View Poll Results: A poll
Voters: 29. You may not vote on this poll
stronger / better: e-maxx or e-savage
I've read the e-maxx is better and stronger than the e-savage / e-zilla(same truck, different brand). Then some guy in a youtube video messed with my head saying the e-savage is much stronger than the e-maxx.
The only reason I care is I'm selling my t-maxx soon and want a used e-maxx for Christmas, and want to make sure it's not a bad decision.
This poll is referring to both of the trucks in stock form, and not referring to the new e-maxx that was just released, vote for the strongest truck / overall better. Feel free to explain your vote too. Thanks.
Moderator
RE: stronger / better: e-maxx or e-savage
Having owned both, I'd go with the E-savage hands down. The chassis is more advanced, everything is less prone to breaking.
ORIGINAL: sheograth
ORIGINAL: sheograth
I've had the exact same experience with both trucks. The only people that say the E-Maxx is stronger seem to be the ones who haven't had both.
MO
I believe its personal preference. Both trucks will take a lot of abuse, but both WILL break. If you liked your t-maxx, you will like the e-maxx. Its basically a t-maxx with more torque, less top-end, and not as much maintanence unless you break a part
NJ
Now a war is starting. I'd go E-Savage. $100 less than E-Maxx. The old E-Maxx broke parts frequent. The new one might be the same.
Moderator
Its not a war, we're just discussing pros and cons.
I take each vehicle on its own, brand loyalty doesnt play a huge role in my hobby. Granted, certain companies make many good vehicles and can be trusted, between the top brands its really vehicle by vehicle.
NY
there was a artical about this, someone did a test on both already, hands down the E-savage was stronger faster, and handles better. but the comparison was with the current emaxx.. but the new emaxx is coming out and it is supposed to be stronger and better than the older one, so this new emaxx might be at par or better the the current Esavvy. but there has been no comparison as of yet between the new emaxx and the savvy so no one really knows yet till they test both. and who knows the savvy might still be better.
Thanks for all the advice! I'm probably going to order a e-savage tonight from tower.
I discovered it's not the exact same as the e-zilla, it's like an upgraded version.
And I also saw in the RCU ratings it's rated 4.5 stars and the e-maxx is a 4
I want to be able to plug the charger into the wall... What do I need to buy? Hopefully that won't cost a lot[]
Thanks.
Thanks.
ORIGINAL: 500 lb. koolaid man
Thanks.
Thanks.
Yeah that's a good idea, thanks. And the thing you said to buy at radio shack(or just hook it up directly) is included with the truck if I understand what you're talking about, it's in the top left of this picture. Then I guess I could plug the clips to a car battery charger set at 12V. I just hope the power level(exact amps and volts) is safe using this method and wouldn't ruin anything.
Calvino, thanks again for the help. I'll use my battery tester first then.
OK 2 more questions then I'm done... I think
Are there any rumors of a new e-savage? I'd wait in that case...
What should I set the charger at for longest life of the battery cells and the best performance of the truck itself, 1 amp, 2 amps, or 4 amps(that's what it'll do)? The reason I ask now is I won't have internet when I get the truck nor for a week and a half after I get the truck.
Thanks.
Thanks.
NY
as of right now no, i dont think. but because the new E-maxx is coming to play i would not be surprised if in the near future maybe a year or 2 that there will be a new E-savvy
Thanks.
Thanks.
When I get new batts, for the first charge I like to keep the amps as low as I can stand (lower takes a lot longer to charge) Then go up for some performance increase (if I feel I need more).
I don't think you can say 1 amp is best though.. You want a little bit of everything
ORIGINAL: Dokioto
^ I don't know if that will give the same affect lol..
I have read in mags something called, step-charging though (almost the same thing). Top touring car racers use it.. While the pack charges the amps change at picked times (on charger?), and done correctly gives you an increase (in what ever you were trying to accomplish). Sounded interesting to me[:-]
Woohoo it's purchased (from LHS, time was running short). Just felt like sharing.
I'll start with 1 amp then after a few times 2 amps, then maybe 4 after a while...
WI
The only setback of the e-savage is the drive shafts. From what I have heard they will not hold up to anything over stock.
All the info I am sharing I got from many people that own these trucks. look on www.e-savage.com
I will be getting an e-savage very soon.
Thanks for the info PedeBeater. I plan to keep it stock except for maybe some better brushed motors, another set of 6 cell batteries and deans plugs in the future, maybe 7 cell packs with a fan way in the future, hopefully that wouldn't push the drive shafts to the limit[&:] No brushless and lipo or anything...
I've read a lot about the charger and batteries that come with it. The batteries are 3300's so I'm happy with that and consider it good myself($25 a piece estimate if bought separate, and 10-12min. run time is fine with me). And the included charger, I'm going to use a car battery charger as its power source so I'm fine there, however some people say it doesn't do a good job charging, one person said it only said it charges the packs 75%. Well the RCU e-savage review said it's a good charger, it's best for me to just believe that and not worry about buying another.[8D]
I want to break in the motors before I run the truck for the first time, my plan is to submerge them in a cup of water and let each run for 1 hour under the power of a D(1.5V) battery. Then when I take them out I'm supposed to spray them down with motor oil or WD-40 which is what I'm using, so does that mean flush out the insides of it(touching the brushes for example)? And then I'll use [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDA93&P=7]this oil[/link] on front and back of the motor, front as in where the bearing is. Does all of this sound rite? It's the inside of the motor that needs to be flushed out?
Thanks.
Thanks.
Thanks.
Thanks.
Umm... Please?
Thanks.
Thanks.
