Old 11-03-2010, 07:19 PM
  #18876
Vertical3-D
My Feedback: (20)
Vertical3-D's Avatar
thats the same tach I'm using and it's been serving well for the cheap price...and my 1.30 twin doesn't tach what it supposed to according to the review posted a couple pages back, though I'm usuing a Pro-Zinger 15x6 and not the regular Zinger 15x6 thats in the review, gonna try a 16x4WAPC prop next...always had luck with the APC props...
Old 11-03-2010, 07:21 PM
  #18877
Jimmy Hoffa
Jimmy Hoffa's Avatar
ORIGINAL: 1974hd
I have just finished putting new bearings in my 82 and after putting it all together I destroyed my prop flange.
I always just tighten the prop nut with a propeller on to install the collet (flange). No heat necessary.
Old 11-03-2010, 08:38 PM
  #18878
1974hd
Thanks w8ye I will get one and give it a try.
Thanks for the information Jimmy Hoffa. does this do any damage to the prop?</p>
Old 11-03-2010, 08:44 PM
  #18879
blw
blw's Avatar
Tachs are like someones taste in pickups. Ford or Chevy?
Here is another end of the scale: http://www.fromeco.org/products/05frctnc/
Old 11-03-2010, 10:31 PM
  #18880
1974hd
I would have to compare my hangar9 tach to a Yugo not even close to a ford or chevy. I have heard of these tachs just dont want to drop a hundred bucks on one.
Old 11-04-2010, 12:44 PM
  #18881
Linkan2
God afternoon
Her is DH chipmunk and Saito 100TI.
Teak u look
http://www.youtube.com/watch?v=JbjcO2RC9Gw
<br type="_moz"/>
Old 11-04-2010, 01:14 PM
  #18882
Jimmy Hoffa
ORIGINAL: 1974hd
NO. It will be fine.
Phillip
Old 11-04-2010, 01:20 PM
  #18883
w8ye
w8ye's Avatar
ORIGINAL: Linkan2
God afternoon
Teak u look
Good video, thanks for sharing
Old 11-04-2010, 05:44 PM
  #18884
spaceworm
ORIGINAL: 1974hd
I use an old plastic prop, or a wood one that is broken Just to be sure not to damage a good prop.
Sincerely, SPACEWORM, Saito Club #635
Old 11-04-2010, 05:57 PM
  #18885
w8ye
w8ye's Avatar
Hub Installation
Place the collet in position first
Set the prop drive hub over the collet
Put the prop you will be using in position on engine
Install prop washer/nuts - Tighten in normal manner - go fly.
Old 11-04-2010, 06:16 PM
  #18886
slopoke
That Saito sounds great. Good video.
Old 11-04-2010, 11:20 PM
  #18887
NM2K
My Feedback: (14)
That is a sweet sounding Saito, that's for sure.
Ed Cregger
Old 11-05-2010, 06:28 AM
  #18888
ulpilotrmh
Where do you guys get your bearing puller for the drive washer removal?
Russ
Old 11-05-2010, 06:50 AM
  #18889
w8ye
w8ye's Avatar
This is the only one they have now.
I paid much less about 5 yrs agol
http://www.harborfreight.com/14-piec...set-30305.html
  #18890
Jimmy Hoffa
I don't use one but these have been recommended:
http://www.harborfreight.com/3-piece...-set-8832.html
http://www.harborfreight.com/automot...ler-66868.html
Old 11-05-2010, 06:54 AM
  #18891
mike early
mike early's Avatar
ORIGINAL: w8ye
Dang, I bought mine only 2 years ago, and it was half that. I try only to buy stuff at Harbor Freight when it's on sale..
Old 11-05-2010, 06:56 AM
  #18892
w8ye
w8ye's Avatar
The bigger Saitos require something with some real power plus heat and maybe a hammer
A battery terminal puller is a joke in this situation
Old 11-05-2010, 07:00 AM
  #18893
Rudolph Hart
Rudolph Hart's Avatar
Good taxiing with the chippie on boggy ground(gumboot territory)
Old 11-05-2010, 01:00 PM
  #18894
NM2K
My Feedback: (14)
If anyone watched the video that was recommended in this forum a bit earlier, showing a Saito inline twin powering a model of a Chipmunk, pay attention to the difficulty that the pilot was having while taxiing the model, all because he did not use up elevator to keep the rear end planted on the ground. Just a little oversight like this can eventually lead to a broken prop and possibly a bent crankshaft in his engine.
Ed Cregger
Old 11-05-2010, 01:14 PM
  #18895
w8ye
w8ye's Avatar
I think the weeds were a little high also
Old 11-05-2010, 01:36 PM
  #18896
jessiej
ORIGINAL: 1974hd
I have used the Hangar 9, GloBee and Fromeco tachs. All have worked well enough. The fromeco will give a reading from a bit greater distance.
I also have an ancient Vibra-Tach that reads very close to the electronic tachs, though I have not tried it on a 4-stroke. (Never have to replace a battery)
jess
Old 11-05-2010, 03:40 PM
  #18897
blw
blw's Avatar
The Fromeco always seemed accurate quicker than the Hobbico. First readings were always good and steady. Yep, distance wise you can let your ankles hold the stab and tach the prop standing up. Also, the position of the sun doesn't seem to matter with it.
Old 11-05-2010, 05:40 PM
  #18898
NM2K
My Feedback: (14)
ORIGINAL: w8ye
It is called lack of piloting skill. Something that his instructor should have taught him. I don't mean my comment to be offensive. I would just like folks to think more about what they are doing when they are trying to fly a model airplane, is all.
Ed Cregger
Old 11-05-2010, 05:55 PM
  #18899
w8ye
w8ye's Avatar
After he landed, I saw him raise the flaps and from my experience, you just cannot taxi with the flaps down. Engine power will raise the tail.
Old 11-05-2010, 07:11 PM
  #18900
NM2K
My Feedback: (14)
With conventional landing gear, engine power will always raise the tail, with or without flaps or tall grass. It is normal to taxi a conventional landing gear aircraft while holding up elevator (heading upwind) and relax it slowly with the application of power on the takeoff run.
I'm not trying to be argumentative. It's just that the thought of the bill he will have to pay to get that crankshaft straightened or replaced makes me wince.
Ed Cregger
