Official Tamiya TT-01 Thread
#1777
ORIGINAL: mindwreck
oh taht is one sexy beast. i see a cusco struct brace and scca sticker. autoX?
patrick
#1781
hi all,,
for those in the SO Cal area, ( LAX and nearby ) ive started a socal Rc group on yahoo groups. http://groups.yahoo.com/group/socalrc
if you are interested join. its for group stuff in so cal.. hooking up to race/run. etc.
patrick
patrick
#1782
Well i was waitign bigM to respond since he knows everythign about the tt-01.
1. Do your motors haves capacitors? thats one of the main causes of glitchign. your futaba is only 27mhz so its really susceptible to interference. i recommend getting a 75mhz am or FM system.
2. the gear mesh may be bad. are you using the stock gearing?
ORIGINAL: Unique1
Hi everyone,
I have a problem with my TT-01 (sry if wrong place to post)
Setup: TT-01, RS540 Sport Tuned Motor and Heatsink, Upper arm kit, Alloy Propeller shaft, Ball bearings, TEU-101BK and Futaba MJ Radio Gear.
1. I have symptoms of Glitching (Interference?), inconsistant power-on (throttle response). I have swapped my motors out to see if that was the issue, but the problem still persists. I was previously running my radio gear in a Kyosho V one S in the same area with no interference problems at all. This points to the ESC(?) I know... not too sure. Can someone please help/ offer opinion?
2. I have a concerning humming noise comming from my Spur/ Pinion. Sounds like they may be wearing/ not running smoothly? Can someone please recommend the next optimum step up for spur pinion, geared for a bit more speed, but not to much stress on motor? or somewhere I can look?
- Can someone please help!
Thanks in advance.
regards,
Unique1.
P.S -> I'm a drifter
Hi everyone,
Thanks in advance.
regards,
Unique1.
#1783
qwksti, i believe you, nice car!
It's just that i've seen a couple of WRX's with STI body kits, rims and painted brake calipers to look like real Brembos.
#1785
Man, i've already split the front bumper and cracked the rear end and broke a rearview mirror on my A4 body. []
Plus the rims are gouged because i went drifting with the car and didn't glue on the tires so they came off.
And the underside of the chassis is very scratched. too much offroading i guess. :lol:
#1786
ORIGINAL: qwksti
hi,, its a real STi, www.qwksti.com
also,, i would love to hook up and run the tt-01. let me know when you go out,, im there.... i go to a parking lot near my house, its wide open and no one uses it on the weekend, its perfect for open drifting.
patrick
p.s. if this wont show its a STi, not sure what will.. i guess a swap is possible... but im no fake...
[img]http://www.qwksti.com/stiengine20.jpg[/iage]
patrick
Have your tein hood dampers rusted at all?
#1787
hi
the hood dampers are fine so far. i keep them oiled good, so that might help. plus i dont drive it in the rain.
patrick
p.s. as for the fake thing,, no hard feelings, i was not bent over it, just making sure no one thinks im a fake. kuz ive seen lots of them.
patrick
#1788
wow what happen?!?! run into a dumpster like nubus don't even worry about teh chassis. its a 8 dollar part. next time i order stuff im goign get like 3 just incase Lol. me and nubus went to a local park and rallyed on a baseball field. OH man you wont' believe what it did. half a battery in each of our cars and the the rear was packed with red clay and rocks. I got lucky but nubus's car had no teeth left on his gears[:@]
ORIGINAL: Raguvian
#1789
ORIGINAL: mindwreck
ORIGINAL: Raguvian
I kept jumping off the little speedbump and i think that's how the front end cracked, and the underside got killed when i went over some rocks i think. Any time it got stuck, i just floored it all the way and the 4WD would pull it through somehow.
Yummy.
#1790
lmao looks like ours. Yeah the bottom just scratches allot. I'm going to order a bunch more spare parts. I broke the spur/pinion gear cover and that thing shattered. Yeah the pics would explain everything. My Microsoft Natural 4000 keyboard just died on me. half the keys doesn't work after " qwert" second time their keyboard pooped on me. Unappreciated Microsoft. Can't keep good quality workmanship
#1792
its 7 bucks on towerhobbies. you should definitely get it if your running that 12T motor. i have a 17t in mine and ran it to see how bad it is. the shaft was actually vibrating out of the drive cups!!
#1793
Yeah I installed a new spur /pinion set. and was trying it out.. and did a drift and was sliding sideways and hit the curb on its side. Cracked mindwreck's wheel =X and it shattered that whole part. The aluminum shaft cost... 12? i think?
I definitely need to upgrade to aluminum drive cups and stuff too.. cause its starting to shake off too. when I run it just like slow driving.. it sounds like a truck gassing it from a red light.
#1794
Hey everyone I have two TT-01 Cars one Nismo Silvia S15 and the Ferrari FXX. The Ferrari has an alluminum propellor shaft metal motor mount and Aluminum heat sink very stock. The Nismo on the other hand has the Aluminum Oil Dampeners,Aluminum Propellor shaft,Metal Bearing Upgrade,Carbon Fiber upper arm front and rear stabillizers RS-540 Sport tuned motor Aluminum Heat sink and metal motor mount and cut down the posts for the body. My question is what else can I do to my nissan for upgrades or is that all there is? I knnow there are bigger motors to upgrade to but I am happy with this motor.
#1796
So basically the Hex nuts is al that's possibly left the aluminum swing arms don't work with the tamiya stabilizer bars what about the dog bones and propellor joints are they available in aluminum? I have already upgraded the steering to aluminum.
#1797
ORIGINAL: mindwreck
#1798
ON, CANADA
hey i'm thinking of starting a little drift team wit some of my good friends. i mentioned tt-01s to them, but were all kinda busy. now i'm thinking about offroad 2 wheel drive
#1800
I just bought a RTR Tamiya TT-01 with the CPR-01 unit witch acts as the ESC and Reciever. I heard that this ESC can be used with the Sport Tuned Engine. So i bought it, but when i took out the plugs for the engine... they look completely different then the sport tuned one i just bought... does anyone know if i can somehow buy plugs to fit the ESC? cause i kinda dont want to buy a whole new reciever and ESC. If i do then should i just get a whole new controller as well? or can i just stay with the one it came with... please help!!!!
