RE: Welcome to Club SAITO !
ORIGINAL: FNQFLYER
Contact Phil Collings out of the Tingalpa Club if he can't fix your engine he will know who can do the job
Hope your fingers are OK!
Beej
Eh feller's, I have been pondering converting a Saito medium size single, 120 /150, to ignition using a Rexell CDI, to run on low or no nitro (FAI) glow fuel, to power a 1/4 scale Piper Super Cub bush plane. The point being the more scale sound/performance over using a two stroke gas, and to hopefully eliminate the headachs of Saito gas motors. I have heard of oldtimers runing glow on ignition, but thought I'd ask here first to see if it's actually a viable idea. Anyone with experience with this topic? Chime In!
For those out there who will say just run gas, it's cheaper, ect., don't bother, this application is for smoother runing, lower idle, and, I guess, the cool factor!
Not to overshadow SkyPilot101, but while you are contemplating his question, can I toss in another one? Has anyone mounted a Saito 82 into a Horizon Hobby Cub 40? I'd be curious about any tricks that you had up your sleeve...
Bob
Bob
I have a Saito FA 72, it keeps eating the rear bearings up .
This is the third set of bearings . It eats the bearing cage up in the rear bearing. One was the factory bearing, one was put in by Horizon Hobby, and I have just put the third one in myself that I got from Boca Bearing. The factory bearing and the Horizon hobby bearings all had metal shields on them. The Boca bearing does not have shields. I think it is the shields that don’t let them oil properly. I haven't tested the new bearings. As soon as I test the new bearings I will let you know what happens. The old bearings lasted about one gal. of fuel. The fuel that I run is Wildcat 30% nitro with 18% synthetic oil-no castor. Horizon calls for 20% oil. Wildcat says their 18% is a heavier viscosity and does a better job than the lighter 20% oil
My Feedback: (14)
ORIGINAL: WRM
This is the third set of bearings . It eats the bearing cage up in the rear bearing. One was the factory bearing, one was put in by Horizon Hobby, and I have just put the third one in myself that I got from Boca Bearing. The factory bearing and the Horizon hobby bearings all had metal shields on them. The Boca bearing does not have shields. I think it is the shields that don’t let them oil properly. I haven't tested the new bearings. As soon as I test the new bearings I will let you know what happens. The old bearings lasted about one gal. of fuel. The fuel that I run is Wildcat 30% nitro with 18% synthetic oil-no castor. Horizon calls for 20% oil. Wildcat says their 18% is a heavier viscosity and does a better job than the lighter 20% oil.
I'd put the engine back in service and see what happens to the new bearing(s). Of course, if you bought them from RC Bearings, you could have probably gotten all three sets for the price of just one set from the more expensive source.
I would begin to suspect the crankcase being out of alignment if the latest set of bearings die within a gallon of fuel being consumed.
Ed Cregger
IL
ORIGINAL: WRM
This is the third set of bearings . It eats the bearing cage up inthe rear bearing. One was the factory bearing, one was put inby Horizon Hobby, and I have just put the third one in myself thatI got from Boca Bearing. The factory bearing and the Horizon hobby bearings all had metal shields on them. The Boca bearing does nothaveshields. I think it is the shields that don’t let them oil properly. I haven't tested the new bearings. As soon as I test the new bearings I will let you know what happens. The old bearings lasted about one gal. of fuel. The fuel thatI run is Wildcat 30% nitro with 18% synthetic oil-no castor. Horizon calls for 20% oil.Wildcat says their 18% is a heavier viscosity and does a better job than thelighter 20% oil.
-Mike
<br type="_moz" />
1 Post
I have a question, I have a saito 170 r3, and it is on a GREAT PLANES WACO, I`m looking for some flexi SOFT extencions for the exhaust sistem to put all 3 lines togeteher in the down part of the couling, I know there are some metalic flexible extencions but I prefer to look for some SOFT MATERIEAL for the vivration damage that the metalic can do ti my engine. PLEASE LET ME KNOW ANY IDEA OF SOME HEAT RESESTANT SOFT TUBE or something.
ORIGINAL: Nikolas K
Does anyone Saitonut here [8D], have the original manual of the FA-30S? I want the one that comes with every Saito and seems to be the factory-original one. It usually comes packed in a plastic folder with a Saito leaflet...
PS I do not want the Horizon Hobby nor the Aeronaut ones...pls if anyone has it in a file, scanned or knows where to download.That's because I believe that the factory instructions are usually the best...
