Eliminating gas spills in the SUV
Old 02-19-2012, 12:45 PM
grosbeak
grosbeak's Avatar
Default Eliminating gas spills in the SUV
Considering that...
[*]My new plane is gas-powered[*]Gas is stinky[*]My transport vehicle is a family SUV
I want to make sure that no gas leaks onto (into) the carpets during transport. I've built two items to help ensure that doesn't happen.
GAS CAN TRAY
The tray does double duty as a spill protector and a mounting point for the pump. The gas can is held in place by a pegged dowel. The inside of the tray is coated with 30-minute epoxy, so if any does leak out of the can, it will be contained.
VENT LINE FUEL STOPPER
I had a spare fuel fitting and while I was casting around for something to stop it with I found some music wire that filled the gap perfectly.
I fed the wire about halfway into the fitting and soldered it into place there. Once that was done I cut off the excess wire and dressed up the bottom.
That should keep any gas from dripping out of the vent line during transport.
Old 02-19-2012, 01:17 PM
Oberst
Banned
Default RE: Eliminating gas spills in the SUV
I have a idea!!! Go glow or electric!
Just pulling your leg.
Pete
Old 02-19-2012, 03:58 PM
Walt Thyng
My Feedback: (9)
Pete: Amen electric!
Walt
Old 02-19-2012, 05:28 PM
kenh3497
kenh3497's Avatar
Very nice solution [sm=thumbup.gif]
Ken
Old 02-19-2012, 06:23 PM
Pylonracr
Pylonracr's Avatar
One last line of defense. Use a cookie sheet with paper towels or rags in it, and place it under the plane. You should even be able to put your fuel caddy on it. If anything spills or leaks, it will be in the pan. Take it out when you take out your plane. A little air freshener hanging from the mirror will take away any residual gas smell inside the car.
Old 02-21-2012, 02:50 AM
telejojo
Get a trailer........................................... ...............
Old 02-21-2012, 08:43 AM
bolar
bolar's Avatar
ORIGINAL: Pylonracr
Cookie sheet, that's a good idea. The Dubro stopper you have isn't very airtight, and your going to get vapors coming from your fuel jug. I have the same stopper and had some gas go bad at the end of the season last year with that stopper. I'm looking around now for something better, I'll probably end up making my own.
Old 02-21-2012, 09:02 AM
kenh3497
kenh3497's Avatar
ORIGINAL: bolar
Shelf life of gasoline these days is about 30 days from the time you pump it at your favorite watering hole. IMO I would always use a fuel stabilizer/fuel system cleaner. My favorite is Sea Foam.
Ken
Old 02-21-2012, 09:52 AM
bolar
bolar's Avatar
ORIGINAL: kenh3497
ORIGINAL: bolar
Ken
Yeah, I use a fuel stabilizer, with the oil and stabilizer it's become a "witches brew" of gasoline. 30 days, it took me most of the summer just to burn the gallon I had. Well at least gas is still cheaper than glow...for now.
