RE: Welcome to Club SAITO !
ORIGINAL: Old Fart
Huk you may have damaged the new needle seat by fitting the bent hsn?
Anyone know why they sometimes start in reverse? Also, when its cold, they just don't wont to start? I use 15% fuel, should I use a higher mix?
Below is the video to what I am running... Thanks!
http://www.youtube.com/watch?v=-oay6Erw6kM
http://www.youtube.com/watch?v=9muW0CRVAco
ORIGINAL: Johnk71
My 12.77:1 CR high compression 180 starts better when it's cold due to the higher combustion chamber temperatures when cranking.
I can use a heat gun to heat up the carburetor & intake manifold. Then, the stock engines will start.
In Northern states, E-85 blends are dropped to about 60% alcohol in winter for the very same reason
Thank You! I guess that's why when I take it out of the heated cab of the truck it starts....... rather then at or below 0 it is just not working... Any Idea on why it starts in reverse? I will kill it, and after a few start and stops, it will run. Its not cavitating, it is running in reverse....
ORIGINAL: FNQFLYER
just use an electric starter, a cure all for most things like this and saves the fingers
Just not enough heat build up in the compression of the stock engines.
The high compression 180 will light off when the stock engines won't.
I'm sure that @ a certain minimum temperature the 180HC will fail to start too, but I don't want to be fooling with it when it's that cold.
My Feedback: (12)
I have heard of some people using lighter fluid to help start a cold engine but don't know how well it works or if it's even advisable.
ORIGINAL: Quikturn
Ha HA! I had to look at that 3x's... I must need more coffee......
ORIGINAL: mike early
[youtube]http://www.youtube.com/watch?v=vOoQXTInTQM[/youtube]
ORIGINAL: Johnk71
ORIGINAL: Old Fart
I'm so glad YOU said that couple of drops and you're away and running
ORIGINAL: Quikturn
My Feedback: (12)
OK then. So lighter fluid is the ticket for getting a cold engine running. Do you put a few drops down the carb or put a little in the fuel tank?
Hi mate,on a fourstroke i open the throttle fully and block the carb intake with my thumb,flick the prop two or three times to bring the fuel up then a couple of drops of lighter fluid into the carb with throttle fully open.Flick the prop over several times.Throttle back to your normal starting position and put the glo stick on.One or two flicks and your away.If your engine is fully cowled it's going to be a pain in the rear end.
In very cold conditions i don't see why you could'nt set upu a portable hairdryer to blow warm air into a fully cowled engine for five or ten minutes,should be game on then.
ORIGINAL: Old Fart
I used my heat gun in the garage when I am out putzing around on a cold day.
Geting the intake manifold & carburetor warm is the most effective method IME.
I find the starting sequences people are using interesting. After a number of "bitten fingers", bitten by various engines startingh with Burford 2.5 diesels and working up through to those engines referred to in polite circles as "Leroy's revenge" I have come to a number of conclusions.
1/ Ensure that your engine is run in and in good tune, this leads to 2/ The engine should have an established prime procedure, mine is (with presurised tanks to place a finger (or suitable blocking device on the muffler outlet and turn the engine over by hand 2 or 3 revolutions, them 3/ apply the glo device and 4/ attach starting device (my electric starter) and actuate. Assuming all batteries are fully charged and I have the throttle open the required amount (I find this is different for each engine) the engine 99% of the time starts is the desired fashion.
IF I DEVIATE from ths procedure I expect to have problems.
The essage I am trying to deliver is have a start procedure, stick to ii and if you have problems you can virtually elimate (or confirm) such things as dud glo plugs, flooding, poor start due to cold or hot (yesfuel vaporises) coditions etc.
And the biggie, no damaged didgets
Catch Ya
Catch Ya
