Reaction 54 Jet Kit
#176
My Feedback: (69)
RE: Reaction 54 Jet Kit
ORIGINAL: mr_matt
I might build one with a P-60 or a P-70, I have not made up my mind yet as I have not decided on what mods I want to do.
ORIGINAL: rcguy!
Who's building a R54 with a P60?
I believe Bruce has stated that the P-70 is too big.....
Dave Rigotti
#177
My Feedback: (69)
ORIGINAL: TommyWatson
Looks Great Dave,
My Wheels etc are on their way to Australia. What is that white stuff on the ground!!!!. We never see it down here.
Regards
Looks Great Dave,
Regards
Thanks! We live in the infamous "snow belt" here in Northeast Ohio. Cleveland gets @ 55" of snow a year and 25 miles East we get @ 120"! The kids Ski during the winter and I hunker down in the basement. "Ya really get used to it!" Hey..It's home.
Today was actually a PERFECT day to fly. Got to 35 degrees (F), no wind and a beautiful clear sunny sky. The county airport does allow turbine models to fly from the taxiways. SO......Flying in the winter is not a problem..IF you have a turbine to fly with....Hmmmm. Otherwise we go to our local field with skis on the models to fly and drink hot choclate in the enclosed pavillion we have.
I looked on the PST website and can't find what the total weight of all the turbine components are. They just list the turbine itself. "Love those marketing guys!" The engine is 1.1 Kg or 2.45 pounds. I can't imagne the CU and battery pack weighing more than a pound and a half (.7 Kg).
Well, I'm going to cleanup a bit and make turbine noises in the meantime.
Keep building!
Dave "we don't need no stinkin tailpipe" Rigotti
#178
WV
Hi Dave:
I just weighed my PST J600R and the weights are as follows;
Engine with mount 40.1 oz
Fuel pump 2.2 oz
ECU with wires
and switch 5.4 oz
Propane tank 1.4 oz
Electronic propane
valve 1.0 oz
Festo fittings 1.2 0z
Reaction ready for final sanding and covering
Ron Jahnig
Fuel pump 2.2 oz
ECU with wires
and switch 5.4 oz
Propane tank 1.4 oz
Electronic propane
valve 1.0 oz
Ron Jahnig
#179
My Feedback: (69)
ORIGINAL: rjpilot
Hi Dave:
Fuel pump 2.2 oz
ECU with wires
and switch 5.4 oz
Propane tank 1.4 oz
Electronic propane
valve 1.0 oz
Ron Jahnig
Hi Dave:
Fuel pump 2.2 oz
ECU with wires
and switch 5.4 oz
Propane tank 1.4 oz
Electronic propane
valve 1.0 oz
Ron Jahnig
Thanks for the info...My math says 51.3oz. (3.2 pounds) I don't see the battery pack weight listed. 64 minus 51.3 is 12.7ozs left for it.
Keep sanding and covering...be careful about banging it into things! I finally gave up filling every little ding.
BTW....when id you get your PST and what version TEMS is it?
Dave Rigotti
#180
My Feedback: (10)
ORIGINAL: rcguy!
#181
Here is what Bruce said about the P80...The P70 would fit fine. Just needed to redesign the turbine mount which I suspect Bruce is already working on...
Cheers,
ORIGINAL: BruceTharpe
Yeah, John, I'm afraid so. I know it can be de-rated, but there are issues beyond max power. It cannot physically fit in the space between the tail boom and the top of the wing. It could be moved aft, but then you are moving an extra-heavy turbine even further behind the CG, which translates into massive nose weight - kind of a vicious circle. It's truly designed for the 54 class of turbines - that's why I specifically put the number 54 in the name.
That said, the P70 is an "in between" turbine that can be made to work in the R54. The P-60, which is due out very soon, is particularly interesting because it's actually a little smaller and lighter than the typical 54-size turbine and still puts out 13.5 lbs of thrust. Sounds like a match made in Heaven!
Bruce Tharpe - BTE
Bruce Tharpe - BTE
#182
My Feedback: (69)
ORIGINAL: mr_matt
Unless something has changed, Bruce was selling package deals of the P-70 and the Reaction at the IMS show this month. He took motors with him to make the mounts. From what I can tell, the P-70 fits fine.
ORIGINAL: rcguy!
Dave Rigotti
#183
My Feedback: (69)
ORIGINAL: mr_matt
ORIGINAL: rcguy!
P70's in stock available for immediate shipment?
Dave "tired of waiting" Rigotti
#184
ORIGINAL: rcguy!
Matt,
ORIGINAL: mr_matt
ORIGINAL: rcguy!
Anything that you can do to help out Dave here?
Cheers,
#185
ORIGINAL: tschuy
Thanks Dave
Much appreciated...
I'm still about three weeks away from getting mine done....
Won't be ready to fly for another 4...
Keep us posted...
Cheers,
Thanks Dave
Much appreciated...
Keep us posted...
