Help! Sanded a pinhole in my Kovall, gotta start over
My Feedback: (10)
RE: Help! Sanded a pinhole in my Kovall, gotta start over
ORIGINAL: speedracerntrixie
Please use the MEK outside with a mask and gloves.....................
Most definitely. I have no brain cells to waste!
And then, after the removal process, I get to deal with the dope fumes again! Wheeeeeee! LOL.
A patch will crash proof the plane. If the patch is on the bottom (or top for that matter) it becomes an "access panel". Put a matching patch on the opposite side. Don't let ANYBODY tell you otherwise.
Ken
Ken
Questions:
1) how large is the pinhole?
2) what did you use to attach the fabric?
3) what is the topcoat? Dope, enamel, urethanes?
4) how did you build up the dope coats? Nitrate, butyrate, color?
I don't believe that you should have to rip off the covering because of a small fault. Can you post a picture?
Unless your finish is clear or translucent, a small silkspan patch will sand/feather out to the point where its virtually unnoticeable.
