RE: Welcome to Club SAITO !
yes,i did check to see if the inlet tubes between A and B are the same and they are.The only difference between models in this area are the crankcase,cam cover etc,back cover and carburettor part numbers,cylinders are also same part number.As the back cover dimesions between both for the internal fitment side are the same it would suggest the differing part number for the carbs may be due to a difference in the width and distance from carb centreline of the carb mounting attachment among possible other internal differences between carbs i'm not aware of.
Maybe I'm just fussy.
Hi again, with regards to a puller for the drive washer, I have just acquired a you beaut device for $35.00 from the local tool place (Coles Tools) that will pull the drive washers off the small crank Saitos and my YS 53 and 63, you local Allied Bearings place also has small 3 jawed pullers for around $60.00 that are almost as good
ORIGINAL: Craig 01
Phillip
And some auto parts stores. Even Harbor Fright has an assortment which goes on sale occasionally.
Some even have a choice between Nitrile, Butyl, Neoprene, and Viton.
But which is best for glow and which is best for gasoline Saito use?
Sincerely,
Richard
Sincerely,
Richard
Hello I'm looking for a carburator of a Saito FA-120 I can't find any available if you have one or know where I can find one please post it here or PM me will really appreciate.
Thanks.
Thanks.
How much of it do you need?
Here's the main body http://www.horizonhobby.com/Products...D=SAI120S821B1
Here's the external part of the spray bar or the needle valve holder http://www.horizonhobby.com/Products...dID=SAI120S145
Here's the needle valve http://www.horizonhobby.com/Products...odID=SAI120S85
Here's the idle needle mixture valve http://www.horizonhobby.com/Products...odID=SAI120S89
Screws and barrel spring http://www.horizonhobby.com/Products...dID=SAI120S90A
The velocity stack http://www.horizonhobby.com/Products...odID=SAI120S93
Barrel http://www.horizonhobby.com/Products...dID=SAI120S87B
Gaskets and metal rings http://www.horizonhobby.com/Products...dID=SAI120S91B
Other misc parts has a different part # but this is what fits the 120 carb http://www.horizonhobby.com/Products...D=SAI450R3D84A
Here's the complete carb but it is out of stock but due anytime http://www.horizonhobby.com/Products...ID=SAI120S821D
ORIGINAL: spaceworm
Sincerely,
Richard
Sincerely,
Richard
Good Question.
The most commonly available o-ring material is Nitrile which is fine for use with both alcohol/oil and gasoline/oil fuels and is suitable for use in glow/gas model engines of all types where high temperature is not a concern ie. above 120 degrees celcius.Viton being more suitable for temps to 200 degrees celcius.
ORIGINAL: w8ye
Real hardware stores have a little Oring kit with various sizes in it. Pick from the selection
MI
i have a saito 115, 45, 50, 72,91, and a 150, run omega 15% fuel. 1000 rpm idle on the 150 with no glow heat with perfect transition. only start Saitos by back flipping them!
Stephen Wilkowski
Stephen Wilkowski
MI
yes, i would like to join the club!, i will soon be getting a new saito 56 for my super sportster! so i can add that to the collection
I have a Saito 91 that I broke the needle off, so I now need to know which way the slot in the spray bar faces. I would think that the slot needs to be pointed straight up at the intake pipe but I figured I would ask to be sure. Thank You
Yes blw,i'd like to join.
1x .56,2x .62,1x .72,1x .82,1x .125. My first Saito was an early .50 with brass exhaust that was fitted to a fourstar 40 that i had just built at the time somewhere around 90-92.Sold that one with the 4 star several years later and of course was still running well.They were a good combination.
Well thanks blw,after your several logins to this forum i take it you have reserved yourself to not answer my reply to your question..
Cheers mate,
Craig.
Cheers mate,
Craig.
