RC Electric On-Road vehicles, race cars and more Discuss electric RC on-road vehicles here. Also discuss brushless motors, speed controllers, brushed motors, etc
I lost a capacitor. Problem?
Old 08-14-2011, 07:57 PM
jrowles91
Default I lost a capacitor. Problem?
After doing a top speed run in my HPI Sprint I ran it around for a little bit and turned it off. Nothing unusual about how it ran and pulled 49.3 mph. I thought it was perfect for the gearing and motor. When I got home I did a little maintenance and noticed one of the two capacitor was missing. Is this an issue? It won't be covered under warranty so Im hoping it will be ok. Thanks for viewing and for comments.
Old 08-14-2011, 08:23 PM
jrowles91
Default RE: I lost a capacitor. Problem?
Guess I should have stated already its a 60 ezrun esc and here is a picture.
http://i1093.photobucket.com/albums/...-14_142056.jpg
Thanks again!
Old 08-14-2011, 09:11 PM
Brainanator
Brainanator's Avatar
buy one at the same specs and replace it. From the looks of your other one I would replace them both...
Old 08-14-2011, 10:24 PM
Haddi Taha
Haddi Taha's Avatar
just buy 2 new ones, makesure you secure them next time
Old 08-15-2011, 08:20 AM
jrowles91
ORIGINAL: Brainanator
I thought about this too, but this happened before and I tried re soldering it on. Clearly though it didn't work. The board that it's on seems like it has a plastic covering on it so I couldn't get the solder to stick to the board. Any suggestions?
Old 08-15-2011, 08:38 AM
jrowles91
Can I just splice this replacement set in? http://www.hobbypartz.com/escca.html
Old 08-20-2011, 01:10 PM
dragnse7en
Banned
You're going to have to peel apart the plastic case with a slim flat-blade small sized screwdriver.
After you peel apart the case, you'll see the solder pads on the caps.
Easy enough, after you carefully peel the case apart and read my soldering thread
You'll certainly void the warranty if you go this route. Remember that!
Old 08-20-2011, 03:26 PM
proanti1
proanti1's Avatar
ORIGINAL: jrowles91
Those are completely different than the ones you originally had. They need to be the same.
Old 08-20-2011, 05:29 PM
jrowles91
ORIGINAL: proanti1
ORIGINAL: jrowles91
what would happen if I used them? I thought it didn't really matter as long as you weren't getting smaller than stock.
Old 08-20-2011, 07:20 PM
dragnse7en
Banned
You can fry the FETs if you don't.
