RE: Welcome to Club SAITO !
ORIGINAL: longjohnplz
Hello,
I am new to the whole internet communicating so forgive me if i miss any ediquets. I have a very old saito .91. The berrings blew up in flight and i cant seem to get the front berring cover off. Someone sugested soaking my beloved saito in anti-freeze. Is this a good idea?
Thanks.
Bring back the long jon
Hello,
Thanks.
Do you mean the thrust washer?
W8ye is correct with the puller but I found the ones I purchased didn't have thin enough legs to fit into the prop driver groove. I solved this by purchasing a Toledo Bearing Separator (part no 245040). When combined with the puller this will remove your prop drivers in a matter of seconds, which is about one million times shorter than the time I wasted trying to get it off using differing methods.
The great thing is that the combination of a gear puller and the bearing separator will now suit just about any other engine I'll ever run across.
[link=http://www.tridon.com.au/Products/Product.aspx?SG=5&S=23&G=60511&P=68723]Toledo Part 245040[/link]
http://www.harborfreight.com/cpi/cta...temnumber=7343
$3.27
<span id="xf_photourl"></span>
http://www.harborfreight.com/cpi/cta...temnumber=8832
$19.99
$3.27
$19.99
ORIGINAL: w8ye
$3.27
<span id=''xf_photourl''></span>
$19.99
$3.27
$19.99
Once again, I cannot reinforce how easy these types of tools made the job. I struggled for over a week before purchasing the tools. Within 5 minutes of getting home with them I had several saito 45s apart...
BTW I'm still 'rebuilding' the Saito 45s. The 45 Sport is running again BUT a tad overpowered for my Eindecker. The older 45 still needs a carb bracket.
Location: West Moorings By the Sea, TRINIDAD AND TOBAGO
<a href="http://www.authorstream.com/presentation/KevinKenny-259310-repairing-saito-91s-radio-control-engines-reseating-valve-91-sports-ppt-powerpoint/">http://www.authorstream.com/presenta...pt-powerpoint/
How to service your Saito 91<br type="_moz" /></a>
Is it normal for a saito .82 to making lot of clicking/snapping noise when shaking the prop hub back and forth in certain "free of compression" parts of the stroke? I havent ran it in a while and it sounds like its filled with loose bearings!
Thanks 871
Thanks 871
ORIGINAL: w8ye
The click is normal
The click is normal
My Feedback: (90)
I rarely wander from the Warbirds forum, but visited this forum for the 1st time because I was looking for info on my recently aquired Saito 300 twin (single carb/ single plug per cyl version). That engine will be used to power my Byron Corsair (yet to be built).
So, count me in, if I am just now joining, my Saito Club membership number must be higher than my AMA number.
However, this is not my 1st Saito engine: that would be a Saito .50 I bought about 15 years ago to power my DynaFlite Corsair (my 1st warbird).
To provide an inventory of current Saitos that I have, and/ or have owned in the past would be too time consuming. I'm sure there are many out there who have owned more than I, but all I can say is: I've owned my share, and loved every one of them.
I tried YS a couple of times: they are without a doubt more powerful for thier size, but I found them a little more challenging to get dialed in and keep them dialed in, so I went back to Saito.
Mian reasons I chose them over O.S.: power to weight ratio AND looks. OS has finally been catching up with Saito in the power to weight ratings, but Saito has NEVER LET ME DOWN, so I just keep buying and using them.
Pic is of my Top Flite P-47 ARF with Saito 100GK: note how well it blends in with the dummy radial (Saito is inverted):
That's a great looking setup... so the bottom pair of tubes are the actual Saito head?
One of the guys at our field had a 300 twin (I think it was the Saito) on a Sundowner... amazing sound and power from that motor. Good luck with it!
My Feedback: (90)
ORIGINAL: reyn3545
.........That's a great looking setup... so the bottom pair of tubes are the actual Saito head? .............
I did a simular thing with a Top Flite Corsair a few years back, this time a Saito .72 GK (before the .82s were introduced). Note how the GK valve covers blend with the yellow cowl ring:
Very nice.
Here's a picture of my 450 in the Waco I'm finishing now... not the most "scale" motor on the planet, but it should be fun to fly.
My Feedback: (22)
Ihave a Saito 72 and running 15% Cool Power with a Master Screw 13x6 prop.and Icant getbut around9000 RPMS out of it.The engine idles fine around 2000 RPM'sbut will only doaround 9000 RPM'swith full throttle.Ichecked to make sure that the carb. is opening all the way. LIke Isaid....idles fine, runs fineand transitions fine but will not max. out on the top end. What do Ineed to do to get the recommended 12000 RPM's that Saito recommends.
First of all it is never going to run 12,000 rpm with a 13 X 6
They run close to 10,000 with a APC 13 X 6
Check your valve clearance
Check your intake manifold for a vacuum leak
Check your valve timing
My Feedback: (23)
Some Saito engine & dummy radial installations. The Monocoupe and Beech Staggerwing are 1.70 radials; the Gee Bee has a Saito 1.20.
Santa left something under the tree for my wife???!!!? Merry Christmas to all of you from Kevin in Trinidad & Tobago.
ORIGINAL: dspadler
I have a Saito 72 and running 15% Cool Power with a Master Screw 13x6 prop. and I cant get but around 9000 RPMS out of it. The engine idles fine around 2000 RPM's but will only do around 9000 RPM's with full throttle. I checked to make sure that the carb. is opening all the way. LIke I said....idles fine, runs fine and transitions fine but will not max. out on the top end. What do I need to do to get the recommended 12000 RPM's that Saito recommends.
The velocity stack helps this engine.
Merry Christmas everyone!
How about a trivia question? I willoffer a free TurboHeader of your choice to the first post with a correct answer to the following questions:
Moderators excluded, please.
1. Who patented the first four stroke engine and what year?
2. Who built the first operable four stroke engine and what was it called?
You must be specific and complete in your answers and quote your source.
I ask that a moderator validate the answers.
Jim
Jim
The four-stroke engine was first patented by Eugenio Barsanti and Felice Matteucci in 1854, followed by a first prototype in 1860.
Hardenberg, Horst O., The Middle Ages of the Internal combustion Engine, Society of Automotive Engineers (SAE), 1999
http://en.wikipedia.org/wiki/Four-stroke_engine
http://www.speedace.info/internal_combustion_engine.htm
a few years ago, this would have been quite a different research task.
The internet has changed the world
