Carl Goldberg Ultimate 10-300 Brotherhood.
#2227
Hi.
I am starting to strip a Goldberg Ultimate. I would be interested to hear from guys that have done it. It has a glued on canopy and the great planes mesh style hinge material. did you cut the control surfaces off the plane and re slot the hinge? I would like to replace the hinge with robart pin hinges,can it be done easily with the bevels done?
will the canopy glue loosen up with heat?
Any tips on getting the blue ultracote that stains the wood off? the covering came off easy but it has stained the wood, head gun and razer blade scraping does good, but?
thanks
thanks
#2228
Hi.
thanks
thanks
Be ware with the heat, it could distort the canopy badly!!!
I would try with a sharp blade and patience.
#2229
Hi. I'ts been a quite some time since I've been here (life and other models in mean time) ![Smile](images/smilies/smile.gif)
Finally, I've been able to fly my Ultimate (this one http://www.rcuniverse.com/forum/12099049-post1746.html )
After some troubles with the engine (Saito 120), probably caused by long time not being used, I've finally made it to run.
What a surprise - after many years (it's the older version of this engine) it run perfectly.
i've had no excuse and had to fly the bipe![Smile](images/smilies/smile.gif)
It flies great and stable! The only issue I have is the wire landing gear, that flex a lot during landing on the grass.
The last flight ended up with the nose over and broken vertical and stab.
Any chance, someone could take the dimensions of the original landing gear skirts? I want to make the landing gear stiffer before next flights.
Thanks in advance!
Thanks in advance!
#2231
The current stuff sticks only with a blowtorch...
...but it peels off just by looking at it!
#2232
The wood around the Cabanes is broken making big holes . I put the Cabanes in then taped around them. Then took them back out and used epoxy and glassed over the holes on the inside and using the tape as a template on the outside . I will cut the glass and give it a nice slot for the Cabanes again.
After I remove the tape I have to fill it with something the ultracote will stick to. Epoxy and microballoons will make a nice filler but the covering won't stick to that.
Any suggestions?
I painted the frame with balsarite already.
Going to fit the new engine today
I want to add some flying wires..
Thanks in advance!
Thanks in advance!
At least here in Spain it is quite easy to find such a gear with a very close size to that of the CG Ultimate. My own one is the RTF version which mounts an aluminium gear; it is stiffer than the wire gear but you still have to make sweet landings for not bending it. Anyway every four or five landings it always need some sort of straightening!.
If you would like the alu gear size just ask and I will measure it for you.
Best Regards.
#2237
Hey guys. I have a CG Ultimate.90-1.20 ARF. I built it 20+ years ago when I wasn’t the best pilot (I’m still not lol). I went overboard and spent too much making it the pride of my hanger. Coreless servos, pull pull rudder, and the real wallet crusher a O.S. Gemini 1.60. I have/had so much money into 1 plane for a 21 yr old I was afraid to fly it.
The day of its maiden I only got 2 flights out of it before it went deadstick too close to the ground to blead off speed or go around. I was forced to skim it down the runway and finally nose the prop into the ground to stop before hitting a parked vehicle beyond the runway. Lucky there was no damage but the carb was full of dirt so that was the end of flying that day. The carb was cleaned and engine tested. All was well but it didn’t fly again for 20 years. I finally pulled it down from the rafters, freed up the engine, replaced the FM receiver for 2.4ghz installed new batteries and a glow driver and sent her up. She flew great but needed a decent amount of trim. I decided to adjust the clevises instead of adjusting the sub trims and broke a 20 yr old plastic clevis. Time to replace all of them before it’s next flight. What other upgrades should I consider to improve on an already great plane.
I will I’ll try to go back and read the whole thread but that’s A LOT of reading.
Only a few landings 4 to be exact, and the gear mount was coming loose. One more landing would have probably cause he gear to rip off. I’m sure skimming across the ground at high speed the day of its maiden didn’t help but it wasn’t a hard impact. The last 2 from a few weeks ago were smooth as can be. But the plane is heavy with the motor. The gear actually spreads out as you set the plane down by hand.
BTW it has unlimited vertical at 1/2 throttle lol.
#2238
I bought a hanger queen with a Gemini 120 on it. It flew well, but same as yours the clevises broke, thankfully not in flight. I replaced them all and ran glue into all joints I could reach as it was built using CA and had turned brittle. I lost the plane due to the throttle arm screw coming loose, so make sure yours is nice and tight! These planes do not fly with a tail wind when dead stick.
