Want to see DA100 next to BME110X?
My Feedback: (50)
I just had both of these engines NIB at the same time for one evening, and took a couple of pics of them next to each other. An enggine that is 10% larger weighs 33% less ha ha.
DKjens
DKjens
My Feedback: (29)
RE: Want to see DA100 next to BME110X?
It looks like the BME guys designed the motor with weight in mind, but there is NO cooling fin area, the engine in all has to be weaker built, and it can't have as much power as the DA,,, stick with the DA (I believe BME has disapointed alot of people in the last year or so)
ORIGINAL: RickP
I was considering it prior to buying my DA-100 untill I heard it ran like a 3 legged washing machine.
ORIGINAL: jongurley
I see cooling fins, so there must be SOME cooling fin area,
Why "does the engine HAVE to be weaker built"...remember, lighter does not mean weaker?
And why CAN'T it have as much power as the DA ...what are the acutual numbers?
ORIGINAL: jongurley
.....but there is NO cooling fin area, the engine in all has to be weaker built, and it can't have as much power as the DA,
I'm running the 110X in my Wild Hare 330. I don't have to bash 3W or DA (both quality engines) in order to feel good about my engine because I can truthfully say that *MY* 110X lives up to the hype! All three major brands can fly a 30 pound 35% aerobat with authority, so the fact that my 110X DOES, in fact, make more power than a DA is less important to me. Many fields that I fly do have noise issues, so what IS important to me is that my 110X with the LARGE Pefa LL cannisters weighs ounces LESS than a DA with stock mufflers. I now have a package that is very strong while at the same time very quiet, and paid ZERO weight penalty.
Yep, I'm VERY satisfied with mine, too bad Keith can't turn them out faster.
Maybe the DA is "OVERBUILT" ? How much cooling do you need? Balsa or lite ply to duct air over the fins is much lighter than aluminum if needed! Remeber, they are based in Tuscon where it is really hot, but BME is in Texas where it is hot also. I just think BME did a little more research to see how much fin is really needed.
Both brands run well and have great reputations. I would buy either. The advantage to DA is the aftermarket exhaust systems seem more available, as are specializd motor mounts.
ML
ML
My Feedback: (50)
Joe,
I found that by adding 1 lb 15 oz to the scale with the BME on it, the needle would end up where it is with the DA on it. Yes, it's a 5 lb scale.
Tim,
I find like you, that one does not have to look far or long for somebody who is ready to sling s..t based on 3rd hand information, or pure personnal perseption. One can only hope that the majority of people recognizes empty statements and bs when they see it. I have not read anything bad about the 110X, in fact, I just read somebody's praise of it.
On the cooling fin area and strength subject. Many 2-stroke engines of this displacement produce 2 to 2.5 times the HP at 2 to 3 times the rpm. Granted, these engines have a limited life expectancy before needing a rebuild. The point is, our engines are really not that hard stressed, and may very well be over engineered. I seriously doubt that Keith Baker would sink the kind of money he did into designing and producing this 110X, without having some serious engineering behind it, confirming that it is a very viable product.
DKjens
Tim,
DKjens
DC
You forgot to mention the fact that the DA is available NOW, all it takes is a phone call for the BEST engine buying experience in the industry, bar none...
My Feedback: (21)
Actually, in Physics Heat Transfer, the BME 110X's thinner cooling fins will actually dissapate heat quicker then DA's bigger heavier cooling find even though the DA's fins will absorb more heat energy.
** sorry for poor spelling, had to fix it (I was at work when I typed it)
ORIGINAL: shortman
Actually, in Physics Heat Trasnfer, the BME 110X's thinnger cooling fins will actually dissapate heat quicker then DA's bigger heavier cooling find eventhough the DA's fins will absorb more heat energy.
ORIGINAL: 3D Joy
On the other hand, it would take much less time to cook a BME 110 than a DA 100.
Why would you say things like this. I have first hand upclose experience with the BME 110. It kicks *****. It will blow away any da100. If you want the finest, most powerfull, 100 class engine available today get the BME110.
If you want to see thin cooling fins, go look at the huge radials from WW2 fighter planes.
Joe
Joe
ORIGINAL: jongurley
My Feedback: (29)
I am not bashing BME I am just making general comments, You can LOOK at the bme and see it has smaller fins, you can LOOK at it and see that it has holes drilled in it, granted they are not in critical spots, and you can LOOK and see all the planes that are flying DA's versus BME's. And all of that about the heat energy dissipation or heat transfer faster than the heat $#$#%^$#^##, it doesn't matter as far has us human's think,,, it might transfer heat faster but when the fins get (full) of heat it can't go anywhere but the motor, if the DA's fins are bigger more total room for dissipation.
My Feedback: (50)
ORIGINAL: 3D Joy
Boy, I've never before started a thread that developed this fast ha ha, and I didn't even start a bashing thread.
DKjens
ORIGINAL: jongurley
Ok, so you don't understand the principals of heat transfer, no big deal. The heat does have somewhere besides the motor to go to, it is transferred to the air. If it can be transferred to the air faster, rather than being retained in the fins (making them full ), the combustion chamber components will be cooler.
There is a lot to proper fin design where heat transfer is concerned. Things like thickness, taper, etc are important. Not having crunched any numbers on these engines (probably couldn't do anymore anyway) I can't say which is technically "better", but the BME design seems to be based on sound principal. I guess time will tell.
My Feedback: (9)
Somewhere on here there is a 110 Hovering around a 40% plane!That alone is pretty impressive.I still think that both motors kick butt.Once the 110 has some time on it...well we'll have to see.My BME 50 has never missed a beat!!
My Feedback: (29)
Any 100cc twin can hover a 40% airplane its just that they are lacking on power needed to do it safely,, if you look and listen to the video it is turning awfully hard rpm's to keep the bird hovering, That doesn't prove anything about horsepower of BME's, it is just a conversation piece. Does anyone else have any comments on horsepower between BME and DA, and yes what you guys are thinking is right I am a DA lover but it is with reason, I have seen BME's fly and there is a horsepower difference in the DA's favor. If you are a DA hater than thats fine buy what you like but if it isn't broke don't fix it. I would like to see some honest rpm readings between the two.
ORIGINAL: jongurley
How can you arrive at all these conclusions by just looking at some pics on a thread???
*****EDITED OUT DEROGATORY REMARK*****
Actually I made that video, the plane hovers at 1/2 throttle and has plenty to spare to pull out. It is no where near "unsafe" and that engine had less than 20 minutes run time, as it is breaking in it is getting stronger.
I think you are just someone that has to argue with everything.
Joe
Joe
ORIGINAL: jongurley
