Official Tamiya TT-01 Thread
#1851
NJ
Someone please help me. I'm just putting my TT-01 back together and I was wondering. Does anyone make a metal/aluminum gear for the gear? The little white gear that spins the rear diff. This seems to be the only gear I keep ripping up. Also does someone know what size bearings to use that go in line with the shaft? I want to get rid of those stock plastic ones. Thanks
#1852
ORIGINAL: Nubus
lol it should. I've drowned mines before. Mindwreck is my witness. =P
Poor TEU101BK.
#1853
ORIGINAL: joeyhatch11
#1854
hi
im wondering what the normal suspension travel is for the TT-01. i went to a new shock set up and it seems to soft. but the travel is less due to the shorter shocks. just wondering if you guys use stiff or soft springs etc?
#1855
lol oh man, poor ESC. I've drenched mines in water before and it still works fine. I plan to shrink wrap it, since I have it openly assessable at work, LOL
#1856
ORIGINAL: Nubus
I should stick my ESC and servo and reciever in a ballon or something but i'm afraid of the heat.
#1857
yeah actually that would do the trick. Like always open the cover clean it and it will still work no matter what. It's a pretty good ESC. I've changed it out with a airtronics now though. I got the need for speed currently. I should post up some pics of the TLU-01/02 unit for the lights. I havn't had time to prep my Gallardo body =(
#1859
ORIGINAL: Nubus
#1863
Heh, so was mine till i stood both the ESC and reciever upright. Double sided tape and packing tape are awesome. :lol:
#1865
[8D] Nice tidy wiring there m8 [8D]
Need some help on a steering problem []
Its only been happening the last couple of days but when i turn the wheels it turns ok but doesnt return back into central position?ive checked to see if the server saver arms were catching anything on the return but nothing? made sure any screws werent to tight to restrict it nuthin [] and ive reset my servo and trims to central too,only thing i can think of is i charged the battery ive using about a week ago and just started using it yesterday would the battery loss enough power to return the steering?
i know battery start to lose power but surely not this much in a that many days?
any suggestions of help plz thanks guys
#1866
ORIGINAL: TIGER76
have you opened up your servo and checked the gears? i had a similar problem and it turns out that one of the gears was missing about 3/4 of it's teeth. i had to order a set of replacement gears and a better servo saver.
#1867
No m8 havent thought of that i had a spare servo with the radio ie acoms should i swop them over would that help?
#1868
ORIGINAL: Nubus
#1869
hey guys, i used my TT-01 for the 1st time in ages on wednesday, soo much fun, lol in about 1 hour i balded a set of tyres
not surprising with a venom 13D motor in, running rubber tyres on carpet, i anniholated a TL-01, TB-02, TA-05, Yokomo SSG, 2 TT-01's and a Schumacher MI2
i got some amazing drift around the corners
#1870
yeah m8 people knock venom motors but i reckon there quality [8D]
my 21d modified vemon kicks my mates 19 turn motor all the time lol [sm=thumbup.gif]
#1871
Yeah the thing is, it happened to mines like it would start up then instantly have this constant flash... Just dry it up and works like new! Tamiya ESC!
#1874
hi all
i need a new ac/dc quick charger and i wanted to know what you guys use. or what the hot quick charger out there now is? any suggestions?
patrick
patrick
#1875
the piranha digital peak is probably the best and cheapest charger you can get. lcd with 10 memory stoarge. adjustable charge rate up to 5 amp on DC, adjustable peak cutoff
