Powerband Issue
My Feedback: (10)
RE: Powerband Issue
Its hard to explain but I'll give my best shot...
I just put in a new Axial .28 spec 1s and it has been broken in already... well... it not as the same as before as the 4.1... having a high pitch at high speed so now Im guessing Im lacking RPM?
WI
RE: Powerband Issue
Who said it was broken in or did you break it in? If its new it needs to be broken in. Alot of things can cause low power output loose slipper, grub screw coming out of rear output on tranny, bad clutch etc.
My Feedback: (10)
RE: Powerband Issue
the break in was done by me... thats what I meant I have a brand new clutch shoe installed, adjusted the nut... tight with no 1/4 or 1/2 turn... I was thinking of changing my clutch shoe spring for a stiffer ones... will that resolve it?
RE: Powerband Issue
i replaced my clutch shoes and spring in my traxxas revo3.3 and it took a bit of time and use for the clutch and spring to run in , then it was going really good
ON, CANADA
RE: Powerband Issue
ORIGINAL: REVO X
what gearing are you using.
if its still the stock 15t cb and 49t spur. you should be flipp'in that truck on its lid with that much torque.
if your looking for speed change your gears 17t/18t cb and a 47t/46t spur to get more out of the .28.
WI
RE: Powerband Issue
check to see if the grub screw for the rear output cup on the tranny is missing. after that take the engine out and check to see if the clutch springs are still in the groove and that the clutch nut it tight.
RE: Powerband Issue
Kid you sound very lost........a hig pitched buzzing could be that your motor is way too lean...please do some basic reading on tuning a nitro engine, and also try to explain what wrong with a proper description....what your saying now makes no bloody sense.....
edit ( Sorry to sound so cranky LOL...I just re-read this post and i sound pretty rude) I just couldn't make sense of what you were trying to say..i am trying to help ya though beleive it or not....
My Feedback: (10)
RE: Powerband Issue
ORIGINAL: mazdab2600
you replaced a f4.1(.25) with the axial .28.
Vigilante212
Grub screw? I really dont know where is that at... can you post a photo? Thanks...
supertib
[link]http://www.youtube.com/watch?v=bH37Jyzq3Rg[/link]
Sound like its bogging down from WOT... I think I need to lean out my LSN? what do you guys suggest?
WI
RE: Powerband Issue
I cant tell for certain, but sounds like its not shifting. if thats the case then its either your slipper adjustment is too loose or your clutch shoes are slipping too much.
as for the grub screw heres a pic.
My Feedback: (10)
RE: Powerband Issue
ORIGINAL: Vigilante212
well I think its fix now! I adjusted the nut by the spur gear again loosen it up to almost 1/2 of a turn then I lean out the HSN a little bit... now its hauling arse!
Thanks guys for all your help.
ON, CANADA
RE: Powerband Issue
ORIGINAL: REVO X
what is the purpose the slipper clutch?
diff's mainly.
once you get that engine tuned in. you'll get fed up with the flipping and wheelies and want to go faster.
i remember my f4.1 with 13t/52t gearing loved the wheelies but the excitement wears off quick and got the lrp spec3.
changed the gearing real quick with that upgrade.
wheelie with the stock f4.1.
http://s5.photobucket.com/albums/y20...t=wheelie2.flv
http://s5.photobucket.com/albums/y20...t=wheelie1.flv
MD
RE: Powerband Issue
this is the one i use with the small wheel. i can wheelie as long as i want. it bolts on solid and won't bend. i've landed on it from a jump and nothing happened http://www.hpiracing.com/products/en/85245.html
ON, CANADA
RE: Powerband Issue
ORIGINAL: hpibasher2
Sorry to go off topic but mazdab2600, what wheelie bar do you have? My Integy... Doesn't work...
now all i use is the one from hpi. one on each truck(4).
WI
RE: Powerband Issue
I find the slipper only midly useful for when your jumping and cant get off the gas fast enough. this will prevent damage if you land with the throttle open. my slipper disk blew apart on me with it only being a 1/4 turn loose ever since I cranked it tight. There are easier ways to prevent wheelies. Softer rear springs, changng the spur CB gear ratio, adding a bit of weight to the front end.
