TRX 2.5 are garbage
Old 05-27-2008, 01:15 PM
nitro rc
Default TRX 2.5 are garbage
Hey.
Has anybody else had this problem? After 2.5 gallons, my trx 2.5 in my tmaxx runs for like 2 minutes maximum and then shuts off. sometimes i it drives literally 10 seconds and dies. This is alll after setting everything abck to factory settings. Its shuts off when i let go of the throttle when it dies in like 10 seconds. Usually it lasts about 3 minutes then gets smoke from the cooling head and if i don't keep on the throttle it dies. It is very frusttrating because it is my first nitro and i wan to run it but i can't get through 1 tank without it dying 5 times. Any suggestions? Mybe an airleak?
Old 05-27-2008, 01:38 PM
shibby1
Default RE: TRX 2.5 are garbage
I would go buy a temp gun and and then try to tune it it make life much better when it comes to tuning. I cant say its a airleak because i dont know what the temps are. If it was running 170 200 then no airleak, but if it is running like 300 then airleak.
Old 05-27-2008, 01:55 PM
skootmaxx
What's the history of the care on ur 2.5? I know when I first got my max it did the same thing . The motor had lost compression so it would run get nice and hot then die. We also had a problem with our new motors dying after we hit the throttle . I had to lean out the Lsn to get rolling
Old 05-27-2008, 02:44 PM
iamnot
yes lots of people have that problem
and 90% of them
don't have a clue
on proper break-in,
proper tuning or
care of a nitro engine
Old 05-27-2008, 02:48 PM
nitro rc
ORIGINAL: iamnot
and 90% of them
don't have a clue
on proper break-in,
proper tuning or
First of all i did break it in exactly how traxxas said to. I clean the engine and oil it every time i run it even if it is like 10 minutes, so don't assume![:@]
Also , the first prolly 1.75 gallons, i never touched the needles, so it wasn' too lean. It just started happening for the last 1/2 gallon i have been running.
If it came down to a trashed engine, is the 3.3 a good engine to get since i can do the traxxas ERP?
Old 05-27-2008, 02:52 PM
nitro rc
ORIGINAL: shibby1
I am thinking airleak only cuz it must be extremely hot if there is smoke coming from the head. It is so hot, the rubber on the coil of the glow plug ez start wire is burning off. I know i should get a temp gun but i haven't gotten to it yet. Lol.
Old 05-27-2008, 02:56 PM
racemaxx24
Just
ignore
iamnot
[I hate he types like that]
Anyway, yes the TRX 3.3 is a great engine but first we need to cover your bases with this one so u don't trash another. Have u tryed richening the LSN? Or the HSN?
Old 05-27-2008, 03:02 PM
iamnot
ORIGINAL: nitro rc
ORIGINAL: iamnot
and 90% of them
don't have a clue
on proper break-in,
proper tuning or
i think that
pretty much
proves my point
no nitro engine
will go almost two gallons
without needing retuning
and anyone who wants
to ignore that, well
you'll ruin your engine too
Old 05-27-2008, 03:06 PM
racemaxx24
ORIGINAL: iamnot
ORIGINAL: nitro rc
ORIGINAL: iamnot
and 90% of them
don't have a clue
on proper break-in,
proper tuning or
i think that
pretty much
proves my point
no nitro engine
Come on man. Give him a break. If he is a newb then he will learn now that u do need to ajust the needles. Why do u have to be so harsh?
Old 05-27-2008, 03:32 PM
iamnot
i hate it when people
blame a perfectly good
engine on their own shortcomings
the trx 2.5 is not
and has never been garbage
the fact that it lasted 2 gallons
after never being tuned
is testament to the
fact that it is a strong engine
harsh?
maybe
but the truth none-the-less
oh, and here's some for real advice
the 3.3 uses the 2.5 crank and con rod
they don't like to be abused as
much as the 2.5
and the con rod can let go
if run lean/abused
Old 05-27-2008, 03:36 PM
Mambamonster
Mambamonster's Avatar
iamnot
if you have
nothing nice to say
get off the site
and go play.
Old 05-27-2008, 03:45 PM
iamnot
hi mercedes
ever get that t-maxx
running?
Old 05-27-2008, 04:13 PM
beer=food
Banned
Running a rich engine will not wreck it, only burn glow plugs out. Running a lean engine will wreck it.
