OFFICIAL HPI Sprint 2 Thread (Sport and Flux)
#1627
RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux)
ORIGINAL: drc35ca
Do you have pictures of the steering setup?? looks cool,never seen this done before?
The steering mech that was at the front has now moved next to the motor. I would recommend this on the opposite side to your pinion and far enough away so you can get the correct amount of lock. I shaved the arm down a little. I would recommend countersinking the newly made holes from underneath otherwise they will scrape and catch
Since the old steering setup has to go, I used two rod ends for the hubs and then a rod to go between them. I am going to make an adjustable one soon but for now this one is fixed so needed to be 110% accurate as toe adjustments are not going to be possible. The rod shouldn't be too thick otherwise it will hit the front frame so I would say anything thicker would not be a good idea.
After going brushless, just needed to swap the steering setup to the opposite side
I have documented nealy my entire build on Flickr (apologies of ext links are not allowed but with over 100 photos, sharing them all would be a bit of a pain). Any questions, please ask away -<a href="http://www.flickr.com/photos/31584547@N05/sets/72157632777509500/with/8708773002/">http://www.flickr.com/photos/3158454...th/8708773002/
</a>
#1628
IL
ORIGINAL: trencha
thanks for help, will upgrade them, what ya think about this chassis? http://www.radshapercshop.com/hpi-sp...-prod-480.html
I like it a lot =
Plants the car
Haven't traction rolled yet
#1629
Hello everyone! Im a new guy here just getting back into the hobby after a LONG break. Just picked up a new HPI Sprint sport 2 Vaughn Gitten mustang. Planning some upgrades pretty quickly ( brushless etc).
Had a quick first question... Im new to the drift world ( ex on road racer...pan cars in the 90s) does anyone know what offset wheels come with the mustang? Im looking at getting a couple different sets but want to stay inside the body. Im thinking they are 3mm and 6mm.
Thanks for the help! Im super excited to get back after this stuff!!
#1633
The way I do it is by my radio (transmitter) but I have a spectrum. The other way to do it is by speed controller but you will need the castle creations program.
#1635
Hey rc maniacs! Thats my problem i got this car for about 2-3 weeks now, and first problem was that pinion gear wasnt screwd well so it come out and the grub scre got broken... So i replaced it with the new one. Went outside for the test drive , after 10 min the squeaking voice started to be louder and louder when i was accelerating. Its annoying its sound like 50 nails scratching a blackboard!!! Plus i dont want to break my engine if the problem is with engine... I checkecked the pinion gear and its all fine so what can that be?!!!! Really need some help to sort it out ad the nie weather coming out and i want to drive it lol. I prepared a short movie to make it easy for u guys to tell me what can that be
Please help me
[youtube] http://youtu.be/cMR21DJzh7A[/youtube] Hide Signatures
Please help me
#1637
ORIGINAL: Taniv
Please help me
Please help me
You can move the pinion gear by loosening up the motor screws. Give screws on spur gear and center shaft (pulleys) a check also, just in case.
#1638
Yes I have checked the pinion gear it was the problem, i make it more tighter but the problem is this pinion gear have kind of shorter (spikes?) they don't fit well to the spikes in the black wheel. so I had to make it more closer. it works fine now, but it may get looser after a time... will the thread locker help resolve the problem of the grub screw getting looser? </p>
</p>
thanks for quick answer </p>
#1639
Hi Guys<div>Just spent the last 3 days reading this forum as I have just purchased a Sprint 2 Flux (911 GT3). Thisis my first real R/C. I have an R31 Wagon body that I am painting to go on it. I have already crashed it a couple of times and broken the right side c-hub. Alloy on order (full alloy kit). I am running it with a 2cell LiPo, and it just flies. There is a bit of slop in the steering and it is a little unpredictable. look forward to getting into the nitty gritty of this chassis.</div><div></div><div>Thanks to all previous contributors as this forum is very informative.
*Edit*
Have since put the chassis on a good quality setup rig. Now have camber, toe and caster set correctly front and rear. Handles alot better but still needs some slop removed. Trying to find a suitable spring to mount into the steering to tie it together a bit better. Any suggestions?</div>
*Edit*
#1640
Hey new to the forum, I have a sport 2 flux camaro all stock. I run it
in front of my house which is concrete with expansion gaps. The gaps are fairly smooth and I'm running the stock tires and it still will
spin out. I'm running a 2s lipo and need suggestions on getting it to stay planted. I know my surface isn't the best but thinking maybe tires,
or softer suspension maybe might help. What do you think?
