ORIGINAL: Ernie Misner
Just curious, I haven't heard of anyone ordering from RC Bearings lately. Aren't these FA 80 prices considerably cheaper?
http://www.rcbearings.com/saito-80-bearings/ Ask for Paul
Thanks, Ernie
Thanks, Ernie
Stainless steel bearings are hardened to the same range as bearing steel. so wear really isn't an issue.
My standard bearings are what everyone else calls high speed. We use the high end Japanese plastic retainers for most of them and we also now have European made SKF Explorer bearings available for most engines. SKF prices are about the same as their no-name OEM bearings.
ORIGINAL: rowdyjoe
Stainless is harder but, more brittle than other steel alloys. I went with stainless to reduce the chance of corrosion.
ORIGINAL: SrTelemaster150
JNorton was right. SS is softer than carbon steel, but it is tougher. It resists corrosion & in rifle barrels, it also resists errosion in the throat from hot gasses. It can also be harder to machine.
High carbon steel is harder & more brittle than SS. I much prefer high carbon steel to SS if knife blades. SS is harder to get a good edge on & it doesn't stay sharp as long . When corrosion is an issue, like razor blades, SS cutting edges last longer.
ORIGINAL: JNorton
I believe SS is softer than normal steels. Just my two cents.
John
John
ORIGINAL: rowdyjoe
>>> i purchased a turbo header prop for my saito fa 125, glow, and it stripped the threads on the crankcase. >>>
Turbo header "prop" or muffler? Stripped threads on the crankcase or in the head?
Previous threads on the fitting of new bearings: do you guys mean proper installation, getting them in straight, no galling, or do you mean actual tightness of fit as they sit in the crankcase? If they are too tight how do you correct that?
Thanks, Ernie
Thanks, Ernie
My Feedback: (18)
ORIGINAL: orthobird
If you're referring to a Turbo header muffler stripping head exhaust threads, I'd say it was improper installation. I have a few and never encountered any problems. Just make sure that you thread them on carefully, that they are tight, not overly, or not loose either. You can't crank them down because you are dealing with aluminum.
Bob
My Feedback: (9)
I bow to the knowledge of the metalurgists/experts on the issue of stainless steel hardness vs. carbon steel. I speak from my 22 yrs experience in the aircraft mfg. industry but, not as an engineer. We made BIG airplanes (C-17s, 747s, 767s, 757s, 777s, 787s, Gulfstream IV & V wings, B-2s) and some smaller ones ....FA-18 A, B, C, & E, F-5, T-38, and some UAVs. Also made some rotary wing aircraft you may have heard of like the Blackhawk.
I have to disagree concerning stainless firearms barrels and chambers. I've had a few and still have one. Chrome is the cure for chamber and barrel errosion and better functioning. Stainless is more pourous, traps more crud, and requires more thorough cleaning IMO. However, it is better for corrosion prevention but, not as accurate as a chrome lined bore and chamber. On this issue I have 20 yrs experience as a military firearms specialist.
RJ
RJ
ANybody got an intake manifold for an older Saito 180? <div>The nut / ferrel on Mine broke away from the cast aluminum pipe. J-B weld might hold it. Horizon has 'em on back order. </div>
NY
I am about to install a perry V-30 fuel pump with my sa100. I have seen the diagram for installing the perry with with saito engines. My questions is the my tee does not have 3 straight legs, but instead the tee- leg going up into the perry pump has has bend that turns it to left, and folks think that this bend will interfere wtih the performance of the perry pump?
ORIGINAL: RC-Bearings
The stainless used in knife blades is a very different type than used in bearings.
ORIGINAL: JNorton
John
John
ORIGINAL: rowdyjoe
Yes the knife alloys would be different. I never meant to imply that they were similar.
However, your previous post tends to prove the softer (more ductile) nature of SS over high carbon even when treated to the same (Rocwwell?) hardness.
Bearing stainless (440C) is hardened to the same range as bearing steel and is very ductile compared to high carbon steels.
Again, not a direct comparison to SS use in bearings, but it still proves that SS is not always "stronger".
I don't believe the steel in rifle barrels is heat treated to enhance hardness/toughness. (unlike receivers & bolts, etc) The heat of hot propellant gases soon negate any advantages of heat treating. They are treated for stress releif however.
ORIGINAL: rowdyjoe
RJ
RJ
What do you Saito 100 owners think of them? A real sweetheart like other Saito's such as the 82? The reason I asked is I am super happy with my 82 and 125 and was thinking of picking up a 100 for use on the 60-90 size profile planes. Reading the reviews most are positive but some say the 100 has excessive vibration (at idle I think) Immediately I thought, yeah learn how to tune them.