The worst a rich engine can really do is squash the con-rod bearing a little when its cold started, that will not stop it running or holding a tune.
Sounds like its getting hot, does the body have holes in it for air flow ?
If its set rich, has never been touched, and is dieing under acceleration, at an assumption, one could guess its leaning itself out, HSN rich enough ? Top end needle.Or overheat.
Air leak may have started if its all set rich, or the glow plug is fried, or its set SO rich that fuel is spattering onto glow plug at WOT and killing it.
Either way its tune related.
At 2.5 gallon, about 10 letres, your engine may have wear on it, that would show YOU, no one else here, how well you run it in, honesty is all that counts here, we all stuff up, lve been into nitro for about 20 years now, l have lost count of the mistakes lve made, and even l stuff a motor run-in every now and then, sometimes out of sheer daftness, just had to see how fast it went LOL, my revo has about 6 gallons through it still idles, but it dont quite have the punch it used to, l run my idle a touch higher now, for obvious reasons.
It doesnt take much, one, two, maybe three overheats, and the engine life goes from an average of 100 hours back to about 40 to 50 hours of usable power. Thats at a guess about 4 gallons, 4 and a half maybe.
Old 05-27-2008, 05:18 PM
nitro rc
yes i did cut holes in the body, maybe i will make it bigger. i hardly go through glow plugs but i will swap in a new fresh one. When i try leaning the engine out from factory settings, it only overheats so i end up putting it back to factory settings.
Well thanks for the advice and ya since its my first every hobby level car, i probably did ruin te engine. Now i know that after i break it in i need to immediately tune it.
Old 05-27-2008, 05:19 PM
matts6887
matts6887's Avatar
ORIGINAL: nitro rc
Hey.
Well usually if it warms up a little, then dies like u are describing; it sounds to me that there could be a loss of compression there and in turn a piston/sleeve that are headed south...cause if a engine dies like that frequently while warm, that is usually a telltale sign that the compression is on its way out the door for good....
Old 05-27-2008, 05:22 PM
Mambamonster
No I am done with that lemon I am getting a buggy.
Old 05-27-2008, 05:23 PM
racemaxx24
I will take it
Old 05-27-2008, 05:27 PM
matts6887
matts6887's Avatar
Shoot....so would I... If u can't figure it out, Im sure I can....
Old 05-27-2008, 06:00 PM
cmerritt
ORIGINAL: nitro rc
ya like others have said. i would try tuning it for your environment. there may still be hope of it being able to run reliably.
if it is done for then i would do the ERP and get a 3.3
Old 05-27-2008, 06:18 PM
Mambamonster
Well if it comes down to nothing but taking up space I might. Just let me know; though you will be spending more time fixing it than using it lol.
Old 05-27-2008, 06:22 PM
racemaxx24
If u decide to donate, I have first dibs
Old 05-27-2008, 06:27 PM
Mambamonster
Sounds good.
Old 05-27-2008, 06:39 PM
rcnitrohead
rcnitrohead's Avatar
As much as I would like to say that the 2.5 is garbage, its not too horrible lol. It was my first engine, it gave me tuning nightmares and made me hate the hobby, and it wasn't spectacular on power. After I bought my Savage, I saw the light and realized that not all nitro engines are impossible to tune Although I wasn't really satisifed with it, it DID last 8.5 gallons running extremely hot temps with smoke coming from the head, and saw ARO on around 5 occasions in its lifetime so I have to give it some props. Your case is simply user error, as mine was in the tuning department.
Old 05-30-2008, 02:53 PM
nitro rc
here is a video to show how long the engine runs before stopping. It is about 1 minute which is annoying because everytime it stops, i have to wait for it to cool before i can start it up again. Check it out. My dad also suggested that it is too rich and is loading up and stalling but there is still smoke from the head(not shown in video) so i am really confused and since it is my first nitro/hobby level rc truck i want to run it.
http://www.youtube.com/watch?v=FqkhTFyTULM
PS- the sound in the background is my dad with a weedwacker LOL...
Old 05-30-2008, 03:26 PM
beer=food
Banned
Sounds rich and looks like a dead glow plug.Dont see smoke but, although some cameras dont pick it up well.
