Official Tamiya TT-01 Thread
#1901
im running a 17t on mine. i also ran it on my dual motor clod for awhile, didn't even break a sweat. these things are tough little buggers and very underestimated
ORIGINAL: TIGER76
Yep 23turns but u can go a little lower its trial and error with it a 21turn seems fine too never went any lower myself
but heard of people running 17t as well
#1903
the satndard tamiya esc takes to 23turns it depends on your ESC really ive seen BL in tt-01s and they seem to cope ok they get REAL loose at high speeds though []
chassis wise it will take it get a decent no limit ESC and try a few low turn motors out and see what you like best
it your going lower than 21 turns you may wanna upgrade your gearing
#1904
i dont have the stock ESC, i have the novaik 15t esc,
where can i upgrade my gearing?
i think im going to go with a 19T motor, im sure the stock gearing can hold up
#1905
Tower hobbies, Local hobby shop...
You can get several gear sizes. 21, 22, 23, 24, 2nd 25 tooth pinions. 58 and 55 tooth Spur gears.
The most common gear selection arround here is 23 / 58.
ORIGINAL: joeyblaze
#1906
#1907
ORIGINAL: joeyblaze
are they ALUM, i dont see how changing your gearing will save the gears from getting eaten with a power full motor? i understand about gearing up and down and what now, but the guys said upgrade as in make stronger and i dont recall seeing alum ones around, ill have to look on tower if u say they are there
#1911
ORIGINAL: Raguvian
I lost a part of a shock that keeps it together, so can i run the car with three shocks instead?
#1912
ORIGINAL: Raguvian
#1913
Nevermind, i just stuck that shock on the car and it holds the weight, so it handles fine. It could still pop off but i don't think it will... hopefully not...
#1914
Right guys, i was driving my car earlier at my local track, with a venom 13D motor and a mtroniks tempo 11 ESC, and i heard that there may be a rally class starting, so me and annother guy took our TT-01's onto the off-road track, and to be honest it was jumping better than a DF-03, even though i was running slick rubber tyres lol, and after about 30 mins, i didnt break athing.
anyway what do i need to make my TT-01 into a rally car, wheels, tyres, shell etc
thanks in advance guys
#1916
ORIGINAL: rcluke
#1917
theres a few mods you need to do before its rally worthy. ground clearance. sealing the gearbox and diffs. went rallying with nubus and rocks got into the gears and chewed the *** out of our pinions
#1918
some more pics of my TT-O1-R
I also had an integy fan heat sink combo, but the fan didnt work when the heat sink was mounted on the motor, i called up integy and they said my motor had strong magnets or wasnt shielded well and was stoping the fan from spinnig when it was near. So i went to radioshack and picked up a 40mm cooling fan, and mounted it with one screw to the heat sink, its nice and snug and wont move, i also noticed the heat sink blocked the vent holes on the motor, so i dremeledthe heat sink in order not to cover the holes.
#1919
ORIGINAL: Drift wannabe
u neeed oil filled shocks i think [&:]
#1920
ORIGINAL: TIGER76
You will need a load more ground clearance on the TT-01 for good off roading i heard you can change the wheel shafts and wheel arms from another tamiya kit to extend the wheels out grab some longer shocks and i reckon it would run offroad well
ORIGINAL: rcluke
#1921
ORIGINAL: mindwreck
#1922
ON, CANADA
hey can someone post some pics of the TT-01 Nissan 350Z kit, and i mean besides the ones on store websites of the box, or with a body on. i mean like before the build, all the parts, and after the build, no body on. thanx.
#1923
ORIGINAL: Paulyd
Just look at any TT-01 in the Pics Section and you get the Idea All TT-01 are the same just the shll is different so any picture will do.
I hope those help a little
#1924
ON, CANADA
yep, cuz theres a kit on hobbypeople.net for 70$, and me and my 2 friends want to start drifting, and i also want to race my tt-01, or just get 2. now i think i'm gunna hav to mention it to them cuz we've had this idea for about a year, but havent taken action due to the lack of time.
#1925
ON, CANADA
is the HPI Stage-D Spec 1 or 2 anygood for some drfting, is it worth the money, and has anybody here ever used it? how does it control. and th pic has some kinda plugs on it, which i'm guessing are banana. wat do u guys recommend for plugs?
