Old 11-05-2010, 07:47 PM
  #18901
FNQFLYER
Full size tail draggers and is applicable to tail dragger models pull up elevator until lined up followed by gradual easing off until neutral elevator engine power should do the rest.
If you are in a hurry and are skilled enough a little down elevator to unstick the tail on the take off roll followed by up elevator works as well. This was a technique used in overloaded DC3's / C47's in SE Asia and PNG, but I digress.
Always taxi tail draggers with up elevator, tricycle under carraige (nosewheel types) however benefit from a little down on the taxi to keep everything firmly planted on terra firma until you change your mind and want to fly.  However to much leads to wheel barrowing and stuffs nose gears
Old 11-05-2010, 09:29 PM
  #18902
Rudolph Hart
Rudolph Hart's Avatar
Agreed,still think he did a good job on a very rough strip tho.Notice the dark blobs getting flicked up on takeoff?,looked like sheep poo to me.
Just finished reading brian winches review on the new saito fa200 r3 in the latest airborne mag,he likes it.
Old 11-05-2010, 11:07 PM
  #18903
rocketman-RCU
My Feedback: (73)
A full size Cub is a little different in that you use a lot of forward stick with full power to get the tail up, and then you neutralize the stick until takeoff speed, then up elevator.
Old 11-06-2010, 02:45 AM
  #18904
Kostas1
Kostas1's Avatar
Guys,
don't you think that it would be nice
to see some reviews on SAITO engines ? [8D]
Old 11-06-2010, 03:53 AM
  #18905
the pope
ORIGINAL: Old Fart
Howdy there old fart, Ive never read a review of his where he didnt give a glowing report of any engine he tested. While I wouldnt say hes full of it I think hes close. Cheers the pope
Old 11-06-2010, 05:02 AM
  #18906
w8ye
w8ye's Avatar
Ref: Brian Wench reviews - - With a generous helping of BS thrown in for good measure?
Old 11-06-2010, 07:00 AM
  #18907
Rudolph Hart
wel i..i..would'nt go so far as to say he's a wench(aussie speak for an easy going female)but the my aboriginal mate wally accused his best mate alberts wife by saying he thought she worked in the red light district and was a prostitute...albert got a bit hot under the collar and said she's a substitute,only works mondays and fridays
Old 11-06-2010, 09:53 AM
  #18908
Reson7
If you post something in this thread and own a Saito Engine, your automatically in Club Saito???
I own a Saito 100 Golden Knight and I absolutely love it!
Old 11-06-2010, 10:08 AM
  #18909
Hobbsy
Hobbsy's Avatar
RC, you only need ask and then give Barry a couple of days to notice and you're number will appear.
Old 11-06-2010, 10:47 AM
  #18910
spaceworm
ORIGINAL: Kostas1
Guys,
Look here:
http://www.rcuniverse.com/forum/m_93...tm.htm#9315616
Sincerely, SPACEWORM, Club Saito #635
Old 11-06-2010, 11:17 AM
  #18911
kd8x
Hey Barry, please make me a member too. I have a Saito 72 mounted on a Sig Kadet Senior....Puurrrrrs like a kitten.....Tnx
Old 11-06-2010, 11:20 AM
  #18912
Reson7
Ok, Barry make me a member please!
Old 11-06-2010, 03:03 PM
  #18913
FNQFLYER
When I was revioewing engines in my Old Timer column I did not feel the need to pull engines down for the sake of it.  I used to do straight comparisons with like engines in like a/frames and reporting the results.  The one and only good thing (for me) in Mr Winches reviews is that you get to see these shiney new engines reduced to their smallest component in living colour.  Very handy when one is doing a rebuild.  </p>
Old 11-07-2010, 04:33 PM
  #18914
triumphman49
My Feedback: (149)
Hi, Not a reply, just a few questions. Recent purchase of an older FA270T. While engine "looks new", didn't feel right & prop drive was slipping. HH techs did replace drive & installed new bearings, saying probably needed further breaking in. Did receive a twin manual but closest reference is FA300TD, but do have a parts breakdown sheet (VERY small picture) for the FA270T. 1st question-Have a 20x6 Zinger & wonder if it will do for further breakin & tuning? The parts list references an air needle & air needle spring; looking at the carb, do see a small chrome phillips head screw with a spring around it. The throttle lever passes over the head of this screw. 2nd question-Is this the adjustment screw for the "lo end"? Manual does reference lo speed tuning adjustments by either a needle valve or airbleed screw, but says clockwise to lean with the valve, counterclockwise to lean with the screw. 3rd question-???see 2nd question???. Have found a link to HH where a "manual" may be available, but is shows not in stock & doesn't indicate any availability date. Lastly, would anyone have an old manual for the FA270T that they might be able to make a copy available to me? Your time is appreciated & will be greatful for any responses.
