ON, CANADA
RE: Welcome to Club SAITO !
ORIGINAL: blw
Charles,
That wild goose chase I just went on was a little funny after a few minutes. I went back to an old post of yours in Oct 2007, and you signed the post as #406. Guess that's your number. Seriously, I need to go back and copy the membership lists that Bill Robison would post every few months for questions like yours.
Charles,
Charles.
Saito club Member # 406
My Feedback: (15)
ORIGINAL: Garthwood
Graupners are not cheap and sometimes they're hard to find. For 2-blade props i use APC. I don't use MA so i cannot make any comparisons in regard to pricing 3/2 blade props. APC and Graupner works for me.
ORIGINAL: jkr_1100
OF Graupner props are so expensive here that a two blade is more than a master airscrew 3 blade.
ORIGINAL: Old Fart
Now you've got me stumpeda three blader is more expensive?
that is a shame. I think they are made in Windsor, ON, CA
ON, CANADA
JKR..................Graupner props are made in Germany, not in Ontario. I suppose that is why they're a bit more expensive. I use a Graupner 3-blade on the H9 Corsair.
I have quite a few Graupner 3-blade props with the latest to be fit to the 125a on Rare Bear once the test flights are out of the way. Thinking of painting it chrome. If I could find some appropriate size Hartzell or other stickers that would really help the scale look.
My Feedback: (9)
Ref. 3 bladed props .... Xoar and Zinger make a sell them but, they are bit pricey. Xoar's smallest size is a 14x6 three blade ($42 approx) and Zinger starts in the 10 inch size. Their 14x6 is the same price as the Xoar I think.
RJ
RJ
ORIGINAL: Cougar429
ORIGINAL: w8ye
Anyone care to look at the current Saito catalog from the factory?
http://www.saito-mfg.com/e-book/_SWF_Window.html
They've re-released the Saito 30? And radial Gasoline engines. Good time to be in Club Saito.
It was Horizon that discontinued the 40 and 30 because they thought electrics had taken over the world. Saitro never quit making them.
ON, CANADA
ORIGINAL: Cougar429
You mean painting the rare bear chrome and not the prop. Right ?
ORIGINAL: mike early
He means painting the propeller. People do that.
When a propeller is painted, extra coats of paint can be used as a way to balance the prop.
You have to allow for the added weight of the vehicle (liquid) weight as the paint will weigh less once it dries. Ater the prop ahs a base coat, misting on "dry" coats a little @ a time is the best method to achieve balance.
ON, CANADA
I made that question because if the prop was to be painted, rebalancing the prop again is too time consuming. Graupner has specific instructions regarding their props.
Thanks for that,anyone know how to save it? usually right click and save but the japanese window pops up and i'm stumped.Like the way you turn the pages tho.
ORIGINAL: SrTelemaster150
You have to allow for the added weight of the vehicle (liquid) weight as the paint will weigh less once it dries. Ater the prop ahs a base coat, misting on ''dry'' coats a little @ a time is the best method to achieve balance.
I dunno. But it looks like Saito has stuff for your phones, too?
My Feedback: (32)
<span style="font-size: medium">I have found that two part epoxy paint like K&B or Hobby Poxy works the best for balancing props. It is much better than sanding and removing material from the blades. Regular paint has a vehicle or thinner that dries and makes the dried paint lighter than when it was applied.</span>
ORIGINAL: Old Fart
Put the link in your "favorites".
On props. Have any of you seen the wrinkles that develop at the blade root on APC props when you push "real power" through them. They look a bit like ladies "stretch marks", apologies for that where required, old fart knows what I mean there.
Any way if you do see them (the marks, retire the prop or use at your peril. It means one blade has now grown longer than the other, doubt me measure the 2 blades for yourself. If the blade lets go in flight at any sort of good RPM the worst that happens is a "lunched engine" followed by a re kitted model, on the ground is another matter and look out any one in the way of the loose blade.
In case you were wondering I use APC and Bolley's (sparingly) and yes MA's can't get a reliable source of the right sized Graupner or Superior where I am so I collect them in my travels.
Yes i've seen the stretch marks you talk about on a couple of my apc's but balance seemed ok and hav'nt had a failure.A mate chucked half a blade in flight vibration looked unreal from where i was standing,real exciting and a bit hard on the firewall
The reports on APC blade root failures when bolted to 4-strokes kept me from ever fitting one for that app.
As for failures: ANY prop that has had a ground strike, especially while under power, should be inspected carefully. As with real aircraft these are the types of stresses or damage that can come out later to bite you.
Old Fart, your friends blade failure and my own experience when first learning to tune Saitos have me cringe EVERY time I watch a Youtube vid with the camera well within the danger arc of a prop.
ON, CANADA
ORIGINAL: FNQFLYER
On props. Have any of you seen the wrinkles that develop at the blade root on APC props when you push ''real power'' through them. They look a bit like ladies ''stretch marks'', apologies for that where required, old fart knows what I mean there.
Any way if you do see them (the marks, retire the prop or use at your peril. It means one blade has now grown longer than the other, doubt me measure the 2 blades for yourself. If the blade lets go in flight at any sort of good RPM the worst that happens is a ''lunched engine'' followed by a re kitted model, on the ground is another matter and look out any one in the way of the loose blade.
Charles.
ORIGINAL: w8ye
http://www.horizonhobby.com/products...m-rtf-SAIE040A
No idea why /super-cub-dsm is in the address...
