RE: Welcome to Club SAITO !
ORIGINAL: Hobbsy
Earl, what initial does that one have on the right mounting lug, Thanks, Dave
AL
Hello All
I have followed this thread for quite a while, and now find myself in serious need of the wisdom of this group.
I clocked a tree with my Saito Twin powered Super Sports Senior four months or so back..As Forest Gump would say, 'Stupid is as Stupid does'...The tore out firewall, destroyed wingtip, limb spearhole through the fusalage, busted formers, popped glue joints, ruined covering, and tore up rudder cables have been restored, leading and trailing edge roots all healed up and now this........HELP!!!!!! I just discovered that i severely wounded my nearly brand new (long hoarded away) Saito FA100T in the crash. Tonight, while reinstalling the engine, i discovered that the carburator mounting studs have snapped off the crankcase. (See photos) Sickening....Please guys help me come up with some way around this! There looks to to me to be considerable 'meat' below the ends of the allen screws to drill and tap longer mounting screws with spacers to remount the carb(s). Machine work that is above my paygrade to accomplish. I am really in hopes someone can put me on the trail of a good man that get me past this showstopper.
Hate to think about trying to find a crankcase. That is, if there is one out there. I bolted the motor up and rushed it across the test stand after the crash. Fired right up and idled smooth as a kitten. Course it would die soon as i put the fuel to it. Wrote that off as post crash bad needle settings/possible trash in fuel lines since there was no apparent damage and it idled ok.. Thought no more while i went about rebuilding the airframe.
Thanks, Steve
Thanks, Steve
Been there and done that.
New Crankcase $88
http://www.horizonhobby.com/products...e-aa-SAI100T15
Rear bearing $19
http://www.horizonhobby.com/products...00t-SAI100T22A
Front bearing $14
http://www.horizonhobby.com/products...00t-SAI100T20A
New Crankcase $88
Rear bearing $19
Front bearing $14
I would ditto what W8ye stated. Looks like the crankcase is on sale, so you probably want to get one right away before they sell them all out.
But if you wanted to, you could carefully clean off the oil and dirt from the two broken studs, crankcase and use some JB Weld epoxy to glue them back on with. You can build up a little dam to help contain the epoxy while it cures around the studs using masking tape or wax even. Then you reassemble the carb on the engine with the studs and let the epoxy cure real good for a couple of days. Anyway that would hold for quite a while until you feel like changing out the crankcase.
AL
Thanks for your insights! Called Horizon this morning, apparently that motor is still in production and they said that the crankcase is a current inventory item. 10 in stock and they said there were more avaliable so it appears i am safe to wait till after Christmas to deal with it. Reasonable on the price considering the piece. You think i might have flat spotted some bearings in the process? Will send the motor to Horizon and let them sort it out i guess. Thought about the JB weld thing, but in light of other possible internal injuries i guess it is best to send it in. You think?
Even though I feel comfortable with me making the repairs I find when I send it to them it can cheaper. They can test and know what really needs repaired/replaced and you get a guarantee. Couple of years back I did an inadvertent landing using the right hand side of the aircraft instead of continuing the base leg of approach. It ripped out one of the 170R3 jugs and they fixed it in a couple of weeks for less than what I was going spend for the parts I was going to order. Motor still running fine in the new Super Stearman. BTW, only thing I salvaged on SS was rudder and landing gear.
My experience and opinion.
jimm
jimm
AL
It's boxed up and ready to kick out the door. Brand new motor. Frustrating, I haven't tore up and airframe/engine that bad in years. Oh well. As they say, if you can't stand a crash.you are in the wrong hobby.
Yeah I can understand your thoughts about it. I have wanted to get a Saito 170 or 200 radial engine for a long time now. I have a big Gee Bee plane I want to put it in too. But after spending all that money to get the engine, I really hate to see what would happen if I had some sort of a failure and crashed it real good. So I have procrastinated on getting the radial engine.
I had a Saito 182Tdp twin given to me that had one flight on it. Guy crashed the plane, broke the engine, and sent it to Horizon for repair.
As usual, they sent it back to him saying the repairs needed were too expensive, so he gave the broken engine to me.
I repaired it for $375. It is a nice one. But I'm almost afraid to fly it.
I'm lucky and have both the 182 in a taylorcraft and the 200 radial,which is yet to fly in an at6 texan.Other pilots really enjoy hearing the sound the 182 makes in flight.
<div style="margin: 0in 0in 10pt"><span style="line-height: 115%; font-size: 9pt">This is a thank you note to those that gave their input when I was trying to fix my crashed and broken FG36. In the crash the rocker arm bracket was broken off. The bolt that held it was sheared even with the top of the head.
You-all gave several good methods to remove the broken part f the bolt. The one I settled on was to drill out the center of the bolt. (That was difficult to stay dead center but I managed) Then to use a right hand drill bit to get a bite on the bolt and to back it out with the drill. I applied heat and a mixture of (acetone, lacquer thinner, and MEK) to soften up the red lock-tight type material that is on the threads. It came out nicely without messing up any threads in the head.
Thanks again.</span></div>
Anyone who owns a Saito FA-80 GK version;
I'd like to see some real life pictures!
Was the FA-80GK such a *best-seller* as the standard version;
I used the GK version engines on some prototype ARF planes to make them look good. The planes color scheme matched the engines really well. But for my personal engines I tend to use the regular plain aluminum color engines. Unless I had a plane that the engine would look good on, I didn't see any reason to get the GK version. Especially if the engine is enclosed inside a cowl, it didn't make any sense to hide a GK engine like that. I do have a plain Saito .80 but no GK version.
ORIGINAL: Kostas1
MI
how do you install Satio upgraded caruretor rebuild kit (sai150s144) they are some medal washers and spacers I have no idea where they go
MI
MY old Carb didn't have these parts in it. I had a spring like the small Saito carbs have. I though upgrade rebuild kit was new and I don't know where these parts go.
W8ye,
I also used to just order from horizon,but also a lot of people
saying go to boca,just wasnt sure if the bearings are of the same
quality or not wondering why the prices are so different?Thanks for
your thoughts.
Ty
your thoughts.
Ty
