My Feedback: (221)
RE: Welcome to Club SAITO !
ORIGINAL: AircamperAce
Thx Blw.
All,
Need advice mounting a new 4 stroke.... I am re-powering my GP Super Sportster 40 with a Saito 56. I am using the stock GP universal black plastic motor mount, and tapping 4-40 holes in it per the ARFs instructions, is this adequate or do I need longer screws and nylon lock nuts? I had several flights on it with an OS 46fx mounted this way. I always expected to find it loose after a flight but never did, it seemed ok.
Thanks, Ryan
Thx Blw.
All,
Thanks, Ryan
My Feedback: (221)
ORIGINAL: GaGeeBees
This wasn't a Saito or Graupner incident but thought I'd show an example of what can happen when you throw a prop blade. This happened on the takeoff run at full throttle just as I was ready to feed it some elevator. G-38 with 20x8 Master Airscrew Classic.
My Feedback: (221)
Saito 100s all cowled in with the Turbo Headers installed. They are compact and are nice for these narrow war bird cowls. This is the third change to these cowls and hopefully the last. I had to glass the vents back in this time.
Hi So I have been using Cool Power 4 stroke 15% nitro, synthetic blend/ bit of castor mix as it really was my best option at the time. I now have the opportunity to purchase some YS 20/20 blend as the LHS is now stocking it. Of course its more $$$ but is it worth it. A couple of things the engines run great now but I have to admit the castor staining is pretty annoying but I would rather have them run well then looks. Would a bump in 5% nitro really be noticeable? Any comments would be appreciated.. Thanks
And of course I forgot my main question if I switch from a fuel with castor to non at all is this an issue. Can you switch back and forth like that??
ORIGINAL: Slats!
Thanks, Ryan
Thanks, Ryan
Mounting them as W8YE says is a foolproof method.
MI
IMHO - I’ve had excellent results with the composite mounts with my Saitos. I drill, tap and use a lock washer and washer with no Loctite as I understand it may eat at the material. I’m always weight conscientious and of course an aluminum mount will offer a more ridged platform, better piece of mind and higher weight.
Hey guys, just found this thread. I'm rebuilding a Saito 150 some one gave me. So far, just a new carb and bearings and an overall clean up. I've got a question. I want to remove the piston wrist pin but it ain't budging. Are these pressed in or is the thing just need a good soaking in some solvent to loosin it up a bit?
Location: West Moorings By the Sea, TRINIDAD AND TOBAGO
If you look at the parts list you will see the pin has no threads which would indicate that it is just pushed it. Try to heat the piston and then try knocking it out. I am also over haling a Saito 180 so would be very interested in your experience. I have prepared a Power Point presentation about the job and would be happy to send it to you of you give me your e mail address. Feel free to comment on it. I plan making it available to any one that is interested. I did not take the piston apart so do not have that covered in my presentation. I will be happy to include your experience. It has to be sent in a few parts because I used high qualified photographs.
Kevin
Kevin
ORIGINAL: Chancho
I don't know about 'eating' the material, but certain adhesives will set up stresses in plastics and should be watched for... I don't know if the Loctite/composite mount combination will cause the plastics to craze, but it could be an issue down the road. If it happens, it will probably happen over a period of time, not immediately.
Just my $.02
Bob
The black plastic motor mounts like the Great Planes will hold even a sheet metal screw without it backing out. No lock washers or anything.
But a sheet metal screw is too soft for something like a Saito 56
Don't try a sheet metal screw into wood mounts. It will back out faster than you can shut the engine down.
MI
I'm with you Bob,
I had to read up what crazed meant, i.e, cracking and your right, it can craze or gum over time, but works. It doesn't matter how many times I mount a motor, it's an art and I think I am getting better everytime. I also believe all the airplane crashing I've done over the years has made me better at it.
Phil
Phil
My Feedback: (221)
ORIGINAL: blw
I've used the 6/32 tapping screws on these mounts on all of my models. I had a model that had a case of chronic elevator flutter, and it went down at something like 80 mph. I was using the GP mount with an Evolution .46NT. It hit pretty much on the side of the spinner on hard ground and destroyed the model. This was almost a straight down attitude. The mount survived intact with a couple of bent 6/32 screws as the only damage. I was impressed by the strength of the mount.
Thanks, Ryan
Thanks, Ryan
I got a call from Horzion today on my 270 I sent in That couldn't be repaied. They suggested the evo. 40 for my Stinson. So we made a trade with some extra cash from me. But I was happy to get an engine I can count on.
My Feedback: (45)
AZ
Hey guys, im sure this has been covered but im tryirg to find the power diference between the saito 125 and the 115. I have a 115 and love it but not sure if it will power my next project.
thanks....mike
thanks....mike
The main difference between the two engine is the external size.
The 115 has the same mounting footprint as the Saito 65, 80, 91, OS/Magnum 70.
The 125 has the same footprint as the Saito 100, OS/Magnum 91, Y-S 91,110, & 115
There is one prop size difference in power between a 115 and a 125.
The 115 is essentially a Saito 91 with a 125 cylinder on it.
My Feedback: (45)
AZ
Thanks W8YE, I forgot about the smaller foot print thing. I think ill go with the 125 based on that alone. The plane was setup for a 100 so i dont want to move the mounts for the 115
thanks again.....mike
My Feedback: (23)
ORIGINAL: SU-31 flyer
Hi Guys,
I am hoping you can help me again,
My newer Saito 115 was involved in a minor impact and one of the push rod tubes (and the push rod I assume) is bent significantly.
Are they easy to replace? Would rather do it myself instead of sending it in.
Can anyone tell me the procedure and what I need to aware of?
I am thinking I would need to replace the valve cover gaskets and the lower push rod cover plate gasket as well. Correct?
Ken
Ken
No need to touch the cam housing, put the piston at TDC to relax valve springs, remove rocker cover, remove four bolts that hold the cylinder down. They will be unbelievably tight, pull cylinder upward about .25 inch, do the work and re-assemble. I like to cut an Allen wrench down to remove the cylinder bolts. Again do not remove the cam housing as I did here.
PS, there is no base gasket and not need to replace the rocker cover gaskets.
Unless you ensure that the crank and/or cam gear has not and will not move during the dissembly process, You will need to time the cam gear with the piston at TDC. Someone else can help you there as the procedure varies with the engine size. If you, and you might, need to remove the cam housing, make sure that the gasket is in place between the cam housing and the crankcase, as this sets the clearances between the gears of the crank and the cam. Unless the gasket is damaged there is no need to replace that gasket as it is not under any pressure (since the crankcase is vented). For the 180 I have, it was necessary to grind down the supplied hex wrench to allow it to be fully seated in the cylinder hold down bolts. Otherwise you risk damagiing the internal hex of those bolts.
