Old 10-13-2011, 03:40 PM
  #21051
charlie1960
Yes its the skinny M/A's
Old 10-13-2011, 05:08 PM
  #21052
blw
blw's Avatar
A puller is always good to have around. Yes, both front and rear bearings come out after heating in the oven. Sounds like you are about ready to do anything on engines.
Old 10-13-2011, 06:47 PM
  #21053
STOKEY
How go ya get registered in CLUB SAITO?
Stokey
Old 10-14-2011, 04:45 AM
  #21054
charlie1960
Ive also used a power steering pump pulley remover
to take the drive hub off with.
the puller has two halves and a sleeve that drops over it.
it was the perfect size.
Old 10-14-2011, 06:33 AM
  #21055
blw
blw's Avatar
Stokey,
You need to have a Saito, which you do with your 100. You are now member #774. Welcome.
Old 10-14-2011, 12:59 PM
  #21056
flyingagin
flyingagin's Avatar
I have suscribed to this thread for maybe 2 years now. Learned a lot. But never <span class="Apple-style-span" style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">registered in CLUB SAITO.
I have a Saito .65 I bought NIB right after I got home from the first Gulf War. Still got it. still runs, but down on power. Needs a rebuild, new ring and main bearings. Do you think that is all it will need or will it need more.</span>
Old 10-14-2011, 01:50 PM
  #21057
clytle374
Can I have a number too?
Cory
Old 10-15-2011, 03:33 AM
  #21058
Rudolph Hart
Rudolph Hart's Avatar
ORIGINAL: flyingagin
I have suscribed to this thread for maybe 2 years now. Learned a lot. But never <span class=''Apple-style-span'' style=''font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ''>registered in CLUB SAITO.
How do you mean more what?
Old 10-15-2011, 03:50 AM
  #21059
N1EDM
I think he means whether it will need more work than just bearings and a ring.
Certainly a good cleaning will be in order, and valves readjusted. How about the cam gear shaft? Do those wear, OF? Or is that going too far?
Bob
Old 10-15-2011, 04:30 AM
  #21060
flyingagin
flyingagin's Avatar
<span class="Apple-style-span">
ORIGINAL: Old Fart
I have suscribed to this thread for maybe 2 years now. Learned a lot. But never <span style="">registered in CLUB SAITO.
More parts and more extensive repair, i.e. valve train parts. It for sure has a bunch of hours. Or might I just get by with the bearings and ring.
Thanks</span><span class="Apple-style-span" style="font-family: tahoma, verdana, arial; font-size: 11px; background-color: rgb(251, 252, 255); ">N1EDMyou nailed what I failed to say
</span><span class="Apple-style-span">Sorry I did not make my selve clear
<br type="_moz" /></span>
Old 10-15-2011, 06:59 AM
  #21061
blw
blw's Avatar
We have 2 new members.
Flyingagin #775
Clytle374 #776
Old 10-15-2011, 11:55 AM
  #21062
GaGeeBees
My Feedback: (23)
GaGeeBees's Avatar
ORIGINAL: Old Fart
More cowbell!
Old 10-15-2011, 12:44 PM
  #21063
SigMan
My Feedback: (21)
SigMan's Avatar
ORIGINAL: blw
Flyingagin #775
Clytle374 #776
Welcome Aboard !
Old 10-15-2011, 03:51 PM
  #21064
Rudolph Hart
ORIGINAL: N1EDM
Bob
Hi bob that was kinda tongue in cheek maybe the more experienced members will chime in,none of my saitos are old enough so don't know about cam gear wear but if it moves it ain't gonna last forever.
Old 10-15-2011, 03:55 PM
  #21065
Rudolph Hart
ORIGINAL: STOKEY
Stokey
You need a single digit IQ,if that makes you overqualified we can go halves in minewelcome mate.
Old 10-15-2011, 04:06 PM
  #21066
flyingagin
flyingagin's Avatar
I will get the ring and main bearings ordered after we move in a week or two. Will post accordingly, (i.e. proplems and results)
Thanks all
Old 10-18-2011, 08:31 AM
  #21067
Hobbsy
Hobbsy's Avatar
Barry, sometime in the recent past there was a discussion concernng a poor tank location and the cure for it. The Cline and IronBay regulators were suggested, probably by me. I pulled my old 1991 High Compression Saito 1.50, one of the first sold, out of its box and mounted a Cline regulator.
