DLE 20 Header and Can
RE: DLE 20 Header and Can
http://www.macspro.com/headers_side.asp
<table cellspacing="1" cellpadding="3" border="1"> <tbody> <tr align="center"> <td align="left" valign="top">D.L.E. 20(in design-sub#2985-2987)
(screws 4mm x 12mm socket head)
(center to center = 32.21mm/1.268")</td> <th valign="top" rowspan="12">52.95</th> <td valign="top">4200</td> <td valign="top">4201</td> <td valign="top">4202</td> <td valign="top">n/a</td> </tr> </tbody></table>
My Feedback: (7)
IN
ORIGINAL: TimBle
Alternative option, Custom Header and Weston Uk Aerobatic Mini Pipe 1.08 to 1.20 size from Just Engines.
Quieter than an electric...
1 Post
around GBP80 for the header and mini pipe.
weight, erm well ja I have not weighed it..
othing can compete with the stock muffler. It barely thicker than foil</p>
My Feedback: (7)
IN
ORIGINAL: TimBle
Be nice if someone with your choice & Jody state the weights of each respective style.
AZ
It's from an excellent thread over in the 3D flying forum. http://www.rcuniverse.com/forum/m_10609304/tm.htm
Excerpt from post #18 of that thread____
So my cannister muffler came in...
Why does there always have to be bad news with the good?
Ok, first observation... it's huge!
Good news the quality of the cannister and header itself is pretty good for what I paid for it ($60USD).
Bad news is the supplied hardware is awful... cannister brackets are good for half the diameter and the hose clips feel like they are made of lead (read very heavy).
Second bad news... the header doesn't fit the DLE-20 despite talking to the vendor on the phone and being assured that it does. Oh well...
Pic 1: Parts as supplied. You get what you pay for and this was cheap. I didn't for a moment think that it would be a drop-fit
Pic 2: It needs an additional 8mm of drop (header face to outlet centerline) and 24mm shift to one side. Here it is bolted to a steel plate for bending with a blow torch.
Pic 3: After slotting the header mount holes and bending it, it kinda fits. This is a test and not the final installation.
Wednesday I will pick up some high temp silicone to protect the airframe where needed. Thanks Scott for the advice.
Cheers
Goose
[youtube]http://www.youtube.com/watch?v=5x8PqgGGFGg&feature=youtube_gdata[/youtube]
Cheers
Goose
My Feedback: (7)
IN
ORIGINAL: stangevil29
Hopefully somebody knows what that canister & header pipe weighs.
My Feedback: (7)
IN
Thanks!
11 ounces minus about 2 ounces for stock unit= 9 ounces more than stock unit
'goose' ditched the heavy mounting clamps, so he might be around 7-8 ounces over stock.
Not too bad if noise is a big issue where a person fly's.
My Feedback: (7)
IN
ORIGINAL: av8tor1977
Hmmm, I may be interested in that canister setup from Valley View. Anyone got a video of one running? I would like to hear what it sounds like. (I don't like my engines too quiet!)
AV8TOR
AV8TOR
1 Post
ORIGINAL: a1pcfixer
About $100.00/USD?
ORIGINAL: TimBle
I need to improve the fittings. Will work on that this weekend and post weights of all components required. Been trolling through the bicycle shops for light weight bits and pieces that I can cobble together into a decent mounting bracket. Work in progress but once I've got it sorted I'll post pics, weights and part numbers so you can source the bits yourselves.
Hardware stores I am afraid only sell bits an pieces made from the heaviest materials they could find.
I have found M3 to M6 aluminium bolts and will be retrofitting my plane with these. After adding the Mini pipe I want to claw back as much weight as possible.
ORIGINAL: a1pcfixer
Video is hiding at the end of Post #17
AV8TOR
AV8TOR
a1pcfixer, are you going to be at the Port City fun fly this Saturday? Thanks Capt,n
My Feedback: (7)
IN
ORIGINAL: TimBle
Equal to the stock unit? Less?