Cheers,
Wing is mounted...Tail feathers are aligned and ready to go. Put the big pieces together and couldn't help myself from making jets noises with Joe Satriani's "Flying with an Alien" playing in the background. This thing is cool!!!
Cheers,
#186
My Feedback: (69)
ORIGINAL: tschuy
Hey Bruce....
Cheers,
ORIGINAL: rcguy!
Matt,
ORIGINAL: mr_matt
ORIGINAL: rcguy!
Cheers,
I've cancelled my order for the PST-600R. Too many delays! Looks like the soonest I would have gotten it is Feb 11 or the 14th. 5 weeks after ordering it. I didn't want to go with a P60 as it is too new (sorry jetcatusa). Now that Bruce is evidently endorsing the R54 with a P70, I'll see if I can find one in stock someplace and get it in before next weekend to install. The 78ozs on board fuel should do fine for duration, even with the P70 sucking 8oz per minute at WOT. Hey, look at the bright side...I MAY get my 150MPH yet!
The saga continues!
Dave "still grounded" Rigotti (A tough customer who believes actions speak louder than words. In other words.."do what you say")
#187
Considering what is going on in that part of the world, I can understand the delays...
I'm sure you'll be happy with the P70. Hopefully they will get it out to you real soon.
Seeing how quickly Bruce's flies with RAM-500 I'm sure I'll be happy with the FTE T-500 which puts slightly more thrust.
Cheers,
Cheers,
#188
My Feedback: (69)
ORIGINAL: tschuy
Cheers,
Cheers,
The delays had nothing to do with "whats going on in that part of the world". I won't go into details...out of stock parts basically. Would have been nice to let me know weeks ago...I may have been more understanding. Lets drop it......
BTW...I ain't got a P70 either!
The R54 surely does not need the extra thrust...In fact it may lead to additional landing problems with the "light" wing loading and extra idle thrust the P70 has.
Dave
#191
My Feedback: (69)
ORIGINAL: Ron Stahl
I plan on a Ram-500 or P-70 in mine. I just put the retract gear in it tonight after dinner. Covering will begin asap. Dave check your pm's
Keep at it...you'll be finished before you know it. Bruce makes a beautiful product. With a P70 I'd recommend getting Gary's 74oz tank. This gives 78oz on board...enough for some WOT and "crusing" too!
Got some pictures?
Dave Rigotti
#192
My Feedback: (69)
My Wheel and U/C stuff arrived today ,Thanks Bruce.
Well it looks like work will have to wait now.!!!!
Regards
Regards
Nice stuff huh? I used the paper template Bruce provided and the retracts lined up perfectly when I installed them. Kinda neat to see 'em go up and down!
Dave Rigotti
#193
Hi dave,
Yes I used the template and installed the nose gear blind nuts. I was a little scared they would not line up. I was wrong. I have just screwed the nose gear in place. Still need to cut out he rest of the bottom for the wheel and strut.
I have to go to work now but later tonight wheeeee!!!!.
Regards
Regards
#194
Sorry to hear about the troubles with PST Dave.
I just go with the mind set that all thing happen for the good. Hopefully something will come out good with all the delays that you've been through.
I just bought a NIB Futaba 9CAP radio on eBay for $255. everything is there minus the servo's and receiver. Plus got a CAM pack and rubber grips plus the transmitter freq modual. Guess I won't have to use my 7CAP after all...
Cheers,
Cheers,
#195
My Feedback: (69)
ORIGINAL: tschuy
I just go with the mind set that all thing happen for the good. Hopefully something will come out good with all the delays that you've been having.
Cheers,
Cheers,
You'll love the 9C. Just got a 9CHP for Christmas. I fly heli's and I always get a "Heli" radio. You get a upgraded battery pack and better servos too! I'll let you know how I have it programmed. I have the retract valve on ch9 and the steering servo on ch5 slave to the rudder. The flaps are on ch 7 and 8 both using the left slider. NO mix between them. I added a Pmix(#7) to have down elevator added as flaps lower. It has a"curve" and I can vary the amount of down elevator. This will still leave 5 mixes to use for flight trimming. I'll review it and post it to the group soon.
Dave Rigotti
#199
Awesome Dude...
May have to shift things around a bit to get the CG right. But it'll be an even better performer with the lighter weight engine.
Just wondering about the engine mount... Isn't the P60 smaller in diameter?
Stuck doing some home computer repair work today. But it means an additional $300 in my pocket if I get it done... Gotta pay for that new 9CAP .
Cheers,
Cheers,
#200
My Feedback: (32)
MA
Hi Dave,
Sorry, this is a little bit OT, but since you're idle waiting for your turbine to show up (), here goes:
I really like your R54 covering job/color scheme! Can you tell me the order that you covered it, and the colors you used? Did you start with an overall covering job, and then trim it out, or how did you get the multi-color effect (particularily the wings)? Can you provide some details?
Thanks!
John
Thanks!
John
