RE: Welcome to Club SAITO !
FNQ, there is a contributor on here by the name of Dar Zeelon from Israel who has few left in his stock. Shoot him a PM and he'll gladly tell you what he has left.
Thanks, I'll try to catch up with him, but not now I've spent to much time here trying to find a good scale model kit , ARF or build (bi plane preferably) around 80 to 100 inch and not doing the thingsthat have to be done to keep body and soul together
Catch ya later
Catch ya later
Thank you,
I went to BOCA bearings yesterday and bought new bearings. I bought the standard bearings set for the saito not the high temp version. I put the bearings in the freezer and heated the engine block to 325. Both bearings went in smoothly. The first set of bearings were pressed in. I'll try running the engine tomorrow. Have you ever heard of a bad crank (out of balance) comming from Horizon? I hate to have to send the engine in Horizon. Someone from Horizon told me it could be the spray bar and high speed needle, doesn't sound logical to me. I've never removed either.
Glenn
Glenn
ORIGINAL: Hobbsy
Kostas, let us know how it runs, Thanks
Hobbsy i will !
Let me ask,
should i use as fuel CoolPower 20% N or i can just buy a gallon of 15% N ?
The 20%N fuel costs 30euros which is arround 40-42$ :P
IA
I own a Saito .82 Fa that is mounted in a stick built, and bashed, SIG Kadet Senior. The Saito has only been run on the bench. After checking , and resetting the valves according to the manual, it seems to run very well.
I see tons of information in this thread, and I'm looking forward to reading more.
Hope to maiden the plane and engine sometime this week.
Art
AMA 915882
AA0BL
Art
AMA 915882
AA0BL
Kostas- that is good advice about Omega 15% fuel. It has a small percentage of castor. I bought a quart of castor and add a couple of ounces to each jug.
ORIGINAL: rcair08
Art
AMA 915882
AA0BL
Art
AMA 915882
AA0BL
WV
Sorry, I must stray from the topic of this thread. I all ways wanted to say something to the pope. So here goes, darn I can't say that here, well O.K. just Hi then.
Sorry, off topic only slightly, but Kostas1, how did you get your photos to go in there large, unlike most photos that you click on and then they get just slightly larger???????
Ernie
Ernie
ORIGINAL: blw
[] unfortunately i don't have access to other fuel except CoolPower...but the oil content (......only fully synthetic though) is 17%....
Engine installed.....see the mount of burnt castor arround the muffler ???[:'(]
Is there any way to clean it up? Alcohol didn't work of course....
0
0
Why do you guys use so little oil in your modern Saitos, my 56, 62 and 82 call for a minimum of 20% oil.
Running them in Old Timer models with less (especially in competition) results in at least new bearings after a few competitions mostly due to overheating and remember duration engine run times here are 30 seconds and Texaco average out at about 5 minutes
The best line of defense is to get the muffler clean and then seal every possible joint to keep it clean. Use teflon tape on the threads on both ends. Take the muffler apart and reassemble it with a dab of high temp silicone around the little nut in the front too. You want the exhaust coming out the back of the muffler but nowhere else. Keep the vent tube from getting on the hot muffler also.
You can soak everything in a crock pot full of antifreeze overnight to really clean it up. A quicker way on the outside of the muffler is to use a wire wheel on the bench grinder. Be sure and buy a wheel with soft wire though. They come both ways and the soft variety doesn't scratch the aluminum, just cleans it up, and the you can polish it with the buffing wheel if you want to but the soft wire does a nice job.
Ernie
Ernie
Try oven cleaner (the foaming type) but don't leave it on for more than a minute or so (will chew up the Alumimium) looks like it will need several applications. Scrub with an old tooth brush and wash off with water. Don't forget to strip the engine first. Works on most engines.
I have found this sort of residue is due to to much castor and not enough lubricating oil in the mix causing overheating over time
I'm going to try and do the bearing replacement for saito 82 myself.
Can anyone provide the type,front and rear bearing size, so i can order today thanks.
Cheers
Cheers
ORIGINAL: mk1spitfire
Cheers
Cheers
ORIGINAL: The Raven
Try [link=http://www.rc-bearings.com]RC Bearings[/link] I've always found them to be quick to deliver half way around the world and I've yet to find bearings locally cheaper. Best bet is you just order bearings to suit your engines, no messing around with dimensions and part numbers etc.
Cheers
Cheers
I've taken the backplate off, to try and see the type of bearing. I can see it looks sealed at the back, Is the rear bearing sealed at the front or open or franetic type.
I assume the front bearing is sealed front and back.
Uk macgregor out of saito bearings
The Saito 82 uses a 6902 in the rear
and a R6 - 2rs in the front
http://www.rc-bearings.com/catalog/p...roducts_id=771
The rear should be bare with no shields or seals and the front has rubber seals on both sides
$6.89 for both bearings plus shipping USA
ORIGINAL: w8ye
I've looked at horizon hobby 82 parts and this to shows its sealed,but only back of bearing picture
http://www.horizonhobby.com/Products...odID=SAI91S22A
Maybe now the bearings are not sealed or I have early saito82?
I phoned macgregor who don't have any saito 82 bearings but asked them to look at saito 72 rear bearing and he said that was fully open.
Here is mine
Magregor want $38.80 for both bearings ,if they had any, what a rip off..!!!
Hey W8ye.
I just called a local bearing company and he knew what those numbers you said ment and he's got them in stock.
However, interestingly, he pointed out that the front bearing is imperial and back bearing metric??????
He says the rear bearing he has is sealed, but will remove the seal for me to make it open like you say, even if the bearing I'm taking out and horizon hobby show a sealed or part sealed rear bearing according to the picture I posted above.
$12.55 from him, thats the best I'm going to get here in rip off britain!!
I would just take off the seals or shields when the bearings came in. I think that substitute bearings get shipped all the time judging by what people say.
$38.80 is totally too high. Do you have a parts store in town that may stock them? I would call several and use the numbers that W8YE gave you. If not, there are other places to find them at decent prices. I just ordered a set from Advantagerc.com.
ORIGINAL: blw
I hope the crankshaft has a taper or step in it as the new front bearing inner hole seems bigger than the front width of the shaft.
So, tomorrow I tackle the job.
Just a bit concerned about getting the timing right, or precisely how to do that.
