Wrong Demensions?
Wrong Demensions?
Does hobbyking have this lipo's demension's backwards?hobbyking.com/hobbyking/store/uh_viewItem.asp<span class="Apple-style-span" style="font-family: Verdana, Arial, helvetica; font-size: 11px; color: rgb(51, 51, 51); "><table width="246" border="0" cellspacing="1" cellpadding="2"> <tbody> <tr> </tr> <tr> <td bgcolor="#dbdbdb" style="color: rgb(51, 51, 51); font-family: Verdana, Arial, helvetica; font-size: 8pt; ">Length-A(mm)</td> <td bgcolor="#dbdbdb" style="color: rgb(51, 51, 51); font-family: Verdana, Arial, helvetica; font-size: 8pt; ">135</td> </tr> <tr> <td bgcolor="#e3e3e3" style="color: rgb(51, 51, 51); font-family: Verdana, Arial, helvetica; font-size: 8pt; ">Height-B(mm)</td> <td bgcolor="#e3e3e3" style="color: rgb(51, 51, 51); font-family: Verdana, Arial, helvetica; font-size: 8pt; ">22</td> </tr> <tr> <td bgcolor="#dbdbdb" style="color: rgb(51, 51, 51); font-family: Verdana, Arial, helvetica; font-size: 8pt; ">Width-C(mm)</td> <td bgcolor="#dbdbdb" style="color: rgb(51, 51, 51); font-family: Verdana, Arial, helvetica; font-size: 8pt; ">45</td> </tr> <tr> <td bgcolor="#dbdbdb" style="color: rgb(51, 51, 51); font-family: Verdana, Arial, helvetica; font-size: 8pt; "></td> <td bgcolor="#dbdbdb" style="color: rgb(51, 51, 51); font-family: Verdana, Arial, helvetica; font-size: 8pt; "></td> </tr> <tr> <td bgcolor="#dbdbdb" style="color: rgb(51, 51, 51); font-family: Verdana, Arial, helvetica; font-size: 8pt; "></td> </tr> </tbody></table></span>
1 Post
RE: Wrong Demensions?
ORIGINAL: thehuntingterminator
lol, i don't have one. i found a way to do it using like 2 different adapters
SK, BANGLADESH
you should really learn to solder, it's not that hard
another part of the hobby that can entertain for hours, SOLDERING
you don't want 4 adapters between your battery and your ESC, so what you need to do is cut off the bullet connectors and solder on a proper connector
you could also buy a battery with bullet connectors inside the battery, then you plug bannana pins into the battery that you can buy with whatever battery connector you prefer
http://www.amainhobbies.com/product_...-ROAR-Approved
http://www.amainhobbies.com/product_...Female-Traxxas
ORIGINAL: sloppyG
