Official Tamiya TT-01 Thread
Old 07-15-2007, 01:55 PM
  #2451
TIGER76
TIGER76's Avatar
Default RE: Official Tamiya TT-01 Thread
ORIGINAL: RCHEAVEN101
Hay Im buying a standard TT01 in a couple of weeks and ive thought alot about it...
If i put a aluminion shaft
ball bearings
19 turn motor
ESC that can handle 15 turns
Would that run ok without killing itself?
or would i need some of those overly complicated pinion gear or spur gear upgrades?
thanks alot.
no mate that would run sweet,but you could always grab some pinion/spur sizes if you want to change your gearing about ie more top end or more pullaway
might be worth investing in a ali motor mount incase the motor heats up on long runs k[sm=thumbup.gif]
Old 07-15-2007, 01:57 PM
  #2452
TIGER76
TIGER76's Avatar
@ Hunter yeh those 320si do look sweet [8D]
what are you after all out speed or maybe a bit of drifting too??
Old 07-15-2007, 04:34 PM
  #2453
mindwreck
mindwreck's Avatar
6900 would be good on 6-cells.
ORIGINAL: hunter399
I am planning to invest in many aluminum parts
But which motor? the 4600 5700 6900 or 7700 mamba?
Old 07-15-2007, 04:37 PM
  #2454
mindwreck
mindwreck's Avatar
good setup. I do recommend getting the spurs and pinions as the stock gearing might leave you wanting more. i used to have a 19t in mine running 24/58 gearing. fast and good acceleration.
ball bearings
19 turn motor
thanks alot.
Old 07-16-2007, 06:46 AM
  #2455
CrocEnd
MM 5700 takes allsorts of battery combo's
Old 07-16-2007, 11:20 AM
  #2456
hunter399
So do not go for the 7700?
Thanks guys for your input it really help!
Old 07-16-2007, 11:50 AM
  #2457
mindwreck
mindwreck's Avatar
gearing in the tt-01 might be a little problematic with the 7700. Thats why i said the 6900. 5700 does have more battery options but the tt-01 can't take that many battery options.
Old 07-16-2007, 02:17 PM
  #2458
hunter399
Cool
Looks like im going with a 6900!
Which gearing do you reccomend?
Old 07-16-2007, 02:33 PM
  #2459
MacDuff
MacDuff's Avatar
Look what happened in my bros TT-01!!! ahahaaha
Old 07-16-2007, 03:15 PM
  #2460
studysession
studysession's Avatar
ORIGINAL: mindwreck
Why not go with the 7700? I run a Hack C40 6T in my TT-01. About to switch it out for my 5T motor which is a lot higher kv. My TT-01 runs fine with these insainly fast motors. So trying to figure why you think it might be problematic?
Old 07-16-2007, 04:57 PM
  #2461
mindwreck
mindwreck's Avatar
i was thinking in terms of gearing and reliability with stock parts. i have mamba in mind too with the stock out shafts and diff, etc. only ran it maybe 3 or 4 times and they already have noticeable wear on them.
with upgraded parts it should handle it fairly well. I was just thinking in general terms since most people in here are fairly stock cars . I've said it before, brushless in these cars seem to be a hit or miss. i hear alot success and horror stories on them. I guess mine just isn't liking my need for speed.
Old 07-16-2007, 05:02 PM
  #2462
mindwreck
mindwreck's Avatar
gears need cleaning badly. theres crud inside the teeth of the spur gear and its chewing you pinion(looks like sand or dirt) its happend to be before when i first tried to rally my tt-01.
also the pinion isn't centered on the spur which is why theres still a little bit of the pinion left.
ORIGINAL: MacDuff
Old 07-16-2007, 06:35 PM
  #2463
studysession
ORIGINAL: mindwreck
Makes more sense. Mine is all stock except ball bearings and the shocks are off my TC3. The shaft definately binds, but the gears I have not had any wear yet, but when I accelerate to fast you definately hear it. I am sure with time they will.
In my wish list on tower, I have the aloy shaft listed and was looking at metal gears for the diff off EBay.
Old 07-17-2007, 12:09 AM
  #2464
hunter399
So if I go aluminum I should get the 7700?
Again, thanks guys!
Old 07-17-2007, 12:19 AM
  #2465
mindwreck
mindwreck's Avatar
well not just aluminum. upgrades in the drivetrain. . bearings and the aluminum prop shaft are a must. ball diff and cvds or universals are optional upgrades. these will help with the handling and more efficient power delivery to the wheels.
Old 07-17-2007, 10:47 AM
  #2466
hunter399
So the 7700 is a good idea if i do those things?
Old 07-17-2007, 11:44 AM
  #2467
mindwreck
mindwreck's Avatar
can't say it will work for sure and without breaking. you can try it and tell us, if it doesn't work out then its a good reason to get a new faster car. hehe
Old 07-17-2007, 03:46 PM
  #2468
KilgoreTrout
Old 07-17-2007, 04:01 PM
  #2469
Paulyd
Paulyd's Avatar
where is the best place to buy TT-01's, and upgrades?
Old 07-17-2007, 04:24 PM
  #2470
MacDuff
MacDuff's Avatar
ORIGINAL: Paulyd
towerhobbies.com, ebay, your local hobby shop, dinball maybe...
Old 07-17-2007, 04:37 PM
  #2471
qaz393
ebay for sure
Old 07-18-2007, 02:01 PM
  #2472
Paulyd
Paulyd's Avatar
me and 2 of my friends might buy some tt-01's for the fun of it. where can you buy bodies. i want a tuner body, like a Skyline, S2000, and 1 of my firends does too, and my other one wants either a BMW, or a Lambo. i'm gunna go to my lhs sometime and see how much tt-01's are there, cuz i dont really remember. all i know is that the parts arent worth buying there, cuz there quite expensive, but cars are cheap.
Old 07-18-2007, 02:33 PM
  #2473
lee172
lee172's Avatar
RC mart and Stella models are cheapest for hop up/parts, google and you'll find em.
Old 07-18-2007, 02:52 PM
  #2474
Paulyd
Paulyd's Avatar
http://www.rcmart.com/catalog/produc...ducts_id=23675
would that be something good for a TT-01 kit? please dont recommend something over like $200, cuz i have a low budget.
Old 07-18-2007, 03:00 PM
  #2475
Paulyd
Paulyd's Avatar
building a kit isnt that hard, is it?
http://www.rcmart.com/catalog/produc...oducts_id=6079
EDIT: wat motor and esc are good for drifting?