Saito 1.50
Fuel WildCat 15% 2/4 with 18% full synthetic
Plug===Taipan 4c plug
Prop===MasterAirscrew Classic 18x6
RPM max===8,181
Idle slowest 1,750
I ran 14oz of the fuel out of the tank at various rpm then let it idle the rest of tank out at 2,300, (a realistic flight idle) it took at least 10 minutes to burn the last 2oz of the fuel out at idle. I wanted to see if the tank would stay pressurized until it ran out of fuel, it did. I used a Hobby Lobby metal check valve as the other Cline check valves are on Diesel engines in Tygon fuel line which melts on glow exhaust.
PS, the 18" prop cleared the firewood by .375"
ID:	1675921   Click image for larger version
ID:	1675922   Click image for larger version
ID:	1675923   Click image for larger version
ID:	1675924   Click image for larger version
Old 10-18-2011, 09:00 AM
  #21068
hsukaria
ORIGINAL: Hobbsy
Saito 1.50
RPM max===8,181
Idle slowest 1,750
PS, the 18'' prop cleared the firewood by .375''
NICE PICS, HOBBSY. You can put a bigger prop and use it to chop your firewood, winter is coming.
Since I am not experienced with pressure regulators, what would the engine have done without the regulator? Would it be mostly for correcting a badly located fuel tank?
Old 10-18-2011, 10:34 AM
  #21069
earlwb
earlwb's Avatar
ORIGINAL: hsukaria
Yes it can help correct a bad location for a fuel tank. But they originally went with a pump and regulator to allow for more performance out of the engine. if the engine doesn't have to draw its own fuel, you can open up the bore for the carb or venturi and get more power out of the engine. Plus with constant pressure, you can set the needle valve more closly to peak RPMs as it will run the same on a full tank as it will on a low tank of fuel. the pattern flyers were arguably the early adopters to go with the fuel pumps and regulators on their engines.
the pump and regular is similar to using a bladder or crankcase pressure (timed or untimed) to allow the same performance gains on the engines.
Old 10-18-2011, 11:51 AM
  #21070
frets24
My Feedback: (15)
frets24's Avatar
Is an FA-91 going to be enough motor for a 12lb, 72"wingspan plane? This bird claims to be a 60 (2c) plane but it sure seems to be about on par with the likes of an ESM or KMP 120 plane.
Is there any kind of "rule of thumb" for sizing engines by plane weight or span?
Also, the link I used to have for a thrust calculator is NLA; Does anyone have a link to any kind of engine/prop thrust calc?
Thanks!!
PS; by the way, this FA-91 is turning an Evolution 14x8 prop @8250rpm on 15% nitro-18% castor/synth cool power
Old 10-18-2011, 12:11 PM
  #21071
Hobbsy
Hobbsy's Avatar
Thanks H, I can respond to you and Earl both by saying it can cure a too high tank or too low tank problem and also make it possible to put the tank on the CG which was the original intent. And, Earl is correct, you can run the HS needle closer to peak. I had a Saito 2.20 that came with the large carb option and the crankcase pump to pressureize the tank by restricting the vent output. That system was very hard to get a suitable adjustment, the IronBay regulator worked with the large carb option much better and required no adjustment.
Old 10-18-2011, 12:47 PM
  #21072
hsukaria
ORIGINAL: Hobbsy
I suppose these regulators would help with glow engines that are converted to gas since the gas fuel flow is lower and the muffler pressure is not used to pressurize the tank? I'm thinking of conversions that would keep the glow carb instead of going to a Walbro pump carb?
Old 10-18-2011, 06:20 PM
  #21073
flycatch
My Feedback: (26)
I have a Saito 1.8 FS that stops running when the igniter is removed at 1/4 barrel setting. It runs fine at WOT and half throttle with the igniter removed. I'm stumpped.
Old 10-18-2011, 06:29 PM
  #21074
Hobbsy
Hobbsy's Avatar
Low Speed needle too rich, set HS needle at full peak, then lean LS needle 1/8th turn at a time until you get about a 2,000 rpm idle, be willing to sacrifice a few rpm in favor of the best transition. Fly it at about 2,200 rpm idle.
Old 10-18-2011, 06:37 PM
  #21075
flycatch
My Feedback: (26)
Thanks for the reply. I'll continue on taking your suggestion has my first step. I'm new to Saito engines since I have been using OS. I guess there is no secret they tune the same way except for YS.
