Old 11-04-2012, 09:21 AM
  #23576
Charley
ORIGINAL: w8ye
SNIP
If I had a ST 2000, 2500, 3000 series Super Tiger, I would be converting it to gas.
I converted my Saito 150 to gasoline.
What gas to oil ratio are you using?
73,
AF5AO
Old 11-04-2012, 10:24 AM
  #23577
w8ye
w8ye's Avatar
With the bushing rod, use 16:1 mineral oil.
Old 11-04-2012, 10:39 AM
  #23578
hsukaria
ORIGINAL: Old Fart
ORIGINAL: hsukaria
ORIGINAL: Old Fart
Huk you could increase your nostalgic feeling about your money by adding an on board fuel gauge with a downlink to the tx
That way I would enjoy it as my money transitions from my pocket to become nostalgia.
Touche' pard (you ****ing bustard in awstralian)
I always thought it would be interesting to fly in the same club as you!!! I bet we would have lively conversations.
Old 11-04-2012, 12:29 PM
  #23579
mike early
mike early's Avatar
What would be a good ARF for a saito twin 90? What would be a good ARF for a twin 100?
My buddy has both of these engines and will allow me to use one in a plane. He provides either engine, I provide everything else.
Old 11-04-2012, 01:25 PM
  #23580
Hobbsy
Hobbsy's Avatar
I like to fly Sticks, a Stck 60 would be perfect for either.
Old 11-04-2012, 03:39 PM
  #23581
N1EDM
Hi GUys,
I just found out that I hadn't received a Club Saito notice for almost a month, so I've missed out on some things.
I have a question which may have already been discussed. Could anyone tell me if Saito has discontinued the FA-62 and the FA-125? I just went looking for them on the HH website and see that they're no longer carried. I was able to get other engines to come up, like the 56, 72, 82, 115 etc.
Are engines like the .62 and .125 gone, and if so, which others have they discontinued recently.
Bob
Old 11-04-2012, 03:51 PM
  #23582
JohnB96041
JohnB96041's Avatar
Check it out:
http://www.horizonhobby.com/browse/p...:cp=1/:ip=45/:
Old 11-04-2012, 03:57 PM
  #23583
N1EDM
Thanks., JohnB. I was doing an individual search which is how I came up with the "Discontinued" message from HH. I just got a NIB 125 last January and it seemed too soon to discontinue it. I appreciate the feedback.
Bob
Old 11-04-2012, 05:25 PM
  #23584
captinjohn
ORIGINAL: w8ye
what kind of mineral oil....like castor or????????????????????????????????????????????
Old 11-04-2012, 07:13 PM
  #23585
w8ye
w8ye's Avatar
Pennzoil air cooled 2 stroke
Old 11-04-2012, 08:10 PM
  #23586
captinjohn
ORIGINAL: w8ye
If ya Google mineral oil....it comes up with a different product....just saying !
Old 11-04-2012, 10:20 PM
  #23587
Ernie Misner
Ernie Misner's Avatar
Castor should be a vegetable oil.
Old 11-05-2012, 04:26 AM
  #23588
Rudolph Hart
Rudolph Hart's Avatar
I like flying underpowed h9 camels with the 90 twin they sound better in an off beat way compared to the 100 engine wise.good luck with that
Old 11-05-2012, 06:26 AM
  #23589
Charley
ORIGINAL: captinjohn
ORIGINAL: w8ye
Mineral oil is pretty much anything derived from crude oil. Distinctions are kind of blurry. I used Klotz Super Techniplate; it's 20% castor, will blend with gas and/or alky.
CR
Old 11-05-2012, 09:59 AM
  #23590
tarcure
I am fairly new to Saito's. I have a 72 and a 115. Both are about 2 years old. However, the 72 was broken in and then sat for close to a year before I came to be it's owner. The 115 is rock-solid, idle's great. I've had a few issues with the 72. Mostly, having trouble getting it to idle lower and finicky trying to tune it. When I rotate the prop on the 115 I feel a pretty solid pop when going thru the compression stroke. I don't get nearly anywhere near that feeling on the 72. I realize they are quite different in displacement but wonder if the ring could be an issue in the 72. I happened upon on a thread about replacing rings with one's made by Frank Bowan and this made me interested in posting this question. Is there a way to compare? Suggestions? Thank you.
