KMP F-7F Tigercat
#2126
RE: KMP F-7F Tigercat
Hi Flytail. I have been downloading many many pictures on this thread for over 3 years with no problems. Just recently having trouble and I think it's RCU. I'll try a download on this message. Chuck PS Just realized I changed cameras and don't have it set up correctly. DUMB Chuck...
#2127
All you guys have to see this site, if you like Scale details check this:http://www.iflytailies.com/
Doug Styles
http://www.aerogasrc.com/
Doug Styles
#2128
PA
I have read almost every page,and I have a couple of questions.<div>1..I purchased the esm f7f. About 1 year ago, is it close to the Kmp...ASM. Kits.... As far as quality and construction?</div><div>
</div><div>2..the retracts that I got from esm look sturdy and adequate for this aircraft,does any one have first hand knowledge of these retracts,again I got them about 1year ago from esm from a dealer in Fla.</div><div>
</div><div>Thank you for any input you can give me. I. Plan on diving into airplane assembly in the next few days,I have almost every thing I need to complete this project.</div>
#2129
ORIGINAL: gbauto1
If you can keep the model light , the stock retracts are somewhat okay. Most of the models weigh 27Lbs plus. Long term these will not hold up depending on your field and few other factors. I have Sierra's for mine and that's the best money can buy for this model, Plus Darrel at Sierra is fantastic to deal with on service. Helpful hint on your build, Go through and check all glue joints. Many of them need attention.
Cheers,
Doug
#2130
PA
Thank you for the info..rcnut101...I was thinking about the sierra's.I believe that when installing the Sierra's there are concerns with fuel tank size.I have two new in the box dle 20's that I plan on using, any suggestions or recomendations? Thank you very much for taking the time to respond to my quaaestion's<div> Jason.</div>
#2132
ON, CANADA
The version 3 ESM extracts are available and resolve much of the earlier issues. Best to contact Troy built to get more info. Built heavy is right and compared to other models other really is no need for all this weight.
Checking glue on an ARF is standard. Then having fun flying the heck out of it is the next step.. Enjoy.
#2133
ORIGINAL: gbauto1
The Fuel Tank that I used is a Sullivan SUL390 from Horizon Hobby. It fits on the bottom of the nacelle. Its 16oz. It will give you plenty of run time.
Cheers,
Doug
#2134
My Feedback: (57)
Has anyone put a full body pilot in their T-Cat? I am just finishing my 2nd all composite variant with a Dynamic Balsa cockpit. The seat is only 2.5 inches wide. I am having a hard time finding a 1/8 scale pilot to place in this ship. It just won't look right without one. Any suggestions would be greatly appreciated! Thanks!
#2135
ON, CANADA
My Feedback: (57)
Maiden Flight a Success!
I maidened my new Cat yesterday and it was a huge success! The airplane required 0 trim and flew like it was on rails, even better than Cat #1! The OS GT22 engines proved to run very nicely, however, I will do some more experimenting with different props as she is not quite as fast as my first. I flew it with Xoar 15x8's. The RPM just isn't getting up to the level I need to achieve the power band that I am looking for. I'll try some MA 14x9's, that may just do the trick. I did get 2 successful sorties on her and everything worked as advertised! I can't wait for the next sortie!
#2138
My Feedback: (57)
Three more flights on the cat this past weekend. I have to say that this plane flies wonderfully well and even a smidge better than my first. THe Master Airscew 14x9 3 blades really make this airplane fly fast with authority just as this ship was intended for. The OS GT22's really sing and run like swiss watches. Very reliable with very little draw from the ignition packs. 3 nine minute flights flights only consumed 360 MAH from the 2000 MAH 5 cell packs. Much more efficient than the Zenoah 20's in the first one. I was also able to get about 15 degrees of additional travel out of the flaps allowing for a very reasonable approach speed. I pulled 8 oz of lead from the nose with no noticible change in handling qualities. She is still portly at 33 pounds dry but doesn't seem to bother it all. A great machine. Time to move T-Cat number one and find a new home for her.
#2141
My Feedback: (57)
Well, I haven't looked. The supllied tubes are certainly robust enough. They do weigh more, however, this airplane really doesn't care if set up right. I have certainly put mine through some very aggressive paces using a 3 piece wing setup without any issues. I have nearly 200 flights on that particular model.
#2142
My Feedback: (31)
CRJ, my thought was the potential to save a considerable amount of weight. The wing tubes that came with mine are an odd size and to date I have been unsuccessful locating any in carbon. I will stay on the hunt.
#2145
My Feedback: (20)
Finally finished....except for the gear doors.....
27 pounds DLE 20's. Four Flights so far...
http://www.youtube.com/watch?v=hqR03ST2IxQ
Take off
http://www.youtube.com/watch?v=IvBNW5kqqi0
Flypast
http://www.youtube.com/watch?v=f2bzRfSHx6w
Landing.
Take off
Flypast
Landing.
#2146
Warbird Fly-In at Fresno CA. Sat. 5 Oct. Great weather and a very successful event. Had over 50 War Birds from all eras. Some were Glow Engines, Gasoline and Electric. My F7F was the only TWIN there. It was a crowd pleaser. I really enjoy flying this airplane. The High Speed runs from a steep dive and hearing those twin Fuji's humming still THRILLS me. I can do most basic maneuvers large and smooth and it is really pleasing to the crowd. Many nice comments from the spectators and especially the women. Col. Chuck Winter
#2148
I have the original version of the F7F and I'd have to say I was the first to put two 170r3 is this airframe. Mine balanced perfectly. I also have the Sierra gear too which are a bit heavier than the stock.
If sounds really great.
http://www.rcuvideos.com/item/LTP0M8PLQVXN7JRN
#2149
Hi Tigercat Guys. My pictures in the above post where THERE and now they have been replaced by Attachments that don't open up. I will try again to Post some pictures.
Flew my Tigercat at Fresno War Bird Fly-In last Saturday. There were about 50 War-Birds of all sizes. Gasoline, Glow and Elec. I had the only twin engine there. Col. Chuck Winter .
