RE: Welcome to Club SAITO !
ORIGINAL: clytle374
Anyone dare to guess how much power this exhaust is costing me? This isn't mine, but the exhaust is the same.
Cory
Cory
What I would suggest is running the engine with and without the exhaust and measure the RPMs and see what it really does.
with 2 stroke engines I have seen more restrictive exhaust mufflers causing as much as 2,000 RPM drop in performance sometimes more too. But I haven't tried measuring a 4 stroke engine yet to see what happens.
WV
ORIGINAL: earlwb
4 stroke engines do not behave like 2 stroke engines as to how restrictive the exhaust is.
Yeah, 2 strokes won't tolerate back pressure since scavenging isn't positive like a 4 stroke. Not to mention how much easier carb tuning is on a 4 stroke. I'm never going back to 2 strokes, in fact I'm waiting for 4 stroke chainsaws.
I'm kinda tired of working on this plane for now, but sometime I'll take the cowl off and try different setups for comparison.
Cory
OK Saito friends, I finally finished a home for my Saito .40a I bought from MM37 about 4 years ago. I tried the little .30 but the plane was way tail heavy. Using the .40a, putting the battery under the tank up against the firewall and using Harry Higley's Spinner nut and lock nut it is perfect. It hangs perfectly level at 3.5" behind the leading edge. Hope you like my, I'll know when it upside down scheme. I could use my old FA .40 but it looks kinda big on there.
Yes sir, Thanks. It also has a bolt on wing using a single bolt, very easy to do
PS, if it hadn't had ailerons it would have ended up with them anyway, I'm just that way. The entire plane is glued using SuperPhatic from Hobby-Lobby.
Cory,
Using the 90 degree adapter should not result in a power loss. However, the header pipe should not be threaded in passed the bottom of the female threads in the adapter. Doing so could create a restriction in flow. I have many customers using this arrangement with no power loss.
Jim
Jim
WV
ORIGINAL: RC Specialties
Cory,
Jim
Cory,
Jim
Cory
WV
Cory,
This arrangement should not cause any problem. As another poster suggested try it both ways. You should be okay.
Jim
Cory,
Jim
Please don't misunderstand my question. It was merely me wondering if the neat and quite setup was hindering a plane built for power.
Thanks for the easy and free increase in power.
Cory
ORIGINAL: Hobbsy
Love it. Everyone should have a plane with a Saito .40a.
My Feedback: (15)
ORIGINAL: mike early
I use a 13x8 3 blade MA prop on both of my Saito .91s. Favorite prop for that engine.
What RPM's are you getting from that combo? Reason I ask is that I have a used 91 that just got new bearings and a Bowman ring in prep for powering a 72" ws/12lbs warbird and I'm not sure whether or not this is going to be a good choice for this model in the end.
ORIGINAL: frets24
Mike,
What RPM's are you getting from that combo? Reason I ask is that I have a used 91 that just got new bearings and a Bowman ring in prep for powering a 72'' ws/12lbs warbird and I'm not sure whether or not this is going to be a good choice for this model in the end.
WV
Just trying to offer a suggestion. Happy Flying!
Jim
Jim
I'm so happy, I'm sending you a Christmas card this year.
Cory
My Feedback: (15)
ORIGINAL: hsukaria
Nice plane!! Wouldn't 12 lbs be a little heavy for a 91?
ORIGINAL: frets24
Mike,
Very abreviated build thread begining at post #22 here. http://www.rcuniverse.com/forum/m_80..._1/key_/tm.htm
Don't know...I've never really known of a formula for engine to weight ratio, but it would be nice to know as a jumping off point. The plane was supposed to be 60 2c/90 4c and looked a bit over powered in the advert vid. I'm pulling a 8lbs12oz 62'' wing Me109 with a Saito 62 over proped with a 12x8 3 blade and it does pretty well at 7700RPM....was just kind of using that as a basis.
As always; I'm open to insight, suggestions, experience and commentary The 91 is new to me so I'm not sure as to what to expect from it prop and RPM wise.
Thanks!!
Thanks frets,everytime i see someone flying a warbird that ain;t a spitty or mustang is good,specially with a fourstroke i fly a midget with a 115
My Feedback: (15)
I will tach the .91 with the MA 13x8 3-blade. I have before but have forgotten. You will love it.
Thanks, Mike.
My Feedback: (12)
Hey guys I have a question.
I need a new muffler for my 62, 4 stroke, is it 12mm or 13mm?
Where is the best place to find it?
Also I am getting a knocking sound from this engine and I am not sure if it has to do with the broken muffler??
I had a pilot error today and killed my low wing aerobatic plane. I needed about 6 more inches of ground clearance and it wasn't there. The wing is about 100 feet back behind, and with assorted parts in between is the horizontal stab. The battery is where I stood to take the pic. The poor Saito .80 looks to have turned out OK though as the plane came in flat with the landing gear taking the hard hit. A good washing and oiling and it'll be as good as new again. But no worries, I have been flying the plane since circa 1991, and I still have two more like it in the shed I can put together. It was a "Split S" too close to the ground that didn't work.
WV
Ouch, sorry about your loss. At least it had a good life and went out like a plane should. I can't seem to identify the remains, what was it.
Cory
PS the extra 600rpm was a great addition to my Edge today.
Cory
It was a RB-3 design from the early 1990's. It a ARF design with a 1 piece wing (no gluing the two halves together) and has a a balsa and plywood built up fuselage with a foam core wing and is painted. There were three different models, the RB-1 was a flat bottom airfoil high wing, the RB-2 was a Symetrical airfoil sport plane, and the RB-3 was a low wing pattern style of plane. They were made in the Philipines at the time and imported by my best friend. But due to manufacturing problems with the painting they never made it to market.