Thanks, Ernie
Thanks, Ernie
Thanks guys. Looks like Saito is offering most everything in a gas version now. Maybe I'm behind the times but I'm still thinking that on the 82 or 100 size and real light profile planes that I don't want the weight of the ignition system. What do you guys think?
Thanks, Ernie
Thanks, Ernie
My Feedback: (32)
Hey JonC:
You sure do not need 30% Nitro glow fuel to make your Saito 100 run well ! 10% is more than adequate. Have been mixing my glow fuel for many years. I f you don't care about the cost of 30% fuel then by all means burn it up. I mix 10% Nitro fuel for less than $9 / gallon. My fuel has 10% Nitro, 20% oil (10% castor oil and 10% Klotz Techniplate). The castor oil is an excellent lubricant but requires that you use some automatic tramsmission oil as after run lubricant and preservative if the engine is not going to be run the next few days. Nitromethane is the most expensive component to date, costing $40/ gal. There are several synthetic oil's available that will work. There are alot of fellows that use as little as 15% oil. My Saito's and HP 49's have been running for 25 years now on 20% oil and the cylinders are bright and shinny showing no signs of wear. I hear alot of "boo-hoos" because of the cost of glow fuel sometimes $16~$20 /gallon. For that reason there has been a big switch to electric. I have a few electrics but they just aren't the same. Too quiet! No motor sound !! Four strokes sound great and are easy on fuel compaired to 2-cycle motors. Many of the guys in our area clubs have gone to gas! Gas motors perform well and are relatively inexpensive to operate. I do not burn ethanol laced pump gasoline in my gas motors. I use aviation fuel and good chain saw oil. AV gas has tetraethyl lead in and preservatives in it that will not screw up your carburator. At $5.50 a gallon, it is still the best pick for a good running 2-cycle gas engine. On of these days I may try a FG series Saito 4 stroke that runs on gasoline/oil mix and has an ignition system. Maybe when I grow up!!
Thanks, Ernie
Thanks, Ernie
The weight of the ignition system will be offset by the reduced fuel requirements.
That being said, it will be cheaper & more reliable to just buy an FA version & convert W/a C&H conversion. Much better, easier to deal with system.
i have had several full scale pilots tell me that AV gas leaves alot of ash, i have used both AV gas and 93 oct pump gas and have seen no difference in performance. i always thought it was due to the low compression (9:1) of rc gas engines. correct me if i'm wrong, i live right next door to an airport and don't mind paying $5.50/gal, i just don't wanna hurt an expensive engine for a little more push. i have no use for the lead, the oil i use is Lucas semi-synthetic 2-stroke, it also has fuel stabilizers in it. there's no replacement for displacement, if the engine on my plane doesn't quit do it for me, i get one bigger engine. i run saito/ys 20/20 fuel in all my saitos, even though i mostly fly 3d, i do not push an engine by running hotter fuel.
How do you install the magnet in the prop hub? Purchase that along with the ignition?
The beauty of the C&H systems is that the hall sensor is mounted fixed on the cam housing while the magnet is in an infinately adjustable magnet ring that afixes to the prop hub.
So much easier to set up & adjust.
Here is a thread I posted about [link=http://www.rcuniverse.com/forum/m_11163452/anchors_11163452/mpage_1/key_/anchor/tm.htm#11163452]CONVERTING MY FA91S TO C&H CDI[/link].
An FA100 uses the same prop hub ring as an FA91S & the hall sensor mount for the FA300 fits the high case cam housing of the Fa100.
You should be able to get an entire system including a spark plug from C&H for about $125. Before you convert to gasoline, you might want to try just running CDI W/glow fuel. It will give you impressive fuel savings, (about 25%) much better handling chatacteristics & a power boost.
You will gain about 5%-6% more power W/CDI/glow fuel, while CDI/gasoline will result in about a 15% loss in power. over the standard glow ignition engine.
If you peruse Saito's power ratings, the FG engines put out about 15% less HP than their glow counterparts. (FA220 = 3.5 HP, FG36 = 3.0 HP) That is why Saito is increasing the displacement of the muti-cylinder FG series of engines over the FA versions. (50cc FA300, increased to 57cc FG57)
The power advantage of CDI/glow is 21% more power than CDI/gasoline for the same displacement engine.
The [link=http://ch-ignitions.com/]C&H WEBSITE[/link] does not list a conversion for the smaller Saioto engines, but if you call Adrian he will get back to you & set you up W/what you need.
