DLE 20 Ignition & life4 battery question?
My Feedback: (7)
IN
RE: DLE 20 Ignition & life4 battery question?
Jody & others have noted the DLE20 ign does NOT like voltage from 6.0 and up.
Put a diode in line to the ign module and drop the voltage to below 6.0 volts......or.........take your chances and risk burning it out.
They ONLY about $80 depending on where you get them.
If you can solder good, make up your own. If not, order one pre-made from Richard........
Inline Ignition Voltage Reducer for A123
http://www.shop.kavarootusa.com/prod...&categoryId=10
NJ
http://www.shop.kavarootusa.com/prod...&categoryId=10 Rich is great to deal with good luck!
My Feedback: (7)
IN
ORIGINAL: All Day Dan
Jim, If that diode fails as a short circuit you are going to ruin the module. If it fails as an open circuit or you get a loose connection your engine will quit. Do yourself a favor and use a four cell pack of NiCads or NiMhs. Dan.
to even consider your idea as having any merit. Tons of us have been doing it with no failures.
My Feedback: (7)
IN
ORIGINAL: skip1320
Btw....in the fwiw dept., have you seen Rich's (LiFe) Field Pack?
I just got one (flat - not square), and it's so much lighter than the bigger heavier gell cell or maine batteries!
[link=http://www.shop.kavarootusa.com/product.sc?productId=40&categoryId=10]**NEW** LIFE 4S1P-3300 mAh 13.2v Field Pack..............[/link]
Cool video on it's use as well......
[youtube]http://www.youtube.com/watch?v=go1Fq9CdKS0&feature=youtu.be[/youtube]
Cool how he uses that pack at the field to charge other batteries, then at home,
recharges that field pack with the CellPro charger on house current!
On a 20cc powered plane, you may want to consider the advantages of running an IBEC, such as the Wike. It gives you both an Opto kill switch for the ignition and it has an adjustable regulator, so you can set the voltage needed. On a 20cc plane, if you do have two batteries. Both should be for the radio, and the ignition
Pete
Pete
My Feedback: (7)
IN
Put them in the + line, each diode drops .7v each. Two in series would be
optional for A123/LiFe, one is generally good enough.
http://www.radioshack.com/product/in...ductId=2036270
My Feedback: (12)
WI
The diode method works great when you solder it properly and use shrink tube. One thing to consider is that the 1N4004 has a max current of 1 Amp. Most ignition systems draw .5 A, some others (like Zenoah) take more current.
In this case you need a bigger diode or better a voltage regular.
Also - if you want to use the same setup to run your receiver, get a regulator. This diode is not capable to deliver enough current for your servos under high load.
IL
ORIGINAL: OliverJacob
What if you were to use this one, a 3 amp diode. http://www.radioshack.com/product/in...ductId=2062578
My Feedback: (12)
WI
If a Diode is rated for 1 Amp, then I would not put more current through it. It may be ok to overload it for a short time. Doing so consistingly will heat it up and sooner or later cause it to fail. Again - this one is good for most ignition systems.
But is is not enough for most radio systems. More then likely it will be more then 1 Amp, depending on the servos, the flying style and some other factors. Hard to measure.
If you fly a big bird, your servos combined will draw a lot more current. It may work for some time, but will fail under higher servo workload.
Diodes are the cheapest and smalles part on your plane, why not spending a few more cents to be on the safe side?
To the previous poster - do you think the manufacturer of this diode lies when he states a max current? Or do you think your receiver with servos will draw less?See, I point out this potential problem and maybe prevent someone from loosing their expensive model - by changing out a cheap part. I am happy if I can help people out and sometimes I need someones opinion. You are welcome.
So what is your mission here?
Just to be clear, I get my voltage drops from WrongWayRC, they cost a few bucks but they are all nice and soldered and shrink wrapped.
My setups use his batteries made with two connections from the battery (plus the balance tap).
One goes to a JR HD Switch then to the reciever. The other goes to a HD switch, to the diode, then to the ignition.
I have 3 50cc planes setup that way, I live in Florida so I fly every weekend and sometimes during the week so I rack up a lot of flights. As I said, I've had other issues, some self induced (i married her right? ) but I've not had power system or ignition failure issues.
I am just finishing the review for the Hangar 9 giant Pawnee. Thats got 2 of the WrongWayRC packs in it. One goes into the 12 channel JR Power Safe Rx. The other goes one lead to a switch and a diode and then to the RC Extreme Power electronic ignition conversion (Zenoah GT80 twin) and the other goes to the 2nd lead on the Power Safe receiver.
After 5 flights yesterday I hitched up the Cell Pro 4S and the receiver only battery was at 74% and the rx/ign battery was at 67% I would term that 5 long flights as they were really just tooling around getting some time on the motor at mid throttle and that thing came with a tank the size of a canteen.
IL
I just put one togther and tested it on a fully changed A123. With out the diode 6.9v, with got it down to 6.5 only droping it .4v so I taged two togther got it down to 6.1, I thought it would drop .7v at a time.Tthis is what I bought... 1N4004 Micro 1-Amp Rectifier Diode.
My Feedback: (118)
If current capacity is a concern simply put 2 or more in parallel.
I have switched to all A123's on board my planes, including ignition packs. The ignitions are a mix of Rcxcel single & twins, Falkon single & twins, 3W twins & CH ignitions single & twins.
Be aware that voltage drop across the diode is proportional to current flow so simply using a volt meter is of no value. The 1N400x series are fine for ignition applications. The difference between numbers is the reverse voltage.
I would not recommend using diodes for the RX and servos.
Bliksem
Bliksem
My Feedback: (14)
I am thinking aout trying a RCeXL ignition kill swith w/BEC. Here is the web site. Has anyone used one of these on the DLE ignitiona with a Life4 or A123 battery?
http://www.valleyviewrc.com/estore/r...-with-bec.html
It must a a RF filter built into it because it pulls the power from the reciever.