I used to run a nitro tc3 on my street with an occasional spin out, and I'm thinking the tires were similar.
#1641
will this work for rear belt tensioner?
http://www3.towerhobbies.com/cgi-bin...XDBYA&P=SM
#1642
Welcome rcjohnny.
I have the sprint flux 2 and had a bit of problem with unpredictable steering on my car when I was on track. Car would pull one way on power and the other way under braking.
I fixed this with a little help from one of my friends using his setup gear. We set the toe on the front to 2 degrees toe out which helped alot and also checked all the other adjustments to make sure they matched left to right.
There are a few mods that are suggested for the sprint 2 to improve the handling which revolves around removing the slop in the steering.
If you haven't done so already check out GPM Racing as they have a great range of hop up parts for the Sprint 2 that are available in a range of different colours. Just email them to find out what they can do. I just got a full order from them in orange which looks great see this pic.<a href="https://plus.google.com/u/1/photos?pid=5903427992202512386&oid=10651943675 6166459804">https://plus.google.com/u/1/photos?p...36756166459804
<br type="_moz" /></a><br type="_moz" />
#1643
Thanks MrJudd77,
I didn't even think about setting the toe, been about 6yrs since I ran my TC3 heavy duty. That's alot of aluminum on there, I'll have to wait on hop-ups right now. I've been unemployed for a season.
Do you have a pic of your body on the car. A man with that much alum under the hood has got to have a sharp body ! Thanks again, I'll give you an update on those adjustments.
#1644
Made adjustments on front steering, did help. But I think biggest problem is a 2c 4500 lipo. It steers so quick, I have stock hpi radio and is there a way to slow down the steering.
I've been in rc for 15+ yrs so I got a few skills. Seems like this camaro wasn't meant to drag without dropping some $ in it. I started drifting it so maybe that will be my goal for now.
#1645
Unfortunately there is no way to tune the dual, rates with the stock radio. You could try playing around with the end points.
The body on my car is the stock 911 Porsche. I do have another shell that I need to get painted up. It is a Nissan R31 Skyline Wagon (It will be painted to match my actual 1:1 car) I have attached a pic of my car to give you an idea.
Good to hear the toe settings helped. I run a 2s 4750 30c LiPo and it does make the car respond quickly. Most of the problems with the car (and there are not that many) are to do with the steering slop and the lack of dual rates in the stock radio. I am looking to raplace mine soon, I think I will end up with one of the ebay ones like thishttp://www.ebay.com.au/itm/221225763...84.m1423.l2649<br type="_moz" />
#1646
Okay so to make it more simple i will write a couple bullet points, so all can see what i would like to help.
1 - How to do the tighter rear belt? what does it give? and why so many people do it?
2- There is no video how to put all the parts after i took them off im scared im gonna break something, of replacing rear belt any advice on that?
#1649
ORIGINAL: Taniv
The belt tensioner is there to keep the belt tight when you use it. After repeated use the belt stretches and you will need to adjust the tension further and further until you will need to replace it.
The belt tensioner mod that people have done before is mainly for the older style Sprint 2 that had the purple alloy bits in it. It had a different top plate and path that the belt ran along. This path would make the belt rub on the top front corner of the battery so some clever cookie came up with a simple mod to lift the belt clear of the battery. The newer Sprint 2 with the orange bits does not need this mod as the top plate has been changed which allows the belt to clear the battery.
The other mods that are no longer required are the cut out of the rear section and the extra holes in the bottom plate as these have been done as a factory redesign.
Hope that helps a little. Welcome to the world of Sprint 2 and just have a go you are not likely to break it, use a little common sense and don't force anything together. Also remember to add a little lock tight to any screws that go into metal and check all other screws are tight after each run.
<br type="_moz" />
#1650
Open up link below, go to page 20 on down to see parts lay out.
It will start downloading the manual.
http://www.hpiracing.com/assets/manuals/pdf/108765.pdf
