Official Tamiya TT-01 Thread
#1502
Rare what would u recommend then. remembering its a TT-01 with ali prop,ballraced but standard acoms servo and tamiya speed controller.I only really wanna a bit more speed not loads i dont wanna install a motor that will destroy my esc or gears lol thanks for your help and soz for the noob questions just rather ask before buying anything and destroying my tt01 lol
I can go up to 50 pounds if needed but not wrecking the car is main concern really []
i read somewhere you can go to 19T before any problems occur is that right or bad advice??
thanks [8D]
thanks [8D]
#1503
My friend recommend this as if cheap and will add a few mphs more anyone use this motor...
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXHUJ1&P=C]venom fireball 19t[/link]
#1505
my advice is, shop around for whatever parts you get, often abroad is the best bet (for small bits) that aint gonna cost loads to ship. i have about 8 websites i check to see which is cheapest! i love a good deal!
#1508
ORIGINAL: Rare
*cough*overkill*cough*
ORIGINAL: rcluke
check out www.modelsport.co.uk
for £50 you do not want a tamiya motor, you could get a 7X1 motor
#1514
Running macthed packs the Sports tuned has more than enough power to spin the wheels until top speed, of around 30mph geared right.
#1516
ORIGINAL: minit_racer
is that a good motor for drifting cause i plan on doing that.
it is a direct replacement for the HPI drift car
#1519
ORIGINAL: lee172
does the same gear ratio apply if i am going for good exceleration, but not drifting??
#1520
ola guys im back again after a looonnnggggg absince.
update and thoughts, broke a front upright this weekend (still dont know how) so tip[s for the new guys, when you buy a adjustable upper arm set and you get those copper bal screw things, do NOT attach them to the botton front uprights. they scratch and brake the upright. unless you race on perfect track.
also everyone, do yourself the favour of getting GPM's alloy parts for the tt01, the are not expensive, but damn they are as light if not lighter than the standard plastic parts easier to install and i whole lot stronger, i got the alloy front uprights on right now in red and they also look awesome. will be installing ALL the gpm parts in the next few weeks.
I just became the distributor/importer of gpm into south africa and i must say i am impressed with the parts.
Also if you wanna spoil yourself and your esc hadles it, get a Lrp Gt3 17t double motor, this thing rocks!! it is just so fast, i went from the 19t to 17t this weekend and damn the difference is amazing.
guys now a question: I geared the car at 23/58 and it just flew (acceleration and topspeed), then stripped the gear with a stone (damn parking lot rocks!!), now i installed 25/55 which should give me a damn fast top speed, but i aint getting it!!, what could be wrong, any ideas?
#1522
cool i thought is was overgeared, but expected a bit more. first havta go and buy new 58 and 23, those are f&^%$ed
#1524
the tt01 tub strips screw holes very easily and i was using thread locker, so i didnt know it could lift (the cover that is), it lifted and bang, now ive cable tied it tight on there