#2240
I checked the hinges on all of my planes after my Extra almost died a misarable death due to a aileron hinge coming out. I have many flights on that plane. Life took me away from the hobby for quite a few years and the planes sat collecting dust. The extra was the 1st to see daylight and after about 6-8 flights I noticed the ailerons weren’t responding too good. I figured a servo went bad. When I landed only the outer hinge and the control linkage on the right wing were still attached.
Id also like to get a new cowl for the Ultimate if I can find one. When I cut the original out to fit over the engine I misjudged where the cowl would end up and have extra large openings for the heads. It doesn’t look terrible but it is still the pride of my hanger. I want it to look as good as it flies. I’ll post pics when I can. I don’t have enough posts yet.
#2241
#2242
It has the aluminum gear. I was thinking about either adding a spring pulling the wheels together or just a cable from side to side to prevent the sag. A carbon fiber does sound like a good idea though. I’ll look into that.
#2243
![](https://cimg5.ibsrv.net/gimg/www.rcuniverse.com-vbulletin/2000x1504/c6a3a588_a593_44b1_ac63_5c0f26e17549_0b15108388d91494e2541dac1d24613981e2a531.jpeg)
#2246
I just re-maidened my Ultimate today. I changed elevator servos (S9001) to the tail and removed the heavy pushrods. I also went with the "hot dog" throws from the manual, WOW.
I kept the 77grams of lead I installed inside the tail, Saito 125 in the nose. AND I BUILT IT LIGHT.
I think I could go even with more tail weight, but enough for now. At this point it removed some of the up trim elevator, but not all of it. I aligned wings and tail with the incidence meter when I built it, so it's the CG.
I don't remember my exact CG with both wings attached… …last times I just measured a "relative" CG with ONLY THE BOTTOM WING ATTACHED.
My CG was at 90mm from the bottom wing leading edge, ONLY WITH THE BOTTOM WING ATTACHED.
Now it went back to 96mm from the bottom wing leading edge, ONLY WITH THE BOTTOM WING ATTACHED.
PS with the "hot dog" throws I could do a flat spin and knife edge loops.
But I couldn't get it to lomcevak. I'm using an APC 15x8 with the Saito 125. Maybe with the APX 16x6 it could do it….!!!
PS2 I'm also flying it with JETI now!!!! Great choice!
#2247
How are you compensating for the weight of the top wing? If you want the perfect CG, use a Vanessa Rig with the plane fully assembled. I gave up trying to point balance planes, especially when they tend to slip off prior to getting the weight placed for balance. Before I lost mine to the throttle arm coming loose on the carb, mine was balanced to the point no trim was needed and it flew great. l may get around to rebuilding it some day, both wings survived, only the points where the wings attach to each other snapped off, and the fuse is intact from cockpit back, most of the front structure is there, but cracked. The wood was pretty much fuel soaked when I got it, so most will have to be replaced anyway. It was a fun plane the couple times I flew it.
#2248
I use the simple CG machine from Greatplanes...
https://www.towerhobbies.com/cgi-bin/wti0001p?I=LXK259
Before the first flight (years ago) I measured CG WITH the top wing.
Much later, when shifting the CG back for fine adjustment, I just measured WITHOUT the top wing, as I just wanted to measure the CG "shift" and not the actual CG. So I do not compensate...
Sadly I forgot to write down the first CG position so I don't know where it is "now".
I only know it is 6mm (1/4in app.) to the back as before...!
I normally place the first CG in the middle of the suggested range...
I flew the plane yesterday and I'm sure it can handle even another 1/4in (6mm) to the back...
Saudos,
Jean Paul
Saudos,
Jean Paul
#2249
Bold and beautiful colour scheme warbird_1. I love it!
As for the CG the Ultimate is quite tolerant. It should even be safe at the rearmost position on the plan. Just be aware that if you go further back than the CG range shown on the plan you’ll need to keep the speed up(relatively) on landing, or it WILL drop a wing(two
wings?).
I usually start with the CG in the middle range and move it back in small steps ‘til the plane holds a inverted 45 degrees upline without pilot input.
I them measure the CG for future references in case of repairs or modifications.
wings?).
