My Feedback: (20)
Is there any difference between the Saito FA-125A "White Box" vs the "Gold Box" engines? Is the Gold Box just an earlier model?
I'm shopping for one.
I wonder why they would go to the trouble to use different color boxes for Europe versus the USA.
Is there a difference in the engines of some type? Such as maybe compression ratios or something?
Old Fart If you are interested in Old Timer flying, (we have an avid proponent in Paul Baartz in WA) consider the following. A Saito 62 or 65 in an 85% Lanzo Bomber, initially fitted with a 14 x 8 or better still a 15 x6 or x8 Super or Graupner paddle bladed prop in the Texaco event. Engine limited to 6,000 rpm max (transmitter mixing) with a fixed throttle setting of 2,500 to 3,000 rpm, climb out speed running for approx between 6 and 8 minutes, on 15 ml's of 10% nitro, 20% oil fuel for a 10 minute qualifying round. Then take same engine put a 13 x6 needle bladed prop up from tune to max RPM around 11,000 to 12,500 rpm + on YS fuel (30 - 40% nitro 20% oil) for a Duration comp (30 sec engine run for a 7 minute for the qualifying rounds) and in both modes the combination is capable of winning either of the disiplines then you can say you've been playing with tuning a Saito. Interchange of various cams is another game all together.
I don't do videos but I'll try for some photos in June of these foamie things. Good to see the MAAA is at long last recognising them
Catch Ya
Catch Ya
Hi all!
Today i received my SAITO FA-180 GK....but it misses the side-sticker that reads "180"....
How can i determine if this is really a 180 and not an FA-150 ?
I can make a comparison with my FA-150S but on the outer side these are the same.
K, your 1.80 will be 135mm tall from the very bottom of the crankcase to the top of the rocker covers and 113 mm from the crank centerline to the top of the rocker covers.
The 1.50 weighs 30oz the 1.80 weighs 31oz sans muffler.
My Feedback: (10)
Hi. I just bought a plane that has a Saito 300 in it. He rec'd 20/20 fuel. The only place I've found that carries gallons is Chief Aircraft. Anyone want to suggest anywhere else I can purchase the fuel online?
ORIGINAL: kevinkenny
Just updating you all on my Spitfire. She should be ready to fl;y in about two weeks. The Saito 91S with Keleo muffler fits great.
Kevin
Kevin
have you finished your Spitfire yet ?
I bought a used .91. My first duplicate in the same size. I like the .91 a lot. I run a MA 13x8 three blade on my other one. This one is going to go into a new .50 size GP Shoestring. What prop will give me the best speed, do you think? 12x11 or something near there?
Okay - once is a freak but twice - not so sure. 3 years ago my Saito 150 dropped a valve and effectly turned it into a paper weight! I love the engine so I bought a new 150 to install in my ESM Spitfire 150 - a great combination! On the weekend the new engine (now circa 2 years old) did the same! I never push the motors (lean) and I do check the valve clearance from time to time. I am swinging a 16X10 prop so it is not under proped and normally it starts first time.
I have not had the courage to open it up yet but I guess it will be the same story. Any ideas as to why this has happened?. Hopefully the damage is not to great and between the two engines I will have enough spare parts to get one up and running - but I am not holding my breath!
Anyone else had a similar problem with the 150?
My Feedback: (10)
This is probably old news around here, but I thought I'd link the new engine info from Saito.
3 head radial 1.2
http://www.horizonhobby.com/Products...#quickOverview
Dimensional Drawings
http://www.horizonhobby.com/ProdInfo...nical_Data.pdf
This looks like the perfect engine for my Top Flite Gold Kit P-47D Razorback!
3 head radial 1.2
I think there is more news coming. I can't get the Horizon site to work well this morning, but this is from Saito:
http://translate.google.com/translat...3DN%26pwst%3D1
Indeed my friend,now,how many saito engines of different sizes do you know of that share the same carby7anybody else??![Smile](images/smilies/smile.gif)
open to all forum readers please say what you think
Actually, using the same carb on several different sized engines is quite common. Fox, for example does that with the .46 through .74 engines. The .46 runs faster than the .74 so the large carb works well. The .60/.74 runs slower than the .46 so the same carb again works well.
Thanks for the info on fox engines,my question is directed towards saito engines and any common carbs,can you tell me what they might be if any?
The Saito 50, 56, & 62 all use the same carb
The Saito 72 used the Saito 80 carb
The 82 and 91 use the same carb
The Saito 115 uses the Saito 100 carb
The Saito 150S uses the Saito 120S carb
Have a 1.50 inverted in a narrow cowled warbird and in order to make it fit I had to point the carb/manifold staight down towards the ground
so it is lower than the fuel tank.
Seems it's siphoning down and dripping. Is there any fix for this where I won't have to move either one? Really don't want
to cut the cowl and point the carb out the side and there's just no way to lower the tank any more than it already is.
