Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
AR-6 Construction Thread
Old 06-25-2013, 04:06 PM
  #176
sahartman21
Default RE: AR-6 Construction Thread
The edges of the trim were wet sanded for smooth edges.
The wing was then dried and cleaned prior to painting.
Here is the clear coated wing.
ID:	1895078   Click image for larger version
ID:	1895079   Click image for larger version
Old 06-25-2013, 06:04 PM
  #177
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Scott, I'm curious about your use of peel ply as a hinge. i do realize there are dozens of peel ply products out there, some being treated with release and some not. It however still leaves a question in my mind as to how the hinge holds up in the long run? Everytime I use peel ply it seperates from the fiberglass laminate rather easily and that is exactly why I use it as a release barrier between breather and laminate when I vacuum bag. Is there something special about what you use as I would like to try this hinging method.
Old 06-25-2013, 06:48 PM
  #178
sahartman21
I'm using a generic shinny nylon fabric for the hinge. It just happens to be the same fabric being used as peel ply.
I did place a thin layer of finishing epoxy down first before adding the fabric. Then follow with 1.6 ounce fiberglass cloth.
The stuff that sticks the best is fiberglass cloth, but the issue is that fiberglass tends to crack and eventually fail.
Only time will tell what works best.
Old 06-25-2013, 06:53 PM
  #179
sahartman21
Here are more tank, engine, and radio installation pictures:
ID:	1895138   Click image for larger version
ID:	1895139   Click image for larger version
ID:	1895140   Click image for larger version
ID:	1895141   Click image for larger version
ID:	1895142   Click image for larger version
ID:	1895143   Click image for larger version
ID:	1895144   Click image for larger version
Old 06-25-2013, 06:56 PM
  #180
sahartman21
What was that Mom? Don't procrastinate and get it done sooner! [&:]
It's all coming together, but it always seems to be a push to get things done.
Old 06-26-2013, 04:54 AM
  #181
Alabama Racer
I do hinges very similar to Scott.
The layer in contact with the wood surface is
peel ply. Then a layer of 3.2 oz fiberglass on the
bias (45 degree orientation of the fibers). Then a
layer of 3/4 oz cloth for the finish layer. The light
cloth is mainly used because it is much easier to fill
the weave, for painting, than the heavier 3.2 oz. For
the peel ply itself, I use nylon dress lining from a fabric
store - try explaining to the ladies at the fabric store
what you are using it for!!! It is the same material that
I use for an actual peel ply when vacuum bagging fiberglass
materials, it releases just fine. I've never had a problem
with it wanting to let go when used for a hinge material.
Guess that having it on the inside and encapsulated by
the other materials holds it down just fine.
brad
Old 06-26-2013, 07:04 PM
  #182
sahartman21
Here are more pictures on polishing the wing, installing the landing gear, and radio installation:
ID:	1895391   Click image for larger version
ID:	1895392   Click image for larger version
ID:	1895393   Click image for larger version
ID:	1895394   Click image for larger version
ID:	1895395   Click image for larger version
ID:	1895396   Click image for larger version
ID:	1895397   Click image for larger version
ID:	1895399   Click image for larger version
Old 06-26-2013, 07:08 PM
  #183
sahartman21
Here's the finished product!
One down and the AJ-2 left to go. Nothing like last minute building.
ID:	1895401   Click image for larger version
ID:	1895402   Click image for larger version
ID:	1895403   Click image for larger version
Old 07-14-2014, 05:22 PM
  #184
sahartman21
Default AR-6 Construction Thread
I've been framing up a replacement model for one I left in Phoenix.
This one has a built-up vertical stabilizer that is about 3/4" taller.
Here are some recent pictures:
ID:	2014255   Click image for larger version
ID:	2014256   Click image for larger version
ID:	2014257   Click image for larger version
ID:	2014258   Click image for larger version
Old 07-15-2014, 08:55 AM
  #185
PylonDave
PylonDave's Avatar
Lookin Good !!
Old 08-01-2014, 11:04 AM
  #186
sahartman21
Lightly sand the surface of the model with 220 grit sandpaper and dust off the surface.
I tried something different. I followed with a light coat of rattle can primer on the surface of the model.
Dupli-Color light gray primer was used.
Old 08-01-2014, 11:08 AM
  #187
sahartman21
In a few minutes the primer is dry.
I then applied a thin layer of lightweight spackle to the surface of the model.
You can rub it on with your hands or spread it on with a squeegee.
ID:	2019176   Click image for larger version
ID:	2019177   Click image for larger version
Old 08-02-2014, 10:03 AM
  #188
sahartman21
In a few hours the spackle is dry enough to sand.
I followed with 220 grit sandpaper and sanded as needed until smooth.
If the surface is not filled apply another coat of spackle and continue as needed.
Old 08-02-2014, 10:08 AM
  #189
sahartman21
Once the surface is filled, I followed with a coat of white primer (KlassKote).
I mixed about 6 ounce of primer and waited about 30 minutes before adding thinner.
An equal volume of thinner was later mixed into the primer. Pore the mix though a paint filter into the gun.
Spray on several light coats until the surface is coated.
Set the model out of the way to dry.
ID:	2019352   Click image for larger version
ID:	2019353   Click image for larger version
Old 08-03-2014, 12:04 PM
  #190
sahartman21
I wet sanded the primer until the surface was smooth.
The model was then set out of the way until the water dried.
Old 08-03-2014, 12:07 PM
  #191
sahartman21
About 4 ounce of acrylic enamel paint was mixed. About 2 ounces of reducer was added and the mix was filtered with a paint filter.
A light coat of paint was applied and later several more. The model was set out of the way to dry.
ID:	2019575   Click image for larger version
ID:	2019576   Click image for larger version
Old 08-03-2014, 02:02 PM
  #192
PylonDave
PylonDave's Avatar
Scott, Do you find you red or yellow paint schems are easier to see while test flying and racing ??
Old 08-03-2014, 03:21 PM
  #193
sahartman21
Red and yellow are about the same for me to see. I just want a color that others are not using.
It seems that everyone is using white. White is easy to trim, but I can't keep track of my model when all the racers are the same.
Old 08-09-2014, 10:16 AM
  #194
sahartman21
Here are pictures showing the location of the stencils:
ID:	2021143   Click image for larger version
ID:	2021144   Click image for larger version
ID:	2021145   Click image for larger version
ID:	2021146   Click image for larger version
ID:	2021147   Click image for larger version
ID:	2021148   Click image for larger version
Old 08-09-2014, 12:36 PM
  #195
sahartman21
Gloss black Krylon spray paint was first applied lightly.
Then follow with several more light coats to cover.
In a few minutes the paint is dry enough to remove the masking tape and stencils.
Here is what it looks like after applying the color but before applying clear coat.
ID:	2021216   Click image for larger version
Old 08-17-2014, 10:06 AM
  #196
sahartman21
Here are pictures of the completed AR-6.
ID:	2022994   Click image for larger version
ID:	2022995   Click image for larger version
Old 10-19-2014, 04:50 PM
  #197
sahartman21
Two more AR-6 wings are being built for new airplanes.
Old 10-19-2014, 04:53 PM
  #198
Kevin Matney
Kevin Matney's Avatar
Man them are some great looking foam wing cores!!!!!
Old 10-20-2014, 04:49 AM
  #199
sahartman21
I agree!
Kevin provided the cores and will cut cores to your specification.
Old 11-09-2014, 02:01 PM
  #200
sahartman21
I glassed another wing and placed it in peel ply.
This was then placed in the vacuum bag and closed up.
