Old 11-11-2012, 02:45 PM
  #23626
AJsToyz
AJsToyz's Avatar
Has any one tried a 11x8 MA or Graupner on a 72? Trying to keep the prop size down for clearance .
Andy
Old 11-11-2012, 03:32 PM
  #23627
jeffie8696
jeffie8696's Avatar
You could run a 3 blade
Old 11-11-2012, 03:38 PM
  #23628
Garthwood
BLW........................Forgot what my member's number is.
Charles.
Old 11-12-2012, 03:46 AM
  #23629
AJsToyz
AJsToyz's Avatar
I know you can run one but wondering if any one has any results. I like Graupner props better then MA but they do come at a price. Even the MA three blade is a couple bucks mor then a two blade.
Andy
Old 11-12-2012, 04:29 AM
  #23630
Rudolph Hart
Rudolph Hart's Avatar
Now you've got me stumpeda three blader is more expensive?
Old 11-12-2012, 05:30 AM
  #23631
jkr_1100
My Feedback: (15)
jkr_1100's Avatar
ORIGINAL: Old Fart
OF Graupner props are so expensive here that a two blade is more than a master airscrew 3 blade.
Old 11-12-2012, 05:34 AM
  #23632
Garthwood
ORIGINAL: AJsToyz
Andy
A year ago i purchased a 14X7 - 3-blade Graupner prop for $19.99 + taxes (Cdn.) for comparison with an MA. In my opinion the Graupner is heavier, but i love them. My 14X7 is in combination of a Saito 100 on the H9 Corsair 60.
Old 11-12-2012, 05:51 AM
  #23633
Garthwood
ORIGINAL: jkr_1100
ORIGINAL: Old Fart
Graupners are not cheap and sometimes they're hard to find. For 2-blade props i use APC. I don't use MA so i cannot make any comparisons in regard to pricing 3/2 blade props. APC and Graupner works for me.
Old 11-12-2012, 06:09 AM
  #23634
AJsToyz
AJsToyz's Avatar
Yeh 3 blade MA are more then double there 2 blade counter part. I don't mind buying props I will use but, hate to have tons of extra's that won't be used.
Old 11-12-2012, 09:56 AM
  #23635
Cougar429
Cougar429's Avatar
I've run most makes of props and even with MA I find a wide range of flexibility. IMO, that is what makes a poor prop and the reason wood, APC and Graupner are so much better.
Even though wood can be problematic if there are wide temp and humidity variations, for many of my first flights they are almost mandatory to save the engine and even airframe if something goes wrong. I just have to account for their lighter weight.
Old 11-12-2012, 11:05 AM
  #23636
Linkan2
<span id="result_box" lang="en"><span class="hps">Hi</span>
<span class="hps">I need</span> <span class="hps">a spray</span> <span class="hps">bar to</span> <span class="hps">saito</span> <span class="hps">100TI</span><span>.</span>
<span class="hps">there is no information</span> <span class="hps">which the spray</span> <span class="hps">bar</span> <span class="hps alt-edited">you should have</span>
<span class="hps">It says</span> <span class="hps">buy a new</span> <span class="hps">carburetor</span><span>?
Lars<br type="_moz"/></span></span>
Old 11-12-2012, 03:41 PM
  #23637
Garthwood
@BLW.......................Would anyone care to share the late Mr. William Robison's notes ? Thank you.
Charles.
Old 11-12-2012, 03:53 PM
  #23638
w8ye
w8ye's Avatar
http://www.rcuniverse.com/forum/m_5843055/tm.htm
Old 11-12-2012, 04:03 PM
  #23639
blw
blw's Avatar
What happened is that my name is on the posts for Bill's work. I only uploaded the file. I wish we had the tools to edit that. W8YE did most of the work to correct my formatting mistakes to where it reads as well as it does now.
Old 11-13-2012, 04:46 AM
  #23640
Garthwood
@W8YE....................Thank you for Bill's notes.
Old 11-13-2012, 05:54 AM
  #23641
Charley
Would have been interesting to see figures for bigger props or more pitch. Got time and props?
CR
ORIGINAL: Hobbsy
OK, I should have predicted these results, that way folks would think I am a deviner of sorts.
Fuel for both engines===WildCat 15% Premium Extra
Prop for both============= APC 13x6
Saito .65/stock muffler, rpm====9,800, rpm/TurboHeader==10,000
Saito .62/stock muffler, rpm====9,780, rpm/TurboHeader===9,990
My assumption is that Horizon got their 9,900 rpm for the .62 using 30% fuel, that seems to be their standard.
The .65 wore an Enya A-3 plug
The .62 wore a Fox Miracle
Old 11-13-2012, 06:28 AM
  #23642
mike early
mike early's Avatar
My assumption is that Horizon gets their rpm figures for Saito engines in general using 30% fuel...
  #23643
Hobbsy
Hobbsy's Avatar
Hey Charley, I'll do'er, its about 40 degrees and pouring rain here today. Here is something that surprised me the other day, although it shouldn't have. I ran a Bolly 13.5x6 and a Bolly 12.5x8 and got exactly the same rpm for each. About 9,450 on the .65, didn't try the Bolly's on the .62. I chose to not mention them because not many have Bollys. Its sad that Bolly went under. I have about 10 Bollys that I got from Fiery and Dar Zeelon and have not had to balance any of them. That's a rare thing.
Old 11-13-2012, 06:37 AM
  #23644
w8ye
w8ye's Avatar
ORIGINAL: mike early
Correct
Old 11-13-2012, 08:40 AM
  #23645
blw
blw's Avatar
ORIGINAL: Garthwood
Charles.
Charles- I went back thru my handwritten list and can't find you. I started at #488 after Bill passed away. This may have been around 2006.
Old 11-13-2012, 09:27 AM
  #23646
Garthwood
ORIGINAL: blw
ORIGINAL: Garthwood
Charles.
@BLW...............i read through a few pages but i can't see any proof that i was given a member's number. How about getting a new number ?
Charles.
Old 11-13-2012, 06:44 PM
  #23647
blw
blw's Avatar
Charles,
That wild goose chase I just went on was a little funny after a few minutes. I went back to an old post of yours in Oct 2007, and you signed the post as #406. Guess that's your number. Seriously, I need to go back and copy the membership lists that Bill Robison would post every few months for questions like yours.
Old 11-14-2012, 08:01 AM
  #23648
mike early
mike early's Avatar
This is interesting for several reasons:
http://www.ebay.com/itm/Saito-50-Fou...item1e74451834
Old 11-14-2012, 08:34 AM
  #23649
JNorton
JNorton's Avatar
Wow - how cool is that!
Old 11-14-2012, 11:20 AM
  #23650
mike early
mike early's Avatar
and, longest velocity stack in recorded history, just because.
