single smoke injector nozzle?????
My Feedback: (31)
Anyone running a single smoke tube injector nozzle with success? I have both, but it would be much easier in my patricular application to run just one....using a JC smoke pump......just wondering if I can get good smoke (enough fluid through one tube) with only one injector nozzle in the exhaust stream....will be using MDW Super Dri fluid....
Thanks.....
Thanks.....
RE: single smoke injector nozzle?????
My Single Tam smoke injector is MORE than enough. It sucks the tank dry in no time. I cut it back a bit. I have the tam pump but any fuel pump will work with a controller. I use plane jane #2 diesel.
In my 2 jets i have following setups:
a) Boomerang XL, Sullivan skywriter pump, 32 oz tank, 1 tube injector> plenty smoke.
b) Fei Bao Rafale, Tamjets smoke pump, 2 x 12 oz tanks, 1 tube injector-> plenty of smoke (i was even able to align the single injector in a way to have smoke difused equally in both exhausts.
Hope this helps.
Regards
Hope this helps.
Regards
My Feedback: (19)
How do you guys get the smoke to ignite and pop and flame like I see in some videos? I saw it on the CA jets video, the jet was sitting on the runway and when the smoke was turned on the smoke oil lit and flamed for a second, looked pretty cool. .
AB, CANADA
Wayne......right on!!!!!! Whose smoke system? How many oz tank and about how much time do u get? Thanks.....
My Feedback: (26)
ORIGINAL: Jack28
ORIGINAL: noahb
Question:
How do you stop the nozzle from siphoning (sp?) when the pump is off. I have a TME Smoke system and when I shut it off, I can see a very fine mist being siphoned out of the nozzle.
Question:
I've seen this phenomenon as well, but it has been uneventful for my flying.
Maybe putting some sort of mechanical stopper in line that is switched with your smoke switch on your tx?
Raf
My Feedback: (31)
ORIGINAL: noahb
Question:
Question:
I did a test run on my smoke system today in the rain....Rhino, JetCat smoke system, one injector nozzle, SuperDri.....plenty of smoke.....will fly the system tomorrow.......thanks for the replies.....
My Feedback: (80)
ORIGINAL: ravill
switch on your tx?
Raf
ORIGINAL: noahb
Question:
Question:
switch on your tx?
Raf
C'mon man!!! Just burn it all!!! Siphon worry wort!!!
ORIGINAL: noahb
Question:
Question:
saw that on my elan too. it would suck the tank thru the pump.
make sure your cutoff valve is between pump and nozzle.
ORIGINAL: noahb
Question:
Question:
IL
I use a check valve that requires a little presure from the pump to open.Same check valve used on piston engine smoke system to keep mufflers from sending hot gasses back into some system.
