HL Smoke System
Old 08-28-2006, 06:01 PM
Killhammer
Killhammer's Avatar
Default HL Smoke System
Hey all
I just did some work on the smoke system. I thought that my stock smoker had died on me so I order two more from Mato, got them on Friday and put one in on Sunday after adding some oil I fired it up but got no smoke.[:@]
Being that I like to find out how things tick i cut open my old smoker to see if the element was burned out. I plugged it into the tank and turned it on, and smoke all kinds of smoke off of it.
It seems the they add some extra batting to the oil chamber which makes it hard of the smoke to get out. I removed the batting and left only the wick, then put the smoker back together. Now I get pretty good smoke. I made a small video of it.
http://www.youtube.com/watch?v=mYJUNwoMaLQ
Old 08-28-2006, 06:15 PM
sownare
Default RE: HL Smoke System
Impressive!! Very realistic!
Old 08-28-2006, 06:19 PM
trotski
trotski's Avatar
Wow !!! THAT does make a difference !!! keep us posted on how it runs, 'cos that looks like a useful mod
Cheers A
Old 08-28-2006, 07:40 PM
gorehound
Hi Killhammer
How easy was it to get it apart?
Cheers
Gorehound
Old 08-28-2006, 07:46 PM
Turbobearcat
Batting or Baffles?
Old 08-28-2006, 07:49 PM
gorehound
Hi
Im'm confused by the question sorry. I was meaning how easy is the smoker to take apart in the HL tanks.
Cheers
Gorehound
Old 08-28-2006, 08:07 PM
Turbobearcat
I was asking Killhammer the question, he said "Extra batting in the oil chamber" I was questioning his meaning of batting?
Batting is a baseball term..
Baffling would be compartments in the smoker..
See where I am going with this?
Old 08-28-2006, 08:33 PM
Killhammer
Killhammer's Avatar
It was like stuffing use find in a pillow. I should have took some pictures. The oil tank is like a box then on the inside is the element with the wick wrapped around, the rest of the space was filled with some kind of cotton or something. I removed the cotton and left only the wick.
Jeff
Old 08-28-2006, 09:03 PM
TIGER76
TIGER76's Avatar
Looks great now thanks for the tip too[sm=wink_smile.gif]
Old 08-28-2006, 09:53 PM
Turbobearcat
ORIGINAL: Killhammer
Jeff
Thanks Jeff..that clears that up completely!!
Old 08-28-2006, 11:36 PM
Harquebus
Harquebus's Avatar
Wanting to know this too. Just how hard was it to get apart and reassemble? Did you use glue to reassemble it? Seems that you'd have to degrease the unit so glue would adhere to the parts--seems like an undertaking.
-Harq
ORIGINAL: gorehound
Hi Killhammer
Cheers
Gorehound
Old 08-29-2006, 04:42 AM
Killhammer
Killhammer's Avatar
Getting the unit apart depends on how well it was glued together in the first place. I used a straight razor to cut the oil tank open, then cleaned it with alcohol. Then i just slid it back together and used some rubbery stuff called Shoe Goo ( found At K-mart or Wal-mart) to seal the tank. I will post some picture this evening.
Jeff
Old 08-29-2006, 07:36 AM
Turbobearcat
Jeff
I will be waiting!
I just wonder what the long term impact will be?
Old 08-29-2006, 05:41 PM
Killhammer
Killhammer's Avatar
Here are some pictures of the smoke unit. The yellowish or gold color material is the batting I was talking about. I used the shoe goo to seal it, it drys pretty fast but dose on get hard. I have ran the system for a pretty good time on Sunday, Monday and, today it still going strong....
ID:	515495   Click image for larger version
ID:	515496   Click image for larger version
ID:	515497   Click image for larger version
Old 08-29-2006, 09:27 PM
Turbobearcat
I have noticed on mine if I over fill it, to turn the tank straight up and blow into one of the tubes to get the extra out...
Then run the crap out of the tank a few times(battery charges) and it should start smoking again..
I did this tonight and it's smoking again!
Old 08-30-2006, 12:39 AM
Harquebus
Harquebus's Avatar
The German RC-Panzerketten site has some threads about this exact mod where a HL owner removed the extra batting and restored the smoker to proper function. It seems the batting is a universal problem as it chokes the unit up.
I like the idea of keeping the smoke unit reservoir but replacing the piston mechanism with a 1 1/2" PC "box fan".
-Harq
Old 08-30-2006, 08:06 AM
Turbobearcat
Agreed.. it seems this is the rout to go by using a 1.5 inch fan..
Does Radio Shack sell those?
Old 08-31-2006, 01:18 AM
Harquebus
Harquebus's Avatar
I didn't find any from Radio Shack that were small enough but that was only a cursory glance at their site.
I did find this source, however: http://www.directron.com/40mmfans.html
-Harquebus
ORIGINAL: Turbobearcat
Old 08-31-2006, 05:56 AM
Turbobearcat
I'm going to use a fan from a Dell laptop fan.. it's small enough and pushes enough air..
Old 08-31-2006, 08:14 AM
gorehound
Hi guys
Just a question that might be stupid but I am more of a modeller than an RC person - I am new to RC and still learning. Would it be possible to rig the fan(s) onto the drive motors so the more throttle you give the more the fans pump. It would be more like the real thing then as the faster the engine turns the more exhaust fumes are chucked out.
Cheers
Gorehound
Old 08-31-2006, 08:58 AM
swathdiver
swathdiver's Avatar
Anything is possible! You'd have to add a gear somewhere to the gearbox and a driveshaft to the fan. The fan could be located near the gearbox with a hollow tube going to the smoke unit, or the driveshaft going aft (presuming a Tiger) to the fan.
Old 08-31-2006, 09:13 AM
TIGER76
TIGER76's Avatar
I wanna see that done now that would interest me in getting a smoke unit
Old 08-31-2006, 02:08 PM
Turbobearcat
The only problem I see with using a fan that is hooked to the gear box is when you place the tank in reverse..the fan will suck the smoke into the tank..
Not a good idea there!
Old 08-31-2006, 03:39 PM
gorehound
Hi
Sorry. Did not make myself clear I think. I meant just take the current from the motors to the electric fan. It should be easy to rig something to stop the fan going in reverse - hopefully.
Cheers
Old 08-31-2006, 03:52 PM
digger1976
You seem to be very familiar with this. This maybe a silly question, but is it possible to get black smoke? It is already very realistic, but black smoke rock!