Many Thanx, T-man49 in Alabama
Mike Brennan
Old 11-07-2010, 05:32 PM
  #18915
GaGeeBees
My Feedback: (23)
GaGeeBees's Avatar
ORIGINAL: triumphman49
Hi, Not a reply, just a few questions. Recent purchase of an older FA270T. While engine ''looks new'', didn't feel right & prop drive was slipping. HH techs did replace drive & installed new bearings, saying probably needed further breaking in. Did receive a twin manual but closest reference is FA300TD, but do have a parts breakdown sheet (VERY small picture) for the FA270T. 1st question-Have a 20x6 Zinger & wonder if it will do for further breakin & tuning? The parts list references an air needle & air needle spring; looking at the carb, do see a small chrome phillips head screw with a spring around it. The throttle lever passes over the head of this screw. 2nd question-Is this the adjustment screw for the ''lo end''? Manual does reference lo speed tuning adjustments by either a needle valve or airbleed screw, but says clockwise to lean with the valve, counterclockwise to lean with the screw. 3rd question-???see 2nd question???. Have found a link to HH where a ''manual'' may be available, but is shows not in stock & doesn't indicate any availability date. Lastly, would anyone have an old manual for the FA270T that they might be able to make a copy available to me? Your time is appreciated & will be greatful for any responses.
Mike Brennan
Here's a copy of the manual. It covers prop recommendations as well as your carb questions.
Paul
Old 11-07-2010, 06:00 PM
  #18916
triumphman49
My Feedback: (149)
Have sucessfully printed the manual & attempting to decipher (kind of like the directions for a Kyosho kit) ..... LOL. Many Thanx to you Georgia GB & have a great week.
Mike Brennan
Old 11-07-2010, 07:16 PM
  #18917
GaGeeBees
My Feedback: (23)
GaGeeBees's Avatar
Happy to help. I've got four or five 2.70's and they've all been terrific engines. Let me know if I can answer any questions.
Regards,
Paul
Old 11-08-2010, 07:04 AM
  #18918
Craig 01
Thanks Paul,I saved a copy for myself.
Cheers,Craig
Old 11-09-2010, 08:14 AM
  #18919
Linkan2
God day
mi Saito engines is 50,56, , 62 ,82 ,100 ,100TI and 220
hop i bi a member
Old 11-09-2010, 10:52 AM
  #18920
blw
blw's Avatar
I'm way behind in giving out numbers, but here they are:
712 RcPlaneLover777
713 kd8x
714 Linkan2
Sorry, the background checks and dna testing took longer than expected. Only one guy sent me an engine as an initiation offering. sheesh.
Old 11-09-2010, 02:52 PM
  #18921
Jimmy Hoffa
Jimmy Hoffa's Avatar
Does anyone know the calculations for adding castor to a gallon of fuel as in percentages? I think it was posted a while back but this thread is massive.
Old 11-09-2010, 03:07 PM
  #18922
FNQFLYER
Mixing fuel is a percentage thing.  That is say 1 part castor to 4 parts methanol (standard FAI fuel) . So all you have to do is decide on your final volume of fuel required  and proceed.  Say you want 20% nitro, 25% oil  rest methanol that would equate in imperial measurement for 1 gallon of fuel to 1.3 pints of nitro, 2 pints of oil the rest (6.3 pints) methanol.  Me, unless it is competition fuel, I would round that down or use metric measures (litres and cc's).
I also use pipettes and measuring beakers and only mix in small quantities.
Old 11-09-2010, 03:38 PM
  #18923
Jimmy Hoffa
I just want to add a small amount to a gallon Cool Power LS (low smoke) 30% synthetic. The LS has 20% oil, the regular blend has 22% oil and that's what I normally use. I bought the LS by mistake. I thought a little castor would be a good idea. I purchased some Sig brand castor and need a suggestion on how many ounces to add.
Edit: I was guessing 2 oz
Old 11-09-2010, 04:22 PM
  #18924
w8ye
w8ye's Avatar
In the fuel you have the 20 oz is fine
Old 11-09-2010, 05:23 PM
  #18925
ulpilotrmh
ORIGINAL: blw
712 RcPlaneLover777
713 kd8x
714 Linkan2
But......what about me?
Russ
