RE: Welcome to Club SAITO !
The metal mounts I use have taped threads in the ex factory, (OS and Saito) when I use other mounts (metal) I tap the mount and run screws through and secure on the other side with nylock nuts and spring washers (overkill but I have yet to loose an engine)
I drill and tap the fiberglass mounts
I use hardened hex socket head screws with no lock washers
Never had a screw back out or strip out.
Been doing it 20 yrs
The fiberglass mounts will even hold a wood screw without it backing out but eventually the heads pop off the wood screws sometimes from the vibration.
A wood screw will back out of a wood mount so fast with the engine running, you don't have time to get the engine shut off.
My Feedback: (55)
ORIGINAL: w8ye
The saving grace was at least it happened before I took off! [sm=eek.gif]
I need a little advice, guys...
I just installed a Saito 125 into my Delta Vortex. I had to turn the throttle around 180 degrees to work with the throttle pushrod (you guys can see where this is going, right?? [])
Well, you guessed it.. I started unscrewing the LSN instead of loosening the setscrew for the arm. The engine hasn't been run yet, but I am wondering.. was the LSN flush with the outer edge of the throttle arm, or was it recessed, a little proud of it???
Thanks for helping me out, guys...
Bob
Bob
Yes, Up to a .91. I don't usually have to remove and reuse a mount, but I have no problem when I do. Have you had a problem with this approach?
Sincerely, Richard/Club SAITO #635
ORIGINAL: FNQFLYER
Let me get this right, you tap threads into F/glass mounts and then screw bolts into them. If so what is the biggest engine you do this with and how do you over come the reduced integrity of the mount each time you remove and replace the engines.
I've used the fiberglass mounts tapped for machine screws up through the Saito 150.
Right now I have a Ultra Stick 40 with a GP universal mount that has a Saito 62 but has had a Saito 50 and a couple different Saito 56 engines on it. The plane has well over two hundred flights. Same mounting screws. No locknuts. They don't loosen.
AL
I have never had a problem with drilled & taped fiberglass mounts since they first became available. Never a problem, though I have used them for nothing larger than 1.08 2 stroke and 1.20 4 stroke.
jess
jess
ORIGINAL: FNQFLYER
I've done this myself, albeit not with a Saito engine. Engine was a 61 sized four stroke. The engine has been out of the mounts twice (once to swap to a new fuselage). Provided the holes are drilled the right size the 'threads' seem to last just fine. I estimate at least 100 hours of engine time with this configuration.
I should point out this was the first time I tried this method, so far no problems
IL
ORIGINAL: FNQFLYER
<br type="_moz" />
I also have a Twist 60 that has had a 91FX, 91 Surpass II, Saito 100, and two different Saito 125 engines. These all have the same mounting bolt pattern but the four strokes were mounted farther forward, so there there are two sets of mounting holes. The plane has many flights. Enough to wear the original hinges out. But never any trouble with the tapped holes in the motor mounts.
And another note: I use a variable speed drill to run the tap through the holes, so it is a simple procedure. The threads are very well defined in the holes and look almost polished.
I use a drill press set on the lowest speed, the mount material generates a lot of heat when drilling. My MicroMark DC powered drill press makes the same torque at stall as at full speed so it will drill really slow. If you use a #6x3/4" sheet metal screw I think it would hold a Mack 711.
I have a big Clausing floor model drill press and It is also set on low speed. But I tap them with a hand drill.
I've seen a lot of people using sheet metal screws with the 40-60 engines. I've never seen one break a screw yet.
I often keep a model several years and many flights before it's demise so I use the Allen head hard bolts even to fasten the mount to the fire wall. The blind nuts are a big factor too. Those that come with an ARF are so thin that the will bevel out and ruin themselves. I usually throw them away and get new heavier ones.
I have been just drilling and tapping the motor mounts too, plastic or metal. the fiber filled plastics they use today can be drilled and tapped quite easily. Sheet metal screws sorta work Ok for a while, but eventually they start to get loose and won't stay tight anymore. I quit messing with sheet metal screws to mount engines with many many years ago. Like w8eye, i use hex screws for all the mounting along with blind nuts as needed.
I like using a drill press to drill the holes in the motor mount too.
My Feedback: (12)
ORIGINAL: lopflyers
Hey guys I just bought an used plane. The guy that sold it to me said it has a Saito50 4 stroke. Is that true?
ORIGINAL: lopflyers
Update, I took off the cowling today and was surprised, it is a Saito 62 4 stroke, brand new. Cant wait to fly it Friday[img][/img]
The Saito .62 is my favourite engine. They seem to be the best running Saito, and that's saying something because all Saitos run great.
I run mine with APC 12x6 or 11x8 props, and occasionall a bolly 11.5x7 or 12.5x6.
ORIGINAL: lopflyers
ORIGINAL: lopflyers
Don't forget to capture a video!
Sorry Bob I missed this yesterday, initially it will be about 1/16" in from the end of the throttle arm and end up about where this one is if not a little further in.
Gentlemen:
I installed a brand new Saito FA-180 in a F3A plane (2x2) and would like to know from your experience what is the best APC propeller should a I use for best performance (Byron 15% nitro, 2 stroke fuel 20% oil). The instruction manual lists the propellers according to the type of plane (Sport, Scale, Aerobatics) but my experience from other four Saitos indicates that not necessarily those from the list gives you the best performance.
Thank you in advance for your comments.
Jose N.
Jose N.
ORIGINAL: blw
My vote for best running Saito would be the 56. Maybe we should have a poll.
I thought it looked really good at the time and the black paint job matched the plane it was on too.
More valve lift. The high cam lifts the valve a little higher, the idea being the engine can breathe a little better because the valves open more.
