Electronic solutions to modifying glow engines of all sizes to gasoline
#2002
To illustrate:
Preliminary and very crude consumption checks seemed to indicate approx 24 ml of fuel per hour on the pond.
A test in my bathtub, at near continuous full throttle made 15 ml last for more than one hour.
Which means that either my crude preliminalry measurements were way off, OR the engine load is significantly less in the tub compared to on the pond...
Either way, this kind of consumption, well, it is utterly minimalistic...
#2003
It's an electronic circuit that generates multiplied frequencies, used a bunch in radios and television s and now in computers. It essentially would fill in the 9 missing pulses between the one rpm pulse you have using an arduino's timers and a bit of math. 3.5 khz is pretty easy when you have a 48MHz clock like the one in the seeeduino Xiao.
Edit: it's actually 350 Hz so it could be done with even an Arduino nano or similar
#2006
#2007
Cooling is done by a tiny 42 mm electric fan, and more as a gimmick than anything else I added a commercially availlable themperature controller (very cheap Proportional controller, nothing fancy) and changed the NTC resistor for a FrSky probe, which conveniently brought the regulating range to 70~100 deg C.
The weird thing about this cooling is, that when I ran the engine without cooling, it never got over 110 deg C as far as I can tell, and the other ASP 30FS I have runs way hotter.
I do not believe for one minuten that this tiny fan has any significant effect on engine temperature, because even an idling prop generates a 100 times more air movement,
So tiny or not, HUGE effect... I sure did not expect that...
#2010
Bert, those videos remind me of the old "Hit 'N' Miss" engines... looks like you got it running reliably... after 7 years, I would have lost interest ... looks like a lot of fun.
Whatever happened to the stirling steam engine you had? that looked interesting as well.
#2011
It's not hit&miss, it's properly carburated and throttle-regulated.
The steam engine (not stirling, that's a different operating principle) is running fine, and has been gradually developing ever since. It's got a faster boiler feedpump now, and regulated electric heating on the fuel tank to maintain more constant gas pressure, and now it can either run balls-out continuously (24 minutes until empty) to deadslow continuously (75 minutes) and anything inbetween at will, fully automated and alarmed.
It's a delight to operate.
I will have to update that thread, I noticed I did not post latest developments there. Apologies.
The steam engine currently has about 57 runhours, which frankly, is quite a lot as these things go, most people run them 4 or 5 hours per year... Not me though
#2014
I can see its carb / throttle managed... just the slow putt putt sound reminds me of the hit n miss .
That steam engine looked like it was well made... I have a fancy for anything thats done to scale with detail... My neighbor is into model trains, "G scale garden railroading"... his entire backyard looks like the old time Colorado railroad from back in the day, right down to the scale buildings, crossings, and landscaping... he has a couple G scale live steam trains he runs, just amazing detail.
#2015
It still does...
In the past 2 months, I managed to fit the boat with a feedwater preheater annex condenser, that preheats the water pumped to the boiler to approximately 90 deg C, resulting in a considerably (10% or so) lower fuel consumption for the same output. That preheater/condenser also returns about 40% of the consumed water back to the feedwater tank, resulting in a longer operating time. On this scale, barely anybody does that. Another one of those things that I kept gnawing at
https://www.modelbouwforum.nl/attach...-1-jpg.554978/
https://www.modelbouwforum.nl/attach...-1-jpg.554979/
https://www.modelbouwforum.nl/attach...-1-jpg.554999/
Catching all the oil from the condensate initially appeared to be a challenge, but once I figured out what was the issue, it actually was surprisingly simple.
I think I have now about 25 hrs of runtime on this set-up, and operation has become extremely simple and troublefree.
#2018
My neighbor uses methenamine in his live steam trains, same stuff as esbit... back when I was just a kid, I had one of those Wilesco table top steam engines... when I ran out of the solid fuel tablets, I would pack the fuel tray with cotton balls and soak it in alcohol.
#2019
The fuel tank is electrically heated, heat (5W) is switched on and off on gas tank temperature, in oder to have a somewhat consistent fuel pressure, which makes the job of the boiler pressure regulation easier.
The thing with steam is: the more consistent you can get it, the better it works. "Steam" hates changes in operational conditions, so the better everything responds to each other, the smoother the system functions.
It's rather "organic", actually: Everything affects Everything...
#2020
The extent of my experience with model steam engines is a "dampfmaschine" my father picked up used in Germany. It came with a couple of belt driven accesories.....a wood chopper guy and two guys operating a two-man crosscut saw. My brother and I burned ourselves.......I mean...... had a great time with that toy.
#2021
Strange enough (they are still being made) prices have not kept up with inflation. Forty years ago a Wilesco steam roller would set you back about 250 guilders, now they are about that in Euro's, but 250 guilders in the '80's is closer to 500 euro nowadays, if not more.
#2022
Yes, a Wilesco D5 I believe. The thing wasn't balanced very well and would start skidding across the work bench when at full bore. We took turns sacrificing our arms to the boiling hot spewing splatter coming from the cylinder. Lol. Those were the good times.
#2023
Mine was a D10 I believe... still available, $225 for the std D10... they have a 100 year anniversary version of the D10 for $275... not a bad price for this day and age... the larger models that have silver bazed boilers are a bit more expensive, 1k to 7k USD.
https://www.ministeam.com/product/Wi...-Steam-Engines
#2024
To illustrate:
It still amazes me, how absolutely tiny those droplets have to be.
Anyway, a short impression of this other department of ex-glow gasoline powered RC modelling:
