Go Back  RCU Forums > RC Airplanes > Giant Scale Aircraft - General
Bud Nosen 1/4 scale J-3 Cub
Giant Scale Aircraft - General Discuss all other giant scale aircraft here.
Old 02-04-2012, 07:40 PM
jstanton
My Feedback: (14)
jstanton's Avatar
Default Bud Nosen 1/4 scale J-3 Cub
My next door neighbor got a Bud Nosen 1/4 scale J-3 Cub from his Dad after he passed away. The plane is about 75% complete and is missing the ailerons, cockpit windows and cowl.[:@] Is there a place where we can find the cockpit windows and cowl? We will try and find out what we need for the ailerons. Also the plans say a .60 to .80 glow engine. I was wondering if a DLE-20 might workout OK or maybe a DLE-30? I would like to spin a large wood prop for a more scale look
Old 02-04-2012, 10:23 PM
dadragon
Default RE: Bud Nosen 1/4 scale J-3 Cub
Try fiberglassspecialtiesinc.com,they have what you need.
Old 02-04-2012, 11:01 PM
beepee
My windshield was formed from scratch, flat material. I flew mine with a Quadra 42 and it was great. It needed the weight in the nose anyway. Swung an 18x10 prop, or sometimes a 20x8.
Have fun!
Bedford
Old 02-05-2012, 06:42 AM
jstanton
My Feedback: (14)
jstanton's Avatar
Thanks guy's for getting me this information. I will try fiberglassspecialtiesinc.com today and see what they have.
Bedford thanks for letting me know about the Quadra 42. I think I will try a DLE-30. It says it will spin upto a 20x8 prop and that should be more than enough.
Old 02-05-2012, 09:25 AM
jstanton
My Feedback: (14)
jstanton's Avatar
I was able to find the cowl for this plane. What can I used to make the windows for the cockpit from and where can I but the clear plastic from?
Old 02-05-2012, 03:36 PM
dadragon
good going Jim,I got a g-23 in my sig 1/4 it's more than enough.on your print see if there is a layout pattern for the windscreen,you local hobby guy should have the plastic sheeting to make it.glad you found the cowling.have fun with the build.George.
Old 02-05-2012, 04:12 PM
jstanton
My Feedback: (14)
jstanton's Avatar
I will look on the plans and see if the is a pattern for the cockpit windows. Did you have to add any weight to balance the Cub? Does your G-23 have the magnito or EI.
Old 02-05-2012, 04:33 PM
dadragon
Jim;I had to add wt.so I made the bottom of the nose a hatch under the gas tank put 2 6V batts in and it is 1/4oz nose heavy and it fly's perfect.with floats it's riteon,oh yah it is a mag motor,the mag is in the back of the motor inside the motor mount.it is a 105"WS.later,George
Old 02-05-2012, 04:40 PM
jstanton
My Feedback: (14)
jstanton's Avatar
Geroge,
I am thinking about using a DLE-30 for this plane. It is a rear carb motor and I think it may be to long. I know the G-23 is a shorter engine. Did you have add anything to the firewall to get the right position of the prop hub?
Old 02-05-2012, 05:23 PM
dadragon
Jim; I made my firewall 1/2"thick,and I went the super cub cowl so I would not have to cut holes in the sides for the carb&exaust.think about thickening up the firewall and opening a center hole for the carb to be inside the fuss and move the gas tank a little.the DLE 30 will work well.George.
Old 02-05-2012, 05:30 PM
jstanton
My Feedback: (14)
jstanton's Avatar
George,
Thanks for the help with the engine. I'll do just what you recommended
Old 02-06-2012, 12:30 AM
beepee
Your LHS should have some .030" clear plastic stock, which should be about right. I made my own pattern by cutting some posterboard material until I had it the way I wanted.
Bedford
Old 02-06-2012, 01:29 AM
sebo
Here is where I get mine...........SIG
http://www.sigmfg.com/cgi-bin/dpsmar...FV4.html?E+Sig
Click on building materials, plastics......left side of screen.
Order more than one sheet in case you mess up.
I make a template out of poster board that I purchased at an arts and craft store and then transfer it to the plastic once the poster board is a good fit.
You might want to get a sheet of the next size thicker plastic too......It works nice for the side windows and may work well for the main window screen.
Make sure you get the 17 inch size....the smaller won't work for the main window.
Good luck with your project.
Old 02-06-2012, 02:48 AM
jstanton
My Feedback: (14)
jstanton's Avatar
Guy's
Thanks for the info on the poster board template idea. I'll go to the art store and pick some up. I'll also look for the clear plastic sheets at the LHS in the .030 size or larger. Do you guy's have any pics of you engine setup I could look at?
Old 02-06-2012, 06:11 AM
sebo
My LHS never carries it.. be sure that it bends easily but not too easily because prop wash will put a lot of pressure on it...You don't want it to deform while on the plane with full throttle if you can avoid it......drug stores carry poster board too.
Old 02-06-2012, 06:14 AM
sebo
I fly with an 18x6 prop with an ST3000.....I never go over 1/2 throttle. Way too much power. The large engine provides the weight needed for up front.
Old 02-06-2012, 07:18 AM
jstanton
My Feedback: (14)
jstanton's Avatar
does anyone know the distance from the firewall to the prop hud on thier setup.? That would help me alot
Old 02-06-2012, 09:30 AM
sebo
    6.75 inches from the firewall to the front end of the cowl.....and that is a tight fit.....not leaving any(much) room for prop clearance from the front  of the cowl.</p>
Old 02-06-2012, 09:58 AM
jstanton
My Feedback: (14)
jstanton's Avatar
Thanks for the info. With that distance being 6.75" I know for sure a DLE-30 will be a good engine for this Cub. I think I have all the info I need to now finish the model. Thanks everyone for all your help
Old 02-06-2012, 10:35 PM
dadragon
Jim; just make sure the spark plug cap does not touch the cowl that may cause radio interferance.have fun with it.George.
Old 02-07-2012, 07:43 PM
Lins
Maybe we can help each other out. I probably could have given you my cowl as I'm putting a super cub cowl on. Here's my thread for my Bud Cub.
http://www.rcuniverse.com/forum/m_10774047/tm.htm
Old 02-11-2012, 03:30 PM
mstcitabria73
here is a site for some window material for your cub, http://shop.balsausa.com/category_s/183.htm, the distance from hub to back of factory standoffs on the DLE30cc is 160mm or 6.3 inches, using one in a BN Citabria build I'm doing...........
Old 02-11-2012, 03:32 PM
Lins
It likely won't fit unless you get a side carb version. I know someone who might still be able to get one
Old 02-18-2012, 08:13 PM
dadragon
Jim; how is the cub comming along,well I hope.as for the color I used was from home depot,see if you can find merrigold I think thats how you spell it.its a real rich loc haven color you will like it I did when I first seen it.good luck with the finished plane.George.
Old 02-19-2012, 07:51 PM
jstanton
My Feedback: (14)
jstanton's Avatar
George,
I am not a scratch builder persay but I am having a little trouble trying to figure out the ailerons and how to build them. The leading edge of the aileron is slanted at about a 45 degree angle and I am having to hand cut all of the ribs and trim. I am coming along slower than I was hopeing[] But I will get it done
