Swiwin Turbines
The following 2 users liked this post by BarracudaHockey:
Canadian Man (05-13-2021),
yeahbaby (04-15-2021)
#179
Hi Tone,
This is a pretty simplistic chart that shows the degradation of thrust with altitude. This is not manufacturer specific. The simplest way to interpret this is to look at at notation in KPa. 3500 feet was mentioned which equates to ~1080meters. On this chart see highlighted 1000 meters and you will see 90.7% performance. Calculate loss at other altitudes the same way.
Andy
Andy
#181
There are other factors such as temperature and humidity and believe me I have taken two identical turbines side by side and gotten different measurements. This is just not an exact science. But yes your motor will behave differently in Denver versus at sea level.
#182
I don't think its as bad as we might think, Yes, well I'm well aware it does play a huge factor, I flew my L-39 with ACEx 80 and I've noticed no day and night difference in terms of performance, between Denver and FL, I flew Josh's L-39 with same turbine in 98F+ temps, midday, smoke all around from forest fires and its a little sluggish but not marginal, but my view is if a 120 works at sea level, for us in Denver best to get a 140 sized turbine.
#186
#188
Probable governed the ECU for rpm.
#190
Same country origin built on different days, remember who builds them.......!!!!!!
#194
We modified the output on the earlier 80s. The 60 and 80 wheels are similar. The 80 wheel is 1.5mm larger than the 60 with the same profile. We knew that 5k would yield 85 output but the factory did not want us to push it. So we stopped offering it. There is nothing that the end user can do to increase the max RPM, only to lower it. .
Andy
Andy
Canadian Man (04-28-2021)
#196
One day I ran into an interesting problem with sw120b. All worked fine until engine did not recognize throttle. I swapped cables and tried everything until I contacted CRX turbines via whatsapp. Well, easy fix. Set Jeti system from auto pulse widht ( or frame rate..) to 16ms ( 15ms only selectable rex3 assist) and problem gone.
now I am wondering why its like this? Good servos need fast frame rate to get everything out of them and now you have to reduce your system speed to keep engine ecu hanging along..
#197
That's an interesting issue with the Jeti servo frame rate. In Harry Curzon video
, he talks about leaving it at auto setting or like you did select a frame rate.
#198
Harry doesn't cover the frame rate for the servos in his video it's not in this one, my bad. Ooops
#199
Ceeray, Others have told me 11ms is the magic number. 16 will definitely enable you to connect Jeti with the Swiwin ECU.
Andy
Andy
#200
My Feedback: (41)
Density Altitude is just a fact of aviation life as those of us with full scale licenses will tell you. It can make a huge difference in A/C performance be it full scale or drone or model.
The place where lots of guys like to fly around here, is an old Salt Flats lake bed. It will commonly hit 90 degrees or over in the mid summer. You HAVE to be aware of that as it not only affects engine performance but how well the wings will generate lift. There are just fewer air molecules to work with and that DA can be affected by Barometric Pressure, and Humidity.
Bottom line is that as the DA goes up, you may need to adjust Turbine idle RPM and slow down the ramp speed or they just won't play when it gets high, hot, and wet.
