Powerbox Core radio and set up thread.
#1930
My Feedback: (9)
- The model's current location (latitude, longitude, and altitude)
- The model's current velocity
- The take-off location's latitude, longitude, and altitude
- A time mark
- The ability to determine the take-off location of the UAS
CobraJet (02-26-2024)
#1932
My Feedback: (99)
What I would like to do is have different values for expo with the gyro is switched off. I also want to have one gyro switch that has three values and a second switch that turns the gyro off, just for emergency. I think I can use a virtural switch to get the gyro on two switches for a master "off" and the three gyro values (none 0) on one switch because the three values is easy....
Any suggestions?
Any suggestions?
#1933
Use a Servo Cut-Off for you master gain and tie the expo setting into flight modes. If you are not otherwise using flight modes, you can use the same switch as the cutoff to activate the FM giving you 2 positions and enacting separate sets of expo for gyro on and off.
#1934
My Feedback: (99)
AEROSHELDON (03-04-2024)
#1936
Hello All,
Wondering if anybody is able to assist here - I have over half a dozen Powerbox receivers, a mix of the 9 channel and the new 14 channel units - all are working faultlessly. However one of my 9 channel units is not responding to commands from my PB transmitter. The receiver binds immediately to my PB transmitter, however does nothing more than this. With a correctly set up model, moving the sticks (servo travel shown in monitor screen) does not translate into the servos moving to the powered up and bound PB receiver.
For those in "the know", can you suggest a possible cause here? Possible firmware update needed?
BRG, Frank
BRG, Frank
#1938
Check that you have not inadvertently changed the starting channel for the receiver's servo ports.
You can change the channel that the servo ports start at, so for example if the start channel has been changed to say 15 the rx will only output channels 15, 16, 17....all the way to 23/24. It will no longer respond to chanels 1 through to 9/10.
This parameter ('Output A Start') can be verified and changed in the Rx menu.
David Gladwin (03-31-2024)
#1939
This is for Costas or someone else who feels they know their ways around the Mercury. I need some advice.
I´m setting up the CARF Eurosport. It has a delta configuration and a canard wing that dubbels as an elevator and as as flap. I haven´t really managed to get things right with the gyro function on the delta and the canard and I think it has to do with in witch order I program things. So, here is my dilemma.
Lets say I start with a factory reset Mercury. I understand the basic menu so lets leave that one for now.
Now comes the “set up assistant” I understand that I should set up the delta configuration in the transmitter together with all other functions before I start with the assistant. But shall de canard be set up with the elevator stick control before I run the assistant so that the assistant detects it and assigns a gyro to it at this stage? Or, should I add a control to the canard function later and add it to the Mercury at a later stage via the “input manager”?
As I understand it the canard mixer in the transmitter makes use of both elevator gyros A and B? If that is the case I want to use elevator gyro function C for the canard.
I hope you can follow me this far even though English is not my natural language.
In the next stage I also want to add a flap function to the canard but that shall of course not use a gyro function. That should not be so hard I guess? I just make a function for that in the transmitter with it´s one control switch.
Then, almost the same question as the one above goes for the nos wheel steering as well. I want the steering to be connected to the same stick as the rudder. Then I want the rudder to take advantage of rudder gyro function A and the wheel steering to follow rudder gyro B. Do I set it up with the control stick in the transmitter before I run the “set up assistant” or after via Input mapping?
I would really appreciate if you ,Costas ore some one else, could sort all this out for me.
I would also take the opportunity to express my gratitude for all your instruction videos, Costas. They are invaluable.
Jannica
Sweden.
Jannica
Sweden.
#1941
HI Jannica,
With regards to the canards and the nose wheel - these should be added manually (as well as gyro assignment for these if required) after you run through with the assistant.
The assistant has certain limitations, for instance the nose wheel cannot be handled within the assistant so it must be added manually in the output mapping screen (after first running through setup assistant) and if wanting the gyro to work on the nose wheel then assign a free gyro output (eg. RUDDER B or C) in the output mapping screen for the nose wheel.
I have not tried setting up a canard equipped aircraft so I need to double check my comment above but they should be able to be added manually in any case.
Flap is just a normal function so the Mercury does not impact the flaps, this would just be set up as 'Direct xx' in the output mapping for the ports where the flap servos plug into.
Found this thread over on the PB forum which touches on the same topic...
https://forum.powerbox-systems.com/forum/index.php?thread/14886-instructions-and-set-up-assistant-channel-assignment/#post96483
Jannica (04-01-2024)
#1943
Hello All,
My problem with the PB RX has been resolved - firstly, thanks to all those who responded.
CostasV, when I read your post, the penny dropped. I have a small and complex jet with a lot of channels. To keep the install light/simple I did not want to use any power expander's, etc, so opted for two small 9 channel RX's, with one of them set to start at channel#11. After I set the model up, the new PB 14 channel RX came out, which I purchased and replaced the two 9 channels with, etc. It's now obvious that even though I was attempting to use this particular 9 channel RX in a new model with only one receiver, it would not work as intended as the start channel for this RX was still set to #11, and was not responding to my standard programming-of course this makes perfect sense now.
Thanks again CostasV, a good example of how a single alteration can affect the operation of a receiver.
BRG, Frank
BRG, Frank
The following 2 users liked this post by frankie:
David Gladwin (04-02-2024),
Springbok Flyer (04-01-2024)
#1945
My Feedback: (99)
On the iGyro sat I am flying a plane that is set up but I want more aileron throw. I will add the aileron throw with the tail not connected to make it easier in my basement. Do I have to do "orientation" again to get to the max throw screen? If so, then I'll probably put the plane together to check everything.
As you can see it'd be easier with the entire tail section not even attached.
#1946
Just ensure that you have full throw(s) selected when teaching the sticks and it will now use the larger throw available.
BTW... nice jet...!
AEROSHELDON (04-19-2024)
#1948
Receiver and a servo in the fin and only using one lead?
I have a diffuse memory of Costas, or someone else, discussing the possibility of having a receiver and a servo in the fin and only using one lead to the Mercury in the front of the aircraft. Then the receiver of course connects via the P2bus to the Mercury. Nothing strange there. Then I guess you can change the fast track connection of a PBR-26D receiver to a servo output and connect the rudder servo there. So far ,so good. But, if so, and here comes my question, is it possible to have gyro function emanating from the iGyro and the Mercury on the rudder servo that is directly connected only to the second receiver in the fin? Or, should I just stop trying to be clever and use two leads?
Jannica
Sweden
Jannica
Sweden
#1949
My Feedback: (99)
You just have to re-teach the sticks... no need to re-teach the gyro mounting position/orientation. You can select this directly from the Tx without needing to go through relearning the mounting position.
BTW... nice jet...!
BTW... nice jet...!
