H9 Edge, Moki 1.8 or OS 1.6
My Feedback: (69)
AR
whats the best setup? i like the moki, but it is 12 oz heavier than the OS, and from what read, setup per instructions, the OS is a little nose heavy in the plane, so will prob go with the OS 1.6, but what prop works best for this combo of OS 1.6 +H9 Edge 540? was thinking 18x6 Mejzlik
My Feedback: (34)
I used a bisson muffler - pitts style - lot of room for exhaust gases to exit.
Never got to weigh it - two weeks ago my son shreded it through the trees when he lost radio contact. why, why, why do planes always go DOWN when you loose radio contact???? Shouldn't they go UP ONCE IN A WHILE?
Jerry
Jerry
My Feedback: (69)
AR
what I meant about the muffler was, will the bisson muffler on the Moki clear the stock hangar nine motor mount that comes with the 540? thought someone told me that it didnt
My 1.8 with the Bisson muffler JUST cleared the mount, in fact, it is touching. I thought it might turn into a problem, but thankfully I was wrong. All is okay.
For a prop with the Moki I really like the Moki brand of probs. They are high gloss and really perform well with the 2-stroke. I think the reason for the performance is the narrow blade and the APC like style.
I have heard of great results with Mejlik (sp?), but I have not tried these as of yet.
Good luck.
Mike
Good luck.
Mike
My experience has found that the 18x8 Moki worked best. Other type props will be different and generally less diameter. I was also going for (pull) diameter vs. pitch. Still flies quite fast with the 8 pitch.
Mike
Mike
My Feedback: (21)
I'm getting my H9 Edge 540 soon and next year I'm going to compete in IMAC with it.
This is going to be my set-up and this should be an awsome awsome plane!
General Info:
Ø Wingspan: 78”
Ø Weight: 11-13 lbs
Ø # Servos required: 5 servos
Motor Used:
Ø Name: OS 1.60FX
Ø Muffler: Jett In-Cowl Muffler
Ø Prop: Mejzlik 18 x 6
Ø Fuel:
Ø Spinner: 3” Tru-Turn Spinner
Plane:
Ø Hanger 9 Edge 540
Servos:
Ø 2 x Hitec 5945 digital (servocity.com)
Ø 2 x Hitec 5625 digital
Ø 1 x Hitec hs-81
Radio:
Ø Futaba T6XAS
Batteries:
Ø Li-ion Cells 3.6V/mah
Linkages:
Ø Clevis’s: MKD Control Horn Clevis w/Ball Bearing
Ø Pushrod’s: Central Hobbies Carbon Fiber Rods
Ø Servo Arm’s: H9 metal
Ø Bell Crank: MKD Dual Elevator Bell Crank-Ball Bearing
Other Accessories:
Ø Northern Model Products Ball Bearing Aluminum Tail wheels
Ø Machined 1/2 Servo Arm: Futaba
Ø Hanger 9 Pro-Lite Wheels
Ø Hanger 9 Fuel Filler
Ø True Turn adapter for specific engine
Ø Fuel Tubing
Ø Foam for cushioning radio and fuel tanks
Ø Antenna tube
Ø 12” Aileron Extension
Optional Items:
Ø Pilot Figure
Ø Instrument Panel
General Info:
Ø Wingspan: 78”
Ø Weight: 11-13 lbs
Motor Used:
Ø Name: OS 1.60FX
Ø Fuel:
Plane:
Ø Hanger 9 Edge 540
Servos:
Ø 1 x Hitec hs-81
Radio:
Ø Futaba T6XAS
Batteries:
Linkages:
Other Accessories:
Ø Fuel Tubing
Ø Antenna tube
Optional Items:
Ø Pilot Figure
Ø Instrument Panel
My Feedback: (21)
I choose the OS over the moki for several reasons, one 12 ounces is A LOT of extra weight, which in turns hinders performance. The moki your going to need a cline regulator (50$), os doesnt need the cline regulator.
I am also going with a Jett In Cowl muffler which will boost power dramatically, average 25%, and looking at the numbers they got it really really helps, so in no way will my os not have enough power.
I am going to put moose carbon fiber landing gear to save another 3.5 ounces and carbon fiber pushrods to save weight. One more weight saving thing is Lithium Batteries to help dramatically reduce weight compared to the regular nicads. Im using a 2000Mah pack to ensure several flights
MI
Optional Items:
Ø Pilot Figure
Ø Instrument Panel
Ø Pilot Figure
Ø Instrument Panel
Instrument pannel and pilot figure are optional, but if you intend on competing in IMAC you will take a hit on your score if they are absent. I wouldn't want to handicap myself that way, besides the plane looks better if they are installed.
H9 includes a instrument pannel sitcker that ought to qualify, but get a pilot figure from TNT landing gear. They are finnished, light weight, cheap and best of all they look great.
Moki's don't require fuel delivery assistance no more than os. Rather a lot of folks using these engines choose to equip them with fuel assistance delivery systems. This is not unlike glow assistance.
Mike
Mike
I think that the Saito 180 is the best choice. I have done everything imaginable with mine, and it has lots of power. I use the mejzlik 18-6 and still run 15% fuel. My edge weighed just under 13 lbs.
Use the OS 1.60 FX in your edge. I have this very combo using a slimline pitts muffler and the 18x6W apc and it comes out of a hover like a tractor. If that is not enough add the Jett Performance muffler and the performance is close to the moki 2.10. This is the ultimate combo for 3D hand down. Plenty of power with out the weight penalty.
My Feedback: (21)
Yeah, I'm going to use the Jett In cowl muffler. And the nice thing is the muffler adds on average 25% more horsepower but not only that, its lighter than the stock muffler it comes with!
My Feedback: (99)
h9 540 edge os 1.60
i just bought this plane and it has that comb on it and a cline regulator would like to take off the regulator but theres no pressure fitting on the jett muffler do you have to drill it.
or do i need this regulator.
need help on this :spinnyeye
My Feedback: (19)
IL
You DO NOT need the cline pump on the Moki. I'm running the MOKI 1.8 in a SIG 300XS and power is AWESOME. It will hover all day without missing a beat and has big power to climb out. The engine is spinning a 19x8 mezjlik prop.
My fuel tank is back by the CG, a ways rear of the stock location. The engine runs flawlessly and puts out great power.
