New Carden Yak.
#202
RE: New Carden Yak.
I got a new CF tailwheel from Pete's Models for the Yak. It's the new one he just started shipping for the larger planes. It looks nice. And the weight is very light, about an ounce lighter that the Graphtec CF tailwheel on my 33%. Very helpful as I'll be installing the rudder servos in the tail and I'm trying to keep the tail as light a possible.
Also, the "Smart Tool" is a real handy tool to have in the shop. I borrowed this one from a friend to set wing incidence and have been finding a lot of uses for it. I set up the motor thrust with it as well. Displays to 1/10th of a degree. If you don't have one buy one (or borrow one like me )
............Mark
............Mark
#204
RE: New Carden Yak.
http://www.geocities.com/pierrejac/ Pete's tailwheels are fairly new so they are haven't made it to his site yet. There's a contact e-mail on the site. Great to deal with.
Also, it looks like Troy Built has them on their site. Gene's great to deal with as well.
http://www.troybuiltmodels.com/TailWheels.htm
FWIW. The wieght on Troybuilts site seems over stated. Pierre told me 1.6 oz and my scale says that as well.
It looks to be hollow which I'm sure is how he kept the weight down. I have some rubber backed conical washers that I plan to use to keep it from distorting when I baton it down.
.........Mark
.........Mark
#207
RE: New Carden Yak.
Yes, I'd say it is based on the size of the wheel itself. I got mine directly from Pete Models. Peirre calls it the heavy duty one, Troybuilt lists it by plane size. Agian, not sure on the weight listed on the TBM site as it's only 1.6 oz. I've got mine all mounted. Looks great.
..........Mark
..........Mark
#209
WA
RE: New Carden Yak.
Its funny to hear all the coments about how it doesnt look scale. RC yaks are far from scale. And like said earlier if it were perfectlu scale it would fly like crap. Not to mention a scale yak wil do a fraction of the things as rc yak will do. Has anyone ever seen a full scale yak do a waterfall to inverted harrier to roling harrier? I dont think so. If your in to perfectly scale airplanes get ouy of aerobatics and build a cub and enter the TopGun. I personaly dont fly giant scale aerobatics for the scale aperence. I fly them for there exelent flight ability and the NON sacale things they can do. Just my 2 cents. By the way didn't Quique get protested in a event about yaks not having wheel pants? If i remember right he proved that some do have wheel pants and was not disqualified.
#210
RE: New Carden Yak.
ORIGINAL: OnTheEdge
I just visited Ivan's site last night and sent the same landing gear photo to a friend of mine who does machine work. His message this morning said, "send me the gear"
Did you weigh your Yak gear yet? Mine came in at 27.5 oz. Hopefully my friend can shave 8 oz off of it for me.
#211
RE: New Carden Yak.
What are you guys doing to be able to reach the front wing bolts on the Yak? The tank is in the way for the most part. It'll get worse as I'm making a removable tray for a smoke system where the smoke tank sits right next to the fuel tank.
Anyone try wing nuts or the like?
Thanks............Mark
#212
IN
RE: New Carden Yak.
ORIGINAL: OnTheEdge
#213
RE: New Carden Yak.
I know a few guys have done the wing nut thing. they permanently install the bolt in the wing panel and then slide the wing on and use a wing nut on the inside of the fuse. works great the only complaint Ive heard is you have to be careful when putting on the wing not to tear up the fuselage with the bolt.
Pete
Pete
#214
RE: New Carden Yak.
ORIGINAL: luv2flyrc
U need all the right equipment, including but not limited to the spray guns and paint equip. work benches that are straight and can support the weight needed to sheet the foam parts, the skills to align everthing and the equip. to do so accurately.
..........or the smarts to have a pro build it.
Walt it going to build a Carden 260 for me. Needless to say, I am really looking forward to it.
His work is amazing.
#215
RE: New Carden Yak.
Here's what I ended up with to solve the wing bolt problem (i.e. not being able to get a balldriver in there). A friend of mine made me a set of aluminum thumb wheels. They turned out awesome. I can get in there very easily as the size is just right and the knurls <sp>
are sharp enough to get a good grip on. They are very light and only about seven tenths of an ounce heavier (for all four) than the regular S/S caphead screws that I use on my Extra. Anyone else with the Yak might want to look into something like this as I could'nt imagine a quicker way.
............Mark
............Mark
#216
RE: New Carden Yak.
The washer on the back is a conical shaped washer with a rubber washer attached (found them at Lowes). I've used these before to prevent the screw from backing out from vibration.
#218
RE: New Carden Yak.
ORIGINAL: zzw26n
Edge,
I'll take two sets, how much??
thanks Ward
Edge,
thanks Ward
...........Mark
#219
RE: New Carden Yak.
Well, I got the gear back from being polished and the hatch glassed in (Thanks again Albert!) so it finally looks like a plane. Some final sanding and I'm ready to start covering. Can't wait to get this thing finished and in the air.
...........Mark
...........Mark
#222
My Feedback: (45)
MI
RE: New Carden Yak.
ORIGINAL: OnTheEdge
Let me check with Jim and see if he'll make up some more and if so how much. By two sets, do you mean two pair or four pair?
...........Mark
ORIGINAL: zzw26n
Edge,
thanks Ward
Edge,
thanks Ward
...........Mark
Mark, Your right, four pair.
thanks Ward