Old 11-05-2012, 11:42 AM
  #23591
Mein Duff
Mein Duff's Avatar
have you first checked your valve clearances?....a slightly open valve could do it..
Old 11-05-2012, 11:45 AM
  #23592
tarcure
I did a while ago but will do so again. Thank you very much for the suggestion.
Old 11-05-2012, 02:51 PM
  #23593
hsukaria
I recently readjusted the valve gaps on one of my 4-strokes (not a Saito). Now I have a good compression. I thought I had adjusted it properly before, but I was mistaken. Trying a second time got it right.
Old 11-05-2012, 04:37 PM
  #23594
Rudolph Hart
I used to get carried away setting the finest clearances i could and that takes a fair bit of effort,until one day i was in a hurry and overdid it on one of my 82b's in a decathlon.Flipped the prop with throttle wide open and no compression at all.Exhaust valve was not quite shut and that can be terminal.These days i'm happy at .004
Old 11-05-2012, 07:31 PM
  #23595
jkr_1100
My Feedback: (15)
jkr_1100's Avatar
ORIGINAL: tarcure
I would try to get it wet with fuel and turning over. check the rods and valve rockers. make sure nothing popped out of place. try to get it to run and get some time on it.
set the high sped needle to max RPM at full throttle, then set LS needle by leaning it out until it wont rev up without stumbling, then go back 1/8 turn rich.. make sure to richen HS needle 200-400 RPM down from peak
if you have a plastic backplate you may need to replace the backplate and the intake Oring.
Old 11-05-2012, 10:14 PM
  #23596
Ernie Misner
He's right about the plastic backplate if that's what you have, especially if it's an old 72. The intake manifold will vibrate and wiggle in the head causing air leaks and poor idling / dead sticks.
Old 11-06-2012, 01:17 AM
  #23597
Errol Levin
Errol Levin's Avatar
Hi
I have a new Saito 5 cylinder engine. Would anyone be able to tell me if I will have to prime the engine every time I start it.
The reason I would like to know is that I am installing it in a 1/4 scale Waco which has a closed cowl, and I need to plan where to mount the primer tube.
Any help will be appreciated.
ERROL
Waco brotherhood #204
Old 11-06-2012, 02:39 AM
  #23598
Rudolph Hart
If you have already mounted the engine(325?) in an airframe i'd leave it there almost no vibration.Drop about 3mils of fuel down the primer tube every time you flick it to start even from cold.
Old 11-06-2012, 07:59 AM
  #23599
tarcure
Yes, it has a black plastic back plate. How do Itell if it is an "old" 72? This was purchased at the LHS 2 (not more than 3) years ago.
Horizon lists' this part number for an 82. Correct?
Item: SAI82B17
I believe I read that this is the same part.
I am interested in the carb upgrade kit:
<h3>Upgrade Carburetor Rebuild Kit: FA-72</h3><span class="browse-brand">By: Saito Engines </span>
<span class="browse-item">Item: SAI72144
Is the upgrade kit worth it? What's the difference?
And, will I need to put a gasket between the new back plate the body?
Thank you all for the information. It truely is invaluable.
</span>
Old 11-06-2012, 11:58 AM
  #23600
mike early
mike early's Avatar
On the 72, the plastic back plate means it's the older version.
The new one is the 72B. (SAIE072B)
Yeah, same backplate for the 72 and the 82.
ORIGINAL: tarcure
<h3>Upgrade Carburetor Rebuild Kit: FA-72</h3><span class=''browse-brand''>By: Saito Engines </span>
<span class=''browse-item''>Item: SAI72144
</span>
I never saw that Carb Upgrade before. I wonder if it's new.
It does have a helpful diagram with it:
