests right up against the engine rail. I will have to make some modifications to accommodate this motor, including a hole in the rail for the needle valve to pass through. Not a pleasant thought.
In looking on the Saito website, the 90TS looks different. It looks as if the carb is mounted in the back. That would be good for this project. Also, in reading, it seems that some of the Saito engines run with the pistons in phase (in the same direction at the same time) and others run out of phase (away from each other or toward each other). The latter is what I would prefer. That would have far less vibration.
Any information about these engines would be greatly appreciated.
(If you are interested, there is a build thread on this plane in the scale section.)
Cheers.
Cheers.
My Feedback: (19)
ORIGINAL: flyrc78
Hmmmm....is that you, Monty?
BTW, Thanks, BLW!! 641! I'm gonna have to get that in my signature too.
Jim
ORIGINAL: kevinkenny
If the low speed jet is not correctly set is there a place you start from. For instance the high speed jet we all start from three full turns and then start closing down until we get the max RPM then open it up a bit to make sure it is not too lean. What is the procedure with how we should approach adjusting the low speed jet.
Kevin
Kevin
Banned
we make and sell DA100 standard mufflers,I have a link for some canister mufflers and mufflers of the aircraft engines,welcome to visit:http://jakyying.diytrade.com
you can contact with me by msn:[email protected]
skype:jakyying1
skype:jakyying1
ORIGINAL: jeffEE
My Feedback: (19)
Whuh??
I thought I was in club Saito....What's going on here?
BLATANT sales slamming going on here. It has nothing to do with the thread.
Mods, this tree needs a little trimming.
Jim
Jim
My Feedback: (10)
You'd be more use to mountain oysters back home aye OF? How ya bin?
See if you can guess where this is taken...
http://www.youtube.com/watch?v=wEyzz-ftdAI
Cheers, Paul
PS Couldn't figure out just how to turn up a prop on my lathe, so I guess I'll just have to try a 16x8 3 blader from Master Airscrews
Cheers, Paul
Pretty good mate,flying much?
For our american friends and others not familiar with the term 'mountain oysters' it refers to the process of fitting a small rubber ring around a lambs nearest and dearest.They shrivel up and drop off a few days later to lie scattered around the paddock,hence the term mountain oysters.
Nice touch and go,the weather looks brilliant.Can't guess where that is but looks like the port hills in the background,would love to fly against those again.
Cheers
peter
ps i meant you could have a go at hand carving one...i've got a spare peice of aussie hardwood you could try
Cheers
peter
LA
'mountain oysters'...
...are well known here in the USA. Generally referring to bovine testicles though. Considered a haute cuisine by some.
Terry in LP
Terry in LP
ORIGINAL: anuthabubba
Terry in LP
Terry in LP
Whoowee mikckicken you can sure come up with the goods.A for real testicle festival? well do they have a plastic surgeon tucked away in a side booth like they have at the markets here?.If so i thought about quickly whipping in there to have a reduction but reality soon struck..i hav'nt got enough scrotum to start my 220 yet and i'm about to fire the new 115 up in my midget mustang
cheers mate
ps i can't believe field and stream magazine would stoop so low as to associate their name with this type of pornographic skull-duggery..sniff!
cheers mate
My Feedback: (221)
Hummmmmmm, sounds like a good term for the Saito muffler, if not installed properly. If not installed at operating temp with a drop of light oil, they are prone to 'turn dark and fall off'.
ORIGINAL: ram3500-RCU
How did I do getting back to Saito?