Thank you.
Thank you.
ON, CANADA
Has any one had a problem such as described in my post (Goforit) 19983 ?? on the G36 Saito . I would like to talk to any one about this engine .. or maybe some one could direct me to a Saito Guru....some where . Thanks
Re the bearings that were chewing out. At the SAM champs I saw a YS get destroyed because of the following
1/ The crankshaft wasn't correctly aligned with both bearings
2/ The shaft itself was suspect because the threaded end that one attaches the prop to the engine was just and I mean just slightly bent (measuired with a straight edge from the drive washer to the end) which gives pause to ponder if the "bend might not have continued into the engine.
3/ The engine was run extremely lean (yes he had the right fuel mix, 22% oil, 30% nitro rest methanol)
I personally would do a run out check on the engine and if after assembly the engine was down on revs from previous I would consider a re strip and re build making sure the bearings were properly bedded in the crankshaft.
Old Fart, the fingers hurt (a lot) but the experience with Julia's health system (super clinics) or should I say lack of experience hurt more. The mending of the nerves is causing a little bit of angst but easily fixed with Bubdy. Got to get over the cold though -1 up on the Tableland the other day. Global warming bring it on for now
Hi WRM,
When you install those new bearings, don't oil them at first. Assuming that the crankcase and crankshaft are not bent from a previous mishap, the crank's counterweight should fall to the bottom freely. Of course, add oil afterwards (I use caster, myself) so that the bearings are properly lubed before the first run.
Just my $.02
Bob
Just my $.02
Bob
My Feedback: (10)
So I bought this 90R3 to put into a Kyosho FW 190 ( http://www.espritmodel.com/index.asp...OD&ProdID=7954 ), but while the engine will fit inside the cowl, the prop will not be able to clear the cowl. So, I'm going to have to stick this engine in something else. Since this engine doesn't have a ton of power, I was thinking that something in the WW1 time frame would be best. I've found Proctor Enterprises, Arizona Models, & Balsa USA. I've never built a plane (all arfs thus far) but I wouldn't mind trying. Anyone want to suggest something for this engine and a pretty novice builder? ARF, ARC, kit, etc. are all welcome.
It is time for me to give and take, some advice that is.
I have used the Saito 90R3 in a Top Flite Gold Edition Corsair Kit and in the SNJ (AT6-Texan) ARF and it performed very well. I have seen it in other ARF’s designed for a 60 sized engine and where I would go with another. Hanger 9 claims to have put it in the Sopwith Camel.
Friday I am scheduled to receive my new Saito 200R3 which I plan to put in the Great Planes WACO. Has anyone had a chance to compare the motor with the 170R3 besides the sales info posted? I have the 170R3 in my Super Stearman and according to the write-ups they both are 15# airplanes. Anyone have any experiences with the 200R3?
jimm
jimm
ORIGINAL: panhndl
Most of the work of the prop is done by the tips. Try it and see how she flies....
My Feedback: (10)
ORIGINAL: mike early
ORIGINAL: panhndl
Sorry, I should have been clearer. The engine will fit into the cowl, but it will not go far enough forward. The cowl narrows towards the front and I'd have to cut it to get the engine far enough forward. I don't want to do that so I'm going to go a different direction. I know the 90 will fly the plane, but I'd have to get some type of shaft extension to get the prop outside the cowl. Is that clearer?
My Feedback: (10)
ORIGINAL: n6iap
jimm
jimm
Hi Fellows
First, it doesn’t have a plastic backing plate. I didn’t oil the bearings to put them in.
I did tap on the case with a plastic mallet to unload the bearings.
I ran the engine, and it will turn 9800 rpm with a 14/4 APC .
I called Horizon hobby today and asked why the inner bearings had a shield on
them. The man said he didn’t know. But he would email Saito and ask them
to email me an answer. So as soon as I get the email I will post it.
My Feedback: (10)
So has anyone seen the new FA-120R3? Looks like a bored-out 90R3.
http://www.horizonhobby.com/Products...odID=SAIE120R3
Sorry if this has already been discussed, I'm notoriously late to parties...
G'day
I bought a 90R3 to put in a H9 Sopwith Camel but I have put it into a Kadet Senior to see how it runs. It is less powerful than my Saito 56. I will keep it in the Kadet for a while and keep running it to see if it improves as it runs in but I suspect it will always be a bit low on power. I also have a 90TS twin and it is quite a bit better than the 90R3.
Mike in Oz
Mike in Oz
